Question about Chi Mei Corporation A190A2 LCD Monitor
Chi mei a190a2-h01
Hi,can you give me a schematic or block diagra of lcd monitor chi mei a190a2-h01..thanks!!!
  • Fran Bednar
    Fran Bednar May 11, 2010
    Is that the monitor number or the actual lcd number ? What is the lcd screen doing wrong ?
pushpdeep17
  • 47 Answers
SOURCE: Chi Mei corporation 221D monitor problem no power
well i want to tell u that is a very common scenario u just replace the fuse and sometimes due to power low and high the fuse gets blown and u might also wanna check ur power chord.
Posted on Oct 24, 2008
Benimur
  • 6966 Answers
SOURCE: no display light
For a Samsung 540N, pls try here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 10, 2008
pravinbhavsa
  • 348 Answers
SOURCE: After Monitor is ON, A Sound like chi chi coming out.
yes you first check the capacitor in primary filter 150microfarad/400v if faulty then replace it if not then check boost capacitor near eht (big capacitor near yoke connecter)if faulty replace it
Posted on Nov 20, 2008
georlin_cip
  • 107 Answers
SOURCE: The backlight is out on my A201P2 monitor.
Yes it can be, I suggest using that specific model number and brand name and type that in on a google product search, it surprisingly gives you more than you would think. http://www.froogle.com. After that I would call a technician who is experienced with those, since the cathode lights are way inside, the screen would have to be completely taken a part.
Posted on Oct 31, 2009
SOURCE: Acer AL 1717B LCD Monitor Schematic Diagrams
lcd no brightness
Posted on Jan 17, 2010
Chi mei monitor has lost its resolution
Monitor now has a mind of its own and is fugar for all intents and purposes unless you can use it the way it is
Aug 31, 2017 | Chi Mei Corporation CMV-T39D Monitor
Where can I download an English manual for a CHIMEI - CMV633A monitor. The ones on their site are only in Chinese. Thank You
try www.chimei.com.tw then you click on the English. it will give you the English version.hope this helps.or try www.scribd.com or www.w9drugs.org
May 07, 2011 | Chi Mei Corporation CMV-633A LCD Monitor
Turn on monitor,comes on 3 sec.and goes blank. rljchromedome@aol.com
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Apr 24, 2011 | Chi Mei Corporation A190A2 LCD Monitor
I already change the burst capacitor for my LCD power supply but still not working and again the smell come out. please help...
The capacitor had bursted and so it is important to clean off all the electrolytes on the power board. Also there can be faulty components on the power supply that would have failed along.
It is important to clean or use a soldering iron on the components and if you hear a steaming noise then there is liquid at the base of all components which must be cleaned , even removing and re-soldering the components.
Please check the link for SMPS tips:
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Mar 30, 2011 | Chi Mei Corporation A190A2 LCD Monitor
Off automatically while work
  • First try to check the settings of the monitor make sure it is not set to automatically power off while not using it.
  • Secondly make sure that the cable for the monitor are properly connected and always check the voltage regulator if the fuse is still in good shape.
If you have questions feel free to reply to this solution. Thank you.
Feb 11, 2011 | Chi Mei Corporation A190A2 LCD Monitor
Button does not work off
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
Apr 16, 2010 | Chi Mei Corporation A190A2 LCD Monitor
The pwr light blinks and no picture. I hear a faint vibrating noise.
You need to open it up nad inspect the caps, look for caps with bulging top or seal, post back what you find so we can guide you further, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Mar 11, 2010 | Chi Mei Corporation A190A2 LCD Monitor
Hi! my problem is... whenever i look in my monitor sideways, there's a dark portions in the sides... just like in laptops.. is there anything i can do to fix it? thanks!
Hi It is completely normal for some monitors to do this, mainly with older ones, but there is no way of changing this without changing the monitor itself.
Jan 24, 2010 | Chi Mei Corporation CT522A 15" LCD Monitor
Chi Mei Corporation A190A2 LCD Monitor Logo
911 people viewed this question
Top Chi Mei Corporation Computers & Internet Experts
Jax Planet
Jax Planet
richie46
ray gallant
Are you a Chi Mei Corporation Computer and Internet Expert? Answer questions, earn points and help others
