Hello can you help me find a part? its a thermal circuit breaker for an Omcan 20 quart standing mixer. made by Kuoyuh, 88 series, 16 amp breaker.
Need a part for an omcan mixer
  • 20 Answers
SOURCE: Replacement beaters for Hamilton Beach Hand/Stand Mixer Model 64586
Call the factory. they will point you in the right direction. number online!
Posted on Apr 11, 2008
SOURCE: Tripping Circuit Breaker
Same problem I have. I think the element or thermostat is gone. You will have to replace them. Here are the part numbers repectively:
4501649
4160214
Posted on Jul 05, 2008
bigg t
  • 640 Answers
SOURCE: I need the manual for the Hobart 20 Quart Mixer
Hobart doesn't release their service manuals to the general public,however i'm a hobart tech and repair these mixer's often.If you need any help let me know.
Posted on Mar 07, 2009
SOURCE: Remington electric tiller circuit breaker goes off
For about $20.00 you can buy 50 feet of 12 guage 3 wire yellow extention cord. You will then get all the amps you need to run your unit. If it still fails, you have a problem inside the tiller.
Tom MN
Posted on Jul 14, 2009
  • 145 Answers
SOURCE: Can't find any ite bl circuit breakers.
YOU CAN CALL ITE FOR A DEALER NEAR YOU
Posted on Jan 08, 2010
How can i fix this problem
PDF]SM-70 INSTRUCTION BOOKLET 7.0 Quart Stand ... - Cuisinart
https://www.cuisinart.com/share/pdf/manuals/sm-70.pdf
Cuisinart7. Do not exceed the maximum capacities listed in this use and care instruction book. 8. ... Troubleshooting . ... extra-large Cuisinartâ„¢ 7 Quart Stand Mixer.
Jul 30, 2015 | Cuisinart 7 Quart Stand Mixer
Does it has an internal fuse
I am not sure, often there is an internal thermal protector but easiest would be to contact the manufacturer or a serfvice center and ask the question.
Oct 04, 2014 | KitchenAid KITCHEN AID 5 Quart Artisan...
The head of my Kitchen Aid stand mixer wiggles a lot when I us it
Put it upside down on a towel and tighten the hinge pin screw right up inside the pedestal. It's in the middle & retains the hinge pin.
Nov 30, 2013 | KitchenAid KITCHEN AID 5 Quart Artisan...
Need information on circuit breaker BR2100 60amp
Hi - I'm an electrician and can help you with your question.
A BR2100 circuit breaker is a 2 Pole 100 Amp (for the part number "BR2100", the "2" indicates the number of poles and the "100" indicates the amperage) circuit breaker. It can be installed in a single phase or three phase 120/240 VAC system panel that specifically lists the BR series breakers as acceptable for use.
A BR260 A BR2100 circuit breaker is a 2 Pole 60 Amp (the part number BR260, the "2" indicates the number of poles and the "60" indicates the amperage) circuit breaker. It can be installed in a single phase or three phase 120/240 VAC system panel that specifically lists the BR series breakers as acceptable for use.
It is not possible to have a BR2100 rated for 60 amps, 1 or 3 poles, or a BR260 rated for 100 amps, 1 or 3 poles.
It is not permissible to install any circuit breaker brand or type in any panel that does not specifically include it on a list of acceptable circuit breakers.
Circuit breakers are designed to carry 80% of the amperage rating.
To determine the load a circuit breaker can carry, multiply the circuit breaker amp rating by 80%.
This means that if you need to supply more than 80 amps, you cannot use a 100 amp circuit breaker. A higher rating is required. A BR2110 would be acceptable for loads greater than 80 amps, but less than 88 amps because the formula above says: 110 amp x 80% = 88 amps.
To determine the breaker size, determine the load (by measuring with a meter or obtaining amp rating of the load from the data plate) and multiply it by 125%. Using the same numbers in the example above; assume an 88 amp load. 88 amps x 125% = 110 amp circuit breaker. The 60 amp breaker is acceptable for up to 48 amps because 60amps x 80% = 48 amps. A 48 amp load needs a 60 amp breaker because 48 amps x 125% = 60 amps.
I hope this helps and good luck!
Jan 15, 2013 | Eaton Corporation BR2100 Circuit Breaker
We have a 1999 "Thermal
DO NOT install a 20 amp breaker, you can cause a fire. The breaker is rated for the WIRES, and unless you change out the wires, the 15 amp wires will overheat and can cause a fire.
Typically, A/C units need dedicated power, with nothing else on that circuit.
One step that you may try is a new 15 amp breaker. Once a breaker starts tripping, is starts tripping earlier....
You may wind up running a new circuit for the A/C, if you do, size it for the A/C.
Jul 18, 2011 | Heating & Cooling
I have a k45ss that quit running. Replaced the brushes and did not help.
please , check thermal fuse one time blow 8-10 amps hidden in-line of power cord, must disassemble , check voltage with test Meter , careful don't get shocked ! can purchase fuse @ Radio Shack or replace this with resettable circuit breaker not a fuse
Mar 13, 2010 | KitchenAid K45SS Classic Stand Mixer
Relay Box for 1994 ford mustang cobra
relays are normally in the fuse panel on the left side of dash by knee.
Fuses and Circuit Breakers Location and Values
NOTE: The headlamp switch (11654) has an integral 20-amp circuit breaker.
  • The combination instrument panel fuse and circuit breaker panel contains most of the fuses and circuit breakers used in the system.
  • The fuses and circuit breakers are color-coded by amp rating.
  • The locations and values of the fuses and circuit breakers not contained in the panels are shown in the following chart.
Circuit Circuit Protection and Rating Location Headlamps and High Beam Indicator 20 Amp. CB Integral with Lighting Switch Heated Back Window 16 GA Fuse Link Engine Compartment Power Windows, Power Seat, Power Door Locks 20 Amp. CB Starter Motor Relay Load Circuit Fuse Link In Harness Engine Compartment Lamp Fuse Link In Harness Convertible Top 25 Amp. CB Lower Instrument Panel-Reinforcement
Cavity Number Fuse Rating Color Circuit Protected A 40 Amp Orange
  • Ignition Switch
B 40 Amp Orange
  • Ignition Switch
C 40 Amp Orange
  • Ignition Switch
D 50 Amp Red
  • Headlamp Switch
  • Instrument Panel Fuses 4, 8 and 16
  • Instrument Panel Circuit Breaker 12
E 20 Amp Light Green
  • PCM
  • Fuel Pump
  • HO2S (3.8L)
  • Canister Purge Solenoid
  • EVR Solenoid
  • Ignition Control Module (3.8L)
  • IAC Solenoid
  • Fuel Injector
  • Automatic Transmission
  • Camshaft Position Sensor (3.8L)
  • MAF Sensor
F 40 Amp Orange
  • Heated Back Window
G 20 Amp Yellow
  • Fuel Pump
H 60 Amp Blue
  • Fan Control
J — — Not Used K 10 Amp Blue
  • Anti-Lock Brake Control Module
L 20 Amp Red
  • Fan Control Monitor (PCM)
M 25 Amp Yellow
  • Horn
  • Foglamps
  • Daytime Running Lights Control Module
N 25 Amp Clear
  • Fuses 5 and 9
P 20 Amp Clear
  • Radio Amplifier
Q 20 Amp Yellow
  • Generator
S 30 Amp Yellow
  • Convertible Top Motor
T 60 Amp —
  • ABS
May 14, 2009 | 1994 Ford Mustang
Hobart 20 quart mixer
Hi im a service tech for hobart.I cant give service manuals out because i could lose my job but i can step you thru your problem with the mixer,let me know.
Aug 21, 2008 | Hobart A200 Stand Mixer
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
