Question about Kenmore Washing Machines
ERROR CODE READ OUT LE ON MY KENMORE FRIDGE - Kenmore Washing Machines
2 Suggested Answers
SOURCE: STARTS AND STOPS WITH ERROR CODE LE
Ok, Same problem where it would start. Then it would seem to pump out the old water for a few minutes. Then stop with the LE error. My serial number was 712 and below as mentioned above. If this happens, take the time to check the manual and remove the door cover. It has about 6 screws and you don't have to remove the unit.
Next, pull the door cover away from the door. You will have to unstick the fiberglass like stuff which will stay with the cover. It is sticking to this black tar stuff used for sound damping. The door cover will come free revealing this massive bunch of wires.
Don't be intimidated with the wirss. Trace the wires and find only the ones "stuck" into that black tar. The tar stuff melts the shielding on the wires and corrodes the wires. I found 2 wires melted and shorted.
I pulled out the wires, stripped and reconnected them and my unit tested fine. I rubber taped them back together and put the door back on for a final fix.
Works fine, and saved me $200.00 at least for a service call.
Posted on Mar 28, 2010
Error code LE on Kenmore Elite washer mdl **********0
le code on washer indicate washer over load putting a stange on washer motor .performing a reset on washer will normally resolve this error, if the motor still lock up maybe need replace motor
Dec 23, 2017 | Kenmore Washing Machines
My washing mAchine is broken?
code le = thermal overload protection
let washer stand for 30 minutes then restart
if code persist call for service
page 28 user manual
Sep 27, 2015 | Kenmore Washing Machines
I have frensh door kenmore elite fridge model number 795.72053.110 display error code if someone cane please help me ? ER F5 WHATS THE MEAN .... THANK YOU SO MUCH
faulty cercit board is what you have there sorry to say but it dose happen every so often get in touch with the poeple who you got it off and have the engineer look at it
Jan 22, 2015 | Kenmore Refrigerators
Le error code
The error code "LE" appears after an unsuccessful attempt to fill the drum with water that results in the water level being too low to safely begin cleaning. The product manual suggests calling for service, but there are several steps you can take to try to resolve the issue at home.
Read more: http://www.ehow.com/info_8696564_maytag-washer-repair-code-le.html#ixzz2zXrmqUO5
Apr 21, 2014 | Maytag Neptune MAH5500B Front Load Washer
Have a top loading Kenmore elite high efficiency washer model 796.2927, 2 years old this thanksgiving is showing erroe code LE? what do i do to fix?
On most Kenmore front load washers the LE error indicates a LOCKED MOTOR ERROR. This can be caused by:
  1. Loose motor harness connection.
  2. Failed HALL SENSOR.
  3. Failed STATOR.
  4. Failed ROTOR (cracked magnet).
Nov 06, 2012 | Washing Machines
Cuisiniere Kenmore model# c880634839g2 indique le
Hi
Thanks for using FixYa. F1-E1 error indicates that the control board has gone bad and should be replaced to resolve the issue. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 11, 2010 | Kenmore Ovens
Kenmore ELITE error code ER FF
ER FF error is malfunctioning evaporater fan
hope this helps
Oct 18, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore elite refrigerator error code er if
Bad icemaker fan. When looking in the freezer, its the one on the left.
Sep 01, 2008 | Kenmore 73503 Stainless Steel Bottom...
Washing Machines Logo
29 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
