I replace a pc board wizard 2012 how do you re program energiser
THE RELAY ON THE PRINTED CIRCUIT BOARD DOES NOT SEEM TO BE ENERGISING.CAN THIS BE REPLACED AND WHERE CAN I GET ONE
I pull them off other boards. Rarely do they go bad. It is usually what turns them on and off that goes bad. It could be many things on the board. No power, no ground, bad chip, or a bad resistor/capacitor that supports the chip.
May 15, 2016 | Cars & Trucks
Hello My 60PK550 TV started to turn itself of every 5-10 minutes, I switched it of at the power point and waited, now when it is plugged in and turned on at the power point it immediately tries to turn...
check first the psu unplugging the Y-sus from it if the voltages stay on then you have a Y-sus failure if the psu keeps closing then its most likely the psu itself or your main board
Aug 16, 2014 | LG 60PK550 TV
Error code 136 showing
Just repaired code 136 on a 2013 chevy Orlando and it was a detached ground wire on one of the starter bolts causing the fusebox relays not to energise.
Mar 28, 2014 | 2013 Chevrolet Cruze
I need license key and product key for MS Office 2013
Its illegal for anyone to provide serial keys for programs that have retail value set on them
there are lots of freeware alternative programs available on the internet
http://office.microsoft.com/en-us/sharepoint-workspace-help/redir/HA102434987.aspx?CTT=3
http://www.majorgeeks.com/OpenOffice.org_For_Windows_d3461.html
OpenOffice.org is a free, Open Source alternative to MS Office with a Word compatible word processor, a complete Excel compatible spread sheet program and a Power Point like presentation software and drawing program and also allows to save to PDF File
http://download.cnet.com/Kingsoft-Office-2012/3000-18483_4-75563178.html?part=dl-&subj=dl&tag=button
Kingsoft Office Suite Free 2012
Kingsoft Office Suite Free 2012 is perhaps the most versatile free office suite, which includes free word processor, spreadsheet program and presentation maker.
If the product has been activated it should be on your computer
http://download.cnet.com/%7Bvalue=http://www.download.com/keyfinder-thing/3000-2094_4-10491989.html
Finding lost application install keys is quick and simple with this handy executable, a complete rewrite of a well-received earlier version.
Keyfinder Thing's simple, easy-to-understand interface has Wizard-like efficiency.
This application quickly scans your system registry for 90 supported software titles and displays product names and icons in the result window.
Single-button clicks copy all keys to either a text or HTML file.
It could read something like this
FCMXC-RDWMP-RFGVD-8TGPD-VQQ2X
If its not there there are freeware alternatives
OpenOffice.org is a free, Open Source alternative to MS Office with a Word compatible word processor, a complete Excel compatible spread sheet program and a Power Point likepresentation software and drawing program and also allows to save to PDF File.
Nov 10, 2013 | Microsoft Office Home & Student 2013 -...
How can i copy Norton Antivirus 2012 CD on my computer
Dear profgsm,
You can Use the Print Screen Sys Button in your Key Board and Paste it in Paintbrush or Any Photo Editor Program.Save it as your Desire Extension.
You can Save it for your Future Requirement.
Thank you
Oct 26, 2012 | Norton Antivirus 2012 1-PC [Boxed CD]
It says XP Antispyware 2012 - unregistered version --how do I get rid of it.?
To uninstall this program, go to Control Panel - Add/Remove program and select this Antispyware 2012 to remove.
Dec 11, 2011 | Acer Aspire One Netbook 8.9" Notebook
How to find my pc motherboard configuration
Run this program http://www.cpuid.com/softwares/pc-wizard.html
Jul 12, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
I can't open mastercook version 3 on PC
Compatibility Wizard
1. Open the Program Compatibility Wizard by clicking the Start button , clicking Control Panel, clicking Programs, and then clicking Use an older program with this version of Windows.
2. Follow the instructions in the wizard.
If you cannot install a program, insert the installation disc for the program and, using the wizard, browse to the program's setup file, usually called Setup.exe, Install.exe, or something similar. The wizard is not designed to work on programs that have an .msi file name extension.
To change compatibility settings manually for a program, right-click the icon for the program, click Properties, and then click the Compatibility tab.
Jan 03, 2010 | Sierra MasterCook Deluxe Low Carb...
I have a HVAC unit made by Inter-City Products. I
In general, when more than one heat strip is present, one is used as primary heat, and the second one comes on if the primary does not prevent the temp from falling.
Another set up is, yes there can be a time delay in the system. it usually takes a few minutes for the second set to energize.
Since you did not state if this is a heat pump, i'm limited in my response at this time.
Hope this helps.
Dec 31, 2009 | Heating & Cooling
Motherboard
There is a great program calledpc wizard 2008. this software helps identify your motherboard, and best of all its free. It has no spyware no spyware, and it has an eay to use interface. Heres the link to download the software good luck! http://www.softpedia.com/get/System/System-Info/PC-Wizard-Release.shtml
Dec 16, 2007 | E-Machines eMachines Desktop PC
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
