Question about Power Up Audio Players & Recorders
Pc will not power up all external fuses checked , is there an internal fuse that could be stopping it powering on?
    New Friend:
  • 62 Answers
Reset the system. Take all cords off tower. Then re hook up. Power system has a default that resets when all connections are removed ALL
Posted on May 03, 2017
  • Power Up Master
  • 5,391 Answers
Generally a fault in the power supply will stop it powering up. If the power supply is a separate unit order a replacement. You can then if you wish get the old one repaired, or fix it yourself if you can.
Kef htb2 subwoofer not working plug fuse ok sub fuse ok is there an internal fuse
If you have external fuse there will be none internally. Chances are you have blown the amp if power is confirmed to be getting into the unit and there is no sound.
Sep 16, 2017 | KEF Audio Players & Recorders
Model Yamaha ME-50 no power
John
With AC power off.
Use a meter (on Ohms scale) to check internal fuse for blown (open) fuse.
If you feel qualified & safe with AC Power On.
Check input to internal power supply on AC Scale (Caution when AC is on) for volts in.
Use meter on internal Power Supply for "probably" DC volts leaving internal Power Supply electronics to power the rest of the electronic circuits.
Switch mode power supplies can break down. They stop doing their high frequency switching so they don't convert AC to DC.
If this P/Sup is a separate box or circuit board, inside the unit, then it can have a part number & be replaced.
Good Luck
Jul 14, 2014 | Yamaha Music
Why did my micro stop working?
I guess the main plug fuse does not blow for the same reason it does not blow and you can wreck a PC, although not certain why that is. I have a feeling from past work on a Panasonic that there is an internal fuse as well. This may have blown with the power surge.
Jul 07, 2014 | Panasonic Nn-sn797s Countertop Microwave...
Jamo sub 250
Internal power? Check fuses. No fuses? Disassemble and check Power supply if it is internal. If it is external, check power supply with meter.;.
Apr 30, 2013 | Jamo SUB 250 Subwoofer
Light not coming on
Is there power at the outlet socket? Check the power cord from the outlet socket to the amp.If the power indication light on the amp does come on the you will need to check the internal fuses.Some models have an external fuse located on the back panel
Apr 09, 2013 | Dual XPE2700 400w 2ch bridgeable amp
No power or functions of any kind.
Check the external fuse / circuit breaker first.
IF that is OK, then it's possible an internal fuse has blown. These can be replaced but it should only be attempted if you are confident enough to be able to discharge and ground the main capacitor before working on the device.
Mar 23, 2010 | Whirlpool GH4155XP Microwave Oven
Suddenly power goes off. will not restart,
If there is no external fuse at the back panel, then there must be an internal fuse. I assume you tried another outlet in your home.
Nov 30, 2009 | Mitsubishi M-VR700
Our Image 19.0 R treadmill just stopped in the middle of my workout. We tried the reset switch and made sure the outlet is working, but it won't start.
remove power socket from supply outlet,check external fuses or overload reset trips
if still no results open covers and check internal fuses if you think you are competenet to do so otherwise DO NOT IF THINK OF IT.
if a blown fuse is found try to relace with an exact type and value
close back covers and re try
call technical assistance if still no results
Jul 22, 2009 | Blaze Exercise & Fitness
Infinity Interlude IL120s Powered Subwoofer (home) will not power
Some of these Infinity Amps have an Internal Glass Fuse. Open the Case and Check for this Fuse. Please Rate My Response! Thanks!
Feb 03, 2009 | Infinity 7540A Car Audio Amplifier
No power
Me! Small world! Fluffcat1.
Jul 10, 2007 | Philips CDR770 CD Recorder
26 people viewed this question
Top Power Up Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Power Up Audio Player and Recorder Expert? Answer questions, earn points and help others
