Question about The Optics
Crossman storm xt scope 3-9x32 having a hard time to adjust the the dot to be in the middle of cross.
magoo23
  • 22 Answers
SOURCE: sighting in red dot shotgun scope
Load your gun up and when you can shoot it, aim with your new glass(Scope) and lay out a group of three slugs, not buckshot, (i'm assuming your shooting a shotgun). Then use some trial and error to tighten your dot to your grouping. I don't blame you for the confusion, but normally, most scopes set up for this adjustment pattern are moving your target according to the knobs, not your crosshairs or dot. Another option you have is to buy a laser bore sighter. then you can play with adjusting your scope for in the field or wherever with much more comfort when you need to. You can find them online at walmart or almost any sporting goods store these days, yes they save ammo and yeas they save time, but i still shoot to make sure i'm dead on after using mine.
Posted on May 06, 2008
SOURCE: red dot finderscope alignment problem
point the telescope at some thing during the day and adjust the finder scope and at night point at a star look through the eye piece and center the object in the eye piece then adjust the finder scope.
Posted on Jan 02, 2009
fps353535
  • 99 Answers
SOURCE: I don't know to set the scope for distance and for
removing clutter from My Work Queue and Formn boards
If this problem remains unresolved. repost/comment and ill clarify any issues your having
Posted on Apr 10, 2009
fawkwindows
  • 96 Answers
SOURCE: need manual to set redt dot scope. don't know how
can you be more specific, what is the name and, model number of your optic kit, is it leapers?
Posted on Dec 13, 2009
agent91
  • 2100 Answers
SOURCE: How do I adjust my scope on my Crossman bb/pellet rifle .177
Assuming the scope is ok, and the gun is ok, it must be the shooter, Not you but the stance, holding, bench rest, something is not consistent. If I was you, I would set up a big piece of cardboard at 15 yards, get the rifle on a beanbag or a bench rest, aim at a one inch spot in the center of the cardboard, shoot about 3 times, depending on where the pellet is hitting, move the adj knobs accordingly, do it again, 3 times, adj, as many times as it takes, get it centered, then, shoot it about 3 times at a clean plate, if it hits it's mark 3 times, then you can try it standing, and you should be able to build confidence in it so you know where it shoots, and won't be discouraged. Now if the rifle is bad, or the scope mounts loose, you will fight the thing all day and end up trashing it. I would blame the mounts first, then the scope, then the rust spot in the barrel, rare. If it is a break action rifle, you can set it up in a box with v's cut into it, look through the bore at the target, make sure it doesn't move, the scope should be looking at the same exact thing, if it isn't, something is wrong. You can set it up this way to start, and then fine tune it with pellets. Check it out, hope this helps.
Posted on Aug 04, 2010
How lighten the trigger pull
Sorry, this is I'll advised in this or any firearm. These are set with internal pressure to avoid accidental firing. I am sorry we will not be able to help you with your problems at this time.
Mar 25, 2016 | Crosman Storm XT .177 Air Rifle with 4X32...
I just ordered this on amazon for a crossman phantom and i just wanted to make sure this scope is safe to be used with spring rifles
Yes they are made to withstand large caliber pistols and rifles, with way more static shock. Hope this helps Fix Ya up.
Jun 03, 2011 | Tasco 1x30 Red Dot Sight BKRD3022
My cross hairs do not move when i adjust my sights. i bought a laser bore sighter and the laser points in the same exact spot no matter how far i turn my adjustments nor do my cross hairs move.
This happens a lot during bore sighting, - no shock to the scope to jar the cross hairs. So take your screwdriver and use the handle - rap the scope or better just tap it. Not hard enough to bend/dent it but jar it so things can move if need to.
Jan 04, 2011 | Tasco Target/Varmint 6-24x42mm Rifle Scope...
Cross hairs wont move when trying to ajust
The cross hairs don't actually move when you adjust a scope, instead, they are contained within what is called the erector tube. When you adjust your scope you are actually moving this tube, thus the cross hairs do not move around in your field of view
Sep 19, 2010 | Tasco Target/Varmint 6-24x42mm Rifle Scope...
Aug 01, 2010 | Crosman Adventure Rifle Scope 3-9X 50...
Cross hairs turn when adjusting power
Sounds like somebody took your scope apart and forgot something. You can remove the rear of the scope, but you might want to send it back to the factory. Some scopes are filled with nitrogen to stop them from fogging up, But maybe only the front part. Take the eye piece off, you should be able to get to the cross hair unit, it should come out in one piece, find out why it spins, might be missing a washer, I have replaced the cross hairs on scopes before with spider webs, I tried a dolls hair once, I thought it was thin enough, .002 ",, It looked like a rope inside there when I got it back together. Good luck, let us know what happens.
Feb 14, 2010 | Tasco Target/Varmint 6-24x42mm Rifle Scope...
I have a crossman 4x15 power rifle scope. Which way do I turn the elevation/windage dials fro up,down,left, and right?
Under the adjuster cap there should be a scale with an arrow marked up or right (depending on which one you are looking at. If it's not marked, place the gun in a vise (gently as not to crush it, cover metal parts with a towel)
Fire the gun while in the vise at a large sheet of paper several yards away (careful where the bullet goes...use bails of newspaper or plywood backing)
Sight through the scope and move the cross-hairs 'till they are exactly on the bullet hole. After you have done that, keep increasing the distance and adjusting up to compensate for bullet drop till you reach your desired range. Side to side adjustments should only be minor. Before sighting in, make sure that the scope is securely mounted or any adjustments you make will be irrelevant. While sighting, always use a bench rest...shooting "off-hand" will never give you any degree of accuracy because everyone moves and shakes a bit.
Jan 23, 2010 | Optics
New gun - Storm XT Model c1k773932. Never used
where can we order the spring for this gub?
Nov 26, 2009 | Crosman (4032)
When you zoom your scope does the impact point change on the target? is that when you use mil dot?
No, the cross hairs remain fixed. The zoom serves only to magnify the field of view.
Aduz
Mar 25, 2009 | Tasco Target/Varmint 6-24x42mm Rifle Scope...
Optics Logo
Top The Optics Experts
 steve
steve
Clyde Ottaway
deton8 von Splosion
Are you a The Optic Expert? Answer questions, earn points and help others
