Question about Cameras
Cm918t ac adapter
Need ac adapter for camera
3 Suggested Answers
SOURCE: can not find a 3.3 ac adapter for my camera
i had the same problem. still haven't found a charger and my cam drains every battery i put in. So, i just went and bought a rechargeable batteries and charger set at office depot about 30 dollars. 4 batteries plus home and car charger cord,
Posted on May 01, 2009
  • 16 Answers
SOURCE: batteries AND ac adapter?
Make sure the ac adaptor ius the right polarity for the camera, negative outside plug and positive centre,also make sure the voltage output of the charger is correct 5 volts dc.You do not need batteries as well as the charger.
Posted on Feb 19, 2010
What comes with a "astak cm918t night vision security camera"? How do I and what does it hook up to?
If there is a place for an antenna then it is wireless. You can use any computer monitor, doesn't have to be anything specially made for it. You will however need the wireless receiver and you will still need power to the camera. On top of that you will need a DVR for recording unless you have no intent of recording then you can hook it to the monitor with will take a converter to match the inputs properly.
Sep 02, 2014 | Astak Home Security
Can I recharge V1073 Kodak digital camera by putting USB plug in computer or do I have to have an AC adapter to charge it?
This camera can be charge by connecting to a computer USB port so no need for you to use AC adapter to charge it, but its stll handy that you have a AC adapter just in case.
Apr 17, 2011 | Kodak EasyShare V1073 Digital Camera
Lost my ac dc adapter need new one for rca small wonder camcorder
You can try www.ebay.com. I found the following AC adapter for the RCA Small Wonder camcorder:
http://cgi.ebay.com/RCA-EZ209HD-Small-Wonder-camera-CHARGER-AC-ADAPTER-/140516900106?pt=Batteries_Chargers&hash=item20b775bd0a#ht_1469wt_723
Mar 01, 2011 | Cameras
My Kodak Easyshare V1233 will only power up when plugged into the wall charger. Even after staying on the charger it will not power on unless plugged in.
Kodak has 3 types of charger that can be connected to a wall socket
USB AC Adapter - is especially useful when traveling, away from your computer, or just plain on-the-go. Connect your camera's USB cable to the adapter and plug it into a wall outlet to conveniently charge your camera.
5V AC Adapter - Provides in-camera charging for all KODAK EASYSHARE M and V Series Digital Cameras
Input: AC 100-240 V 50/60 Hz Output : DC 5.0 V
3V AC Adapter - Provides direct power to your camera but it will not charge the camera battery
Input: AC 100-240 V 50/60 Hz Output : DC 3.0 V
* You need to check the type of adapter your using. If your using the 5V AC adapter or USB adapter and the camera won't charge the battery contact kodak support line 1 800 235 6325 (23KODAK) for possible repair.
Nov 16, 2009 | Kodak Easyshare V1233 12.1MP Digital...
The on off button is stuck in. is there anything you can do or do i just buy a new one.
Reset the camera
  1. Turn off the camera, if possible.
  2. If an SD memory card is installed, remove the card.
  3. Remove power from the camera as described below:
    • If you are using only batteries for power, open the battery/memory card door and remove both batteries.
    • If you are using only the HP AC power adapter, disconnect it from the camera.
    • If you are using both batteries and the HP AC power adapter, remove both batteries and the power adapter.
  4. Wait for 15 seconds. Then reinsert the batteries and close the battery/memory card door or reconnect the HP AC power adapter to the camera. If you are using both batteries and AC power, try each method separately.
Turn the camera on and off. If the issues is not resolved do the following
Connect the camera to the optional AC power supply
  1. Connect the camera to the optional AC power supply. Ensure that the AC power supply is connected to a working power outlet.
  2. Try turning the camera on.
  • If the issue is resolved , you do not need to continue with the rest of the instructions in this document.
If the is not resolved ,then repeat setps 1 to 4 abiove but remove the batteries and keep the AC power adapter connected.
Oct 14, 2009 | HP Photosmart M425 Digital Camera
Lost ac power adapter ac cord panasonic sdr-s7 camcorder
Go to Radio Shack, bring your camera, and they will sell you an AC adapter part number: 273-1696 for $30.
May 05, 2009 | Panasonic SDR-S7K Flash Media Camcorder
Batteries AND ac adapter?
Sep 04, 2008 | Toshiba PDR-M60 Digital Camera
AC adapter supplied by a third party
No, Minolta cannot guarantee the compatibility of any third party AC Adapters. We recommend the use of Minolta AC Adapters, AC-1L, and AC-2L. Any damage caused to the camera as a result of use of a third party AC Adapter may void your warranty.
Sep 19, 2005 | Konica Minolta DiMAGE E201 Digital Camera
DiMAGE E201 overseas?
Yes. When using an AC adapter, please use the one suitable for the voltage level of your destination country. North America, Taiwan: AC adapter AC-1L; Europe (except UK) and Singapore: AC adapter AC-2L; UK and Hong Kong: AC adapter AC-2L; Japan: AC adapter AC-1L. You may have to switch video output mode between PAL and NTSC to view images on the television.
AC adapters
You will definitely want an AC adapter for your camera. You won't want to be tethered to an electrical cord while taking pictures, but when it comes time to edit the pictures stored on your memory card(s) or to download your photos onto a computer, you'll find the job much easier if you're running the camera via an AC adapter. Without the continuous power of an adapter, you'll burn through your batteries.
Sep 08, 2005 | HP Photosmart 945 Digital Camera
Cameras Logo
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
