Question about Canon imageCLASS MF4150 All-In-One Laser Printer
Kept getting 'remove MP Paper' error message
Bought a new machine...as soon as tried to receive fax, it displays 'remove MP Paper'...there is no paper in MP tray. In taking to Canon support, they mention there should be a paper...just didn't made any sense...
I will like to know the solution to this problem.
Posted on Jan 18, 2010
    Welcome Back:
    Visited the website for 2 consecutive days.
I got the same problem and it turns out that something was stuck on the multi purposed loader just above the place where you put paper. This message means that when it receive fax it will check the multi purposed loader first just in case you want to print out with some special papers or formats, hence if there is something in it, and since it's not paper it can't print out. So you have to remove it, in another words, check it out you might see something like paper clips or my case it's a little scissor. If there is nothing on it, it will load the normal paper to print out. Hope it helps.
Posted on May 30, 2012
I recently bought fax HP2140 and a while ago I saw fax ringing and info: receiving but nothing came thru. It is important to me that I receive faxes because I bought it for business purpose. My nanny threw...
The fact that the phone was ringing and the fax answered the call doesn't necessarily mean, that it was a fax transmission; someone might have called your number and tried to talk, but hung up hearing the fax beep.
You have to ask someone with a working fax machine to try and send you something, then you will be sure whether your fax works fine or not.
If this check will prove that it's indeed your machine that has some issue, then look for any error lights or messages on the display. If there was something wrong with paper, printing head, drive or whatever, you would certainly get some error message.
Oct 25, 2009 | HP 1250 Plain Paper Thermal Inkjet Fax
One Fax machine insatllaed in General Manager Office SEC railway. Problem of this FAX is we receive FAX either 30% or 40% not in complete form. Please provide me solution.
does your fax display error message such: CHECK THE PAPER SIZE or PAPER JAM?
IN CASE OF CHECK THE PAPER SIZE YOU SHOULD CHANGE THE REGISTRATION SENSOR FLAPER.
Jun 15, 2009 | Canon L220 Plain Paper Laser Fax
Brother Fax-1030 plain paper sending constant 'check paper' error
I got this error when I put the paper in without pulling forward the flap that hold the paper. It seems that the action of returning the flap to it's closed position sets the paper in the correct way.
I'd give that a try.
Mar 16, 2009 | Brother FAX-1030e Plain Paper Thermal...
Not receiving faxes
Folio is not what you want. The usual is letter (LTR) or 8.5 x 11. You may have to check the settings to set the default paper size.
Jan 14, 2009 | Canon PC-1080F Plain Paper Laser Fax
Fax Canon JX200
is there any error messages coming out from your fax machine.see the error messages first.the paper should run smoothly during sending and receiving process
May 06, 2008 | Canon FAX-JX200
Error message - "check Rec. Paper"
Check rec. paper means that the paper may not be routed properly thro' the cutter mechanism and out thro' the machine....if it is; then the sensors that detect the paper may be dirty or faulty.
Mar 31, 2008 | Muratec M1250 Fax
Incoming fax problem
DON'T KNOW IF THIS WILL HELP-BUT MY PROBLEM WAS SIMILAR--MINE WAS SAYING PAPER TOO NARROW WHEN I WAS TRYING TO PRINT AND COPY. I JUST KEPT MOVING THE FRONT SLIDER AND THE LEFT HAND SIDE SLIDERS BACK AND FORTH AND TOOK THE PAPER IN AND OUT --TRIED AGAIN AFTER EACH TIME--IT EVENTUALLY FIGURED OUT I DID HAVE THE RIGHT SIZE PAPER--
ALSO TRY---MENU--THEN--COPY SET-UP--THEN PAPER SIZE--SEE IF PAPER SIZE IS SET RIGHT.
Mar 01, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Can't print faxes due to error messages
Please check rear door area for paper, can you use manual feed slot? Power off machine with all jams removed and paper loaded, then power on, can you tell us exact error message/lights that are shown in this state?
Oct 15, 2007 | Brother IntelliFax-2820 Laser Fax
"printer error - check paper" after cartridge replacement
First remove all paper from fax machine and unplug fax machine from the wall socket for 12 seconds then replug fax machine into wall socket replace paper and try printing
Oct 03, 2007 | Sharp UX B700 Plain Paper Inkjet Fax
I can neither send or receive faxes
hi 003 - Recording paper jammed when feeding from the 3rd cassette. Remove the jammed paper. (1) Open the Printer Cover. (2) Remove the jammed paper. (3) Slide out the Paper Cassette. (4) Remove the jammed or wrinkled paper and reload the recording paper into the paper cassette. Caution: Make sure that the paper is set under the clips of the Paper Cassette. You can load about 500 sheets with standard weight paper (20 lb. or 75 g/m2). good luck
Feb 23, 2006 | Panasonic Panafax UF-885 Plain Paper Laser...
Canon imageCLASS  MF4150 All-In-One Laser Printer Logo
1,043 people viewed this question
old marine
old marine
