HOW TO CONVERT SF TO LF? - Washing Machines
How to clear error 6000 canon410
Line Feed error or Error Code 6000
Condition: An error occurred in the LF encoder signal.
Problems and Solutions:
  • Smearing or scratches on the LF / EJ slit film
    - clean the LF / EJ slit film.
  • Foreign material or paper debris in the LF drive;
    - remove foreign material.
  • If other solution fail, replace one off the following
    - LF / EJ slit film
    - LF / EJ timing sensor unit
    - Paper feed roller unit
    - Logic board
    - Paper feed motor
Aug 03, 2015 | Canon Pixma MX410 All-In-One Printer
I have a canon pixma mg5150 Every time i turn it on it comes up with printer error 6000, I have checked for paper jams no paper jams and still not working, what to do?
Please check
1. Any foreign objects or materials in the LF Drive (gear)
2.Carriage Unit
3.Logic Board ASSY
4.Smearing, scratches or conditions of the LF slit disk
5.LF motor harness condition
6.Deformation or damage to the LF roller and LF drive gears.
Apr 13, 2013 | Cannon Office Equipment & Supplies
2000 CHEVY IMPALA AIR BAG LIGHT ON
  • B0041
CIRCUIT DESCRIPTION
The inflatable restraint side impact module-LF deployment loop consists of the inflatable restraint side impact module-LF, the inflatable restraint side impact module wiring harness, and the side impact module-LF high and low circuits. A shorting bar used within the side impact module-LF connector shorts together the side impact module-LF high and low circuits when the connector is disconnected. This helps to prevent unwanted deployment of the inflator module during servicing. During a side or frontal crash of sufficient force the inflatable restraint Sensing and Diagnostic Module (SDM) allows current to flow through the deployment loop in order to deploy the side impact module-LF. When the ignition is turned ON, the SDM performs continuous diagnostic tests on the deployment loops to check for proper circuit continuity and for shorts to ground or voltage. If a malfunction is detected, a Diagnostic Trouble Code (DTC) will be stored in memory.
CONDITIONS FOR RUNNING THE DTC
Ignition 1 voltage is within the normal operating voltage range.
CONDITIONS FOR SETTING THE DTC
  • DTC B0040 will set when the side impact module-LF deployment loop resistance is less than 1.3 ohms for 500 milliseconds .
  • DTC B0041 will set when one of the following conditions occurs:
  • Side impact module-LF high circuit is less than 2.4 volts and the side impact module-LF deployment loop is more than 6 ohms for 500 milliseconds .
  • Side impact module-LF deployment loop resistance is more than 4.8 ohms for 500 milliseconds .
  • DTC B0045 will set when one of the following conditions occur:
  • Side impact module-LF high and/or low circuits is short to ground or short to voltage for 500 milliseconds .
  • Side impact module-LF high circuit is less than 2.4 volts and side impact module-LF deployment loop resistance is less than 6 ohms for 500 milliseconds .
ACTION TAKEN WHEN THE DTC SETS
The SDM commands the AIR BAG indicator ON via Class 2 serial data.
CONDITIONS FOR CLEARING THE DTC
  • The condition responsible for setting the DTC no longer exists and the scan tool Clear DTCs function is used.
  • A history DTC will clear once 255 malfunction free ignition cycles have occurred.
DIAGNOSTIC AIDS
The following are possible causes of the malfunction:
  • A short between the side impact module-LF high and low circuits
  • An open or a high resistance in the side impact module-LF high or low circuits
  • A short to ground or a short to voltage in the side impact module-LF high or low circuits
  • The side impact module-LF connector
  • The SDM connector
  • A malfunctioning side impact module-LF
  • A malfunctioning SDM
Jan 29, 2013 | 2000 Chevrolet Impala
Idler arm LF,idler bracket LF,pitman arm LF,tie rod sleeve LF, inner tie rod LF, tie rod end LF, need to repair
you will need a pitman arm puller, tie rod separator and a good set sockets(6 point preffered)and some penetrating oil, measure all distances between points before removal,and get the vehicle aligned
Dec 01, 2010 | 1995 Chevrolet Tahoe
Batch convert image files, that keeps a folder tree?
If your not using version 2.20 then upgrade because there is no limit according to the manufacturer.
Dec 14, 2009 | Microsoft Windows XP Home Edition
WHAT IS THE PROBLEM WHEN YOU GET THE LF ON THE
LF Long Fill
If the water fill time exceeds ten minutes, the water valves are turned off and LF is flashed.
Oct 24, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Need instructions on how to transfer a file from the PC to the Mainframe. Everything I have found leaves out a step or discribes it in developer language.
What type of mainframe are you referring to and what type of file do you want to transfer? How large is it, etc. Typically you would use ftp to transfer the file. If the mainframe is a IBM/Hitatchi type, you may need to convert the file to EBCEDIC. More likely, the mainframe is a type of Unix machine. It that case you probably want to send the file through ftp as ASCII. That should convert the line ending characters from CR/LF to LF. There are other transfer methods, but ftp is the easiest.
Sep 17, 2009 | Microsoft Windows XP Professional for PC
Door on GE JTP18 oven does not close tightly.
Not sure if this link will work, but give this a try
http://claimworks.servicepower.com/mfgltr/I404/RC/Wall%20Oven%20Repair%2011-4.pdf
There is a recall on the oven door for a few models
Safety Recall GE Wall Oven Models Included in the Recall
Brand Model Numbers Must Begin With Serial Numbers Must Begin With GE® and GE Profile™ JCT915, JT912, JT915, JT952, JT955, JT965, JT980*, JTP20, JTP25, JTP28, JTP48, JTP50, JTP86 TD, VD, ZD, AF, DF, FF, GF, HF, LF, MF, RF, SF, TF, VF, ZF GE Monogram® ZET3058, ZET938, ZET958 TD, VD, ZD, AF, DF, FF, GF, HF, LF, MF, RF, SF, TF, VF, ZF Kenmore
(All model numbers start with 911) 4771, 4775, 4781, 4904, 4905, 4923*
* Lower Oven Only 2T, 2V, 2Z, 3A, 3D, 3F, 3G, 3H, 3L, 3M, 3R, 3S, 3T, 3V, 3Z
and that link shows the door and hinge. Recall info at
http://www.geappliances.com/products/recall/wall_oven_08/
May 31, 2009 | GE JTP20 Electric Single Oven
Have a Lutron Skylark SF-10P need to wire to existing 3 wires
You have to have a special ballast on the light to dim fluorescent light fixtures. You also have to have a special dimmer.
Nov 28, 2008 | AMS Lutron SFSQ-LF Skylark Slide-to-Off...
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
