My tv keeps going into the different sources, i.e.; AV2, DVD, etc while I am watching a tv show. At times I cannot shut tv off & have to unplug it. What can I do to keep it from doing this?
  • 5 Answers
Have you changed any light bulbs in the area or added any other IR ( infrared) operated equipment ?
it sounds strange but it is possible that you are getting bad IR information generated by devices IE compact fluorescent or LED lamps also from the sun or other elecronics.
try turning off the lights and or blocking out the sun etc.
see if you remote and or TV stops giving you issues
Posted on May 02, 2017
4 Suggested Answers
  • 4 Answers
SOURCE: The source keeps changing automatically
this does seem to be a heat issue,
Posted on Nov 28, 2007
  • 11800 Answers
SOURCE: While watching a DVD on
A wireless device never works continuously, it sends and receives the data in bursts / packets , and the HDMI will follow this pattern. In between them the system sits practically idle. If the time between the bursts is too long the device might think that the HDMI cable has been disconnected and switch to the next available connector - AV2.
Since this happens while you are using it correctly (the cables are firmly inserted) with a bandwidth demanding signal like DVD then your unit is defective and it should be replaced.
But, unless your tv is in a place where it's absolutely impossible to get a HDMI cable directly to the tv, you should just get rid of it and get your money back - a direct HDMI link will provide you with a better image and an easier setup: with this device you will not be able to add a home theater to your tv. In my opinion this is a $300 device that nobody really needs, it's just an unnecessary gimmick.
Posted on Mar 11, 2011
  • 49208 Answers
SOURCE: I have my TV on av2 to watch DVD movies keep saying retrieving data
try switching it to a different input .
Posted on Nov 10, 2015
I moved my vhs dvd combo and it does not show on tv altho it says play
make sure that you have selected the right input from aerial to dvd
AV1, AV2 AV3 etc
Oct 24, 2015 | Televison & Video
I can't get the tv to program the cable connection to watch cable
use a scart lead to connect your cable tv box. then on your tv remote press the "source" button or press the "AV" button, you mainly have the options to choose AV1 and AV2 (AV2 is only available if your tv has 2 scart sockets) make sure the box is on and select any AV channel, you should now have cable tv.
Jul 17, 2012 | Disney Princess TV/DVD Combo
How to use the video source to watch a movie when i have time warner cable service
are you talking about VCR / DVD or DVR source. for VCR or DVD your connection shall be for VCR, cable out from the TW box to VCR in and VCR out to TV (VCR ch selector and TV must be set to ch 3)......... DVD connection out from DVD to TV's yellow/white/red (digital in on TV), to view dvd using remote change source to the digital source (av1 or av2)... for the DVR you must call TW to make sure your box is set up to record and view....
May 07, 2011 | Televison & Video
Unable 2 watch dishtv in Benq LCD SD3731 with DVD cbl plugged in
The S_Video connection has precedence (most likely named AV1) over the RCA/composite one (better image quality - usually named AV2) so it will be automatically selected. If you want to view thru AV2 input you will have to select it manually every time you want it.
Jan 07, 2010 | Televison & Video
How do you access the video mode in order to watch a movie on a dvd play or play a video game?
Hi, usually the function button on the remote control to select the input mode / source is a circle or a square with an arrow pointing into it (see below).
b74fea7.jpg Each time you press this, the next available source is selected in a set order, e.g. TV / AV1 / AV2 / HDMI / PC
If using a SCART interface for your DVD player, the TV should automatically switch to the DVD source when you activate the DVD player (take it out of standby).
Nov 26, 2009 | Sylvania Televison & Video
I have an external DVD Recorder / Player attached at my TV via AV1 and an external DVB digital TV box linked to AV2. Both external units are linked togerther to enable direct recording from the external...
I have a LG tv set. When i press the tv/av button on the remote my tv shows av1, av2 earlier but now it is showing only av. So i am unable to watch my dvd player. Need help.
Jul 04, 2009 | LG 37LG30 37 in. LCD HDTV
Blue screen
At least a couple of possibilities, check the yellow video cable that runs from the VCR to the TV, is it plugged into the side of the combo unit that says vcr?
Is your TV on the right source? You could have plugged the audio into say AV2 and the video into AV1, causing a mismatch. Make sure the yellow, red, and white are all plugged into one input section on the TV (AV1, AV2, Video 1, Video 2, etc).
Dec 09, 2008 | Philips MRV700VR DVD Recorder/VCR
Magnavox 42 inch LCD TV
I was having the same problem. On my tv it was caused by a loose or faulty interface chip. I solved this on my television by opening the case and unplugging the circuit board at the top center where the menu and channel buttons are located. I've been running the tv for about a week and have had no more problems.
Jan 06, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
