Question about PRINTER Office Equipment & Supplies
How to switch from photocopy to print from computer LC985
Printer is set for photocopying how do i switch it to print from my computer
    Master:
  • 412 Answers
You don't need to do anything at the printer. How is your computer connected to the printer? Most reliable method would be a USB printer cable. Do you have a driver for the printer installed on your computer? It should have come with the printer on a disk. Otherwise you can go to the Brother website, click on Support and find a driver for your computer. When the driver is installed and the printer is properly connected, the printer should show up as a selection when you click "Print" on a document on your computer.
Posted on May 03, 2017
How do i connect Konica Minolta photocopy Biz211 to a computer for network printing?
First of all, make sure that there is network interface card is installed in your photocopier.
If yes, then connect the network cable to the machine.
Then from the control panel of machine, Go to "Administrator Mode" Administrator Setting.
Press--Utility---then select "Admin Setting"
Now enter Admin Password=000000, press "OK"
Now go to "Network Settings" and Assign the IP address to the machine.
After assigning the IP address, install the relevant printer driver, (compatible with your operating system) You can also download the drivers from the internet.
During the installation of drivers, select "TCP/IP Port" This port is used for network printing.Enter the IP address of Photocopier in this port number.
After finishing the installation, your machine is ready for printing.
If you are still facing difficulty at any point, feel free to ask any time.
Jul 01, 2015 | Konica Minolta bizhub Office Equipment &...
How do I print on A4 envelope with Canon ir 4080i photocopy/printer machine?
in printer just put your envelope portrait position, then set your paper setting into envelope size in your laptop or PC and just print it
in photocopy machine just adjust the input tray into envelope size than put envelope printed face up, and just print it
Feb 18, 2015 | Canon Office Equipment & Supplies
Toshiba estudio 255 Cannot usefunctions
you must connect the machine with you're computer.you want the fax you must check the you're photocopy machine have a fax board.you want the scan & printing connect the photocopy machine to the computer.(network cable)
Jan 27, 2014 | Toshiba estudio 255 Copier
Prints photocopies fine but pages of text have lines missing
Run a nozzle check to see if all inks printing out correctly.
Apr 11, 2010 | Epson Stylus DX6050 All-In-One InkJet...
Printer does not print good copy after doing several head cleaning operations and having enough ink in cartridges.
If the print has horizontal lines of 'missing print' do three head cleqans don't move the printer or switch it off, now leave it overnight - letting the head soak in fresh ink- in the morning, do one more head clean and then print the nozzle check.If it's poor photocopying it is most probably because the print quality for photocopy is set to a low setting. The manual will explain how to change photocopy print quality. Hope this helps
Feb 20, 2010 | Epson Stylus CX6600 All-In-One InkJet...
Dark background when I photocopy
Well since we know its not the settings in the computer there should be settings on, or for the printer. Im not very familure with your type of printer/scanner but check to see if there is a button that says options or if it has any buttons at all. Repost!!
Jun 15, 2009 | Dell A960 All-In-One InkJet Printer
Lines rule across my print out paper at photocopying mode
Make sure you don't have a scratch on the glass of the scanner. If you have a mark, or scratch that matches the line ruled on your print, then there is your problem.
It;s also possible the scanner is jerking as it goes across the bed, which is causing the line. Is the line solid, dashed, bold, thin or just kinda there?
Mar 14, 2009 | HP DeskJet F380 All-In-One Printer
Printer can't print well
Try this...., ,,,,
reset the settings in the printer and switch off the printer and wait for 5 sec and switch on the printer ur prob will get solved....
Aug 23, 2008 | Samsung CLP 300 Laser Printer
Photocopier prints red
You might be running low on black ink and it's not an item when you print from your computer because the settings you are calling for are different. The computer asks you if you want to print normal...to best, etc.
Apr 25, 2008 | Dell 924 All-in-One InkJet Printer
60 people viewed this question
Top PRINTER Office Equipment & Supplies Experts
Gene
Hardeepak Bhambh
Hardeepak Bhambh
Are you a PRINTER Office Equipment and Supply Expert? Answer questions, earn points and help others
