Question about Sewing Machines
My viking huskystar c20 sees a few stitches stops and beeps. When it stops beeping it will sew a few stitches and stops and beeps
  • Sewing Machines Master
  • 11,518 Answers
The beep is a warning of a problem. If it continues, you should take it for service.
Posted on May 02, 2017
  • 8 Answers
SOURCE: beeps several times and stops sewing.
I had the same problem. Through trial and error, I found the problem was with the thread tension. Usually the thread became wrapped around the spool holder as it was coming off the spool. As you continue to press the pedal, tension is created. When you release the pedal, some slack develops in the threading process and you are able to sew a few more stitches before the beeping starts again. If the thread is caught on the spool holder, simple re-thread the machine.That generally works for me. Also you can try to push to spool holder in as close as possible to the spool pin to alleviate any gaps. If the beeping continues to happen, place you thread in a cup behind the machine and thread as usual. You can also purchase an inexpensive thread holder. I made one out of a wood block and other odds and ends found around the house. Good Luck!
Posted on Apr 27, 2008
  • 110 Answers
SOURCE: My Futura CE-150 beeps and stops sewing after only a few stitches
Look for the buttonhole lever, just in front of the presserlever, on the lefthand side of the machine. Pull it down and push it back to the top. Good Luck
Posted on Jan 10, 2009
SOURCE: machine beeps and stops sewing, no error message displayed
sounds like not through the tension plate (on top) right... rethread and make sure you hold the thread taunt toward you as you putt through top tension... you should hear a slight click and some resistance...
Posted on Apr 17, 2009
  • 152 Answers
SOURCE: I have a Huskystar C20 sewing machine and the
Take off the needle plate. There is a bracket near the front right area of the bobbin case. It is the position bracket that supports the case. First smooth the case of any rough edges, the put it in place and loosen the screw of the position bracket and align it in an area that will keep the case from spinning. There should be about 0.5mm of distance available when you use your finger and push the case from left to right, between the case and the bracket. Remember that the thread flows through this area, the case is held in place by the bracket but not tightly.
Posted on Nov 21, 2009
  • 48 Answers
SOURCE: singer futura beeping every 8 stitches can you
Make sure your thread goes under the plate of the carrousel. If not the machine think is not threaded and it beeps. Thread the machine with your left hand and Pull the thread with your other hand to make sure it "clicks" to every part of the machine.
Another important detail is to add thread nets to your spool. After some used the tension of the machine is affected and the nets help the slippery thread to be pulled by the machine correctly and avoiding the beeping.
Posted on Feb 19, 2010
The User Manual does not have a complete stitch guide. Does my Huskystar 207 have a stretch stich?
FWIW, a stretch stitch is simply a stitch that stitches forward a few stitches and then reverses for a couple and then stitches forward again. Having had a machine with a stretch stitch, I found that using a zig-zag is just as effective and uses much less thread as well as less time at the machine. If the fabric is very stretchy, you can merely decrease the stitch length and increase the stitch width to give the stitch enough space to expand with the fabric without popping.
Viking Huskystar 207 Manuals
Jun 22, 2017 | Sewing Machines
Sews about 5 stitches then stops and beeps. stitches look fine, just will not keep sewing
count the beeps and refer to the owners manaul as for troublshooting tips
Dec 03, 2013 | Singer 8780 Sewing Machine
Singer curvy beeps twice and quits sewing
I have the same problem and no any solution, someone can help, please.
Mar 05, 2013 | Singer Curvy 8770 Electronic Sewing...
Huskystar C20 lights up but doesn't work
sounds like circuit board has gone bad. If you are the original owner and purchased from an authorized Husqvarna Viking dealer it may still be under warranty. There is a 1 year warranty from date of purchase. Contact your local authorized Husqvarna Viking dealer for service or have them send it to Husqvarna Viking (SVP) Technical Service Department for repair. You can find authorized dealers near you from the Husqvarna Viking website -
Good luck.
Aug 31, 2009 | Husqvarna Viking 1
Jan 10, 2009 | Singer CE-200 Quantum Futura Computerized...
Singer Confidence 7470 does 3-4 stitches, then beeps and stops
ring up or go to where you bought it from. They should be able to tell you.
Sep 13, 2008 | Singer 7462 Mechanical Sewing Machine
Sewing Machines Logo
81 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
