Question about Campbell Hausfeld Garden
My Campbell Hausfeld pressure washer blows the high-pressure hose off outlet. Could connection parts be of different thread pitch/type ? How hard/expensive to fix or replace a pump outlet ?
  • 8 Answers
SOURCE: Campbell Hausfeld Air Compressor auto shut off switch not working
i have the same one and mine was broken by my kids , i had to replace the entire component, DONT RUN COMPRESSOR with out the regulator working IT CAN EXPLODE IF OVERFILLED,a must fix situation i believe i got mine from sears , a great unit ive used it painting and with many air tools over many years now , well worth fixing mine is a little loud but dependable good luck.
Posted on Mar 15, 2009
  • 384 Answers
SOURCE: PW1345 Campbell Hausfeld Won't run
Got gas?
Posted on Jul 22, 2009
  • 583 Answers
SOURCE: Type of oil for pressure washer pump.
any anti foaming oil ,you can use multi grade but it goes milky with minute air bubbles and gives the appearance of getting water in.most manufacturers recommend anti-foaming oil
Posted on Sep 05, 2009
  • 190 Answers
SOURCE: Can't find a part #
service center, find a part. write inlet outlet valve
Posted on May 15, 2010
  • 420 Answers
Replace the wand (Gun) The valve is not repairable.
Posted on Jun 16, 2010
Hose quik diconect replacement parts
campbell may use a propietary fitting for you to purchase from them try 22 millimeter twist type fitting KARCHER brand uses them they used widely in EUROPE.
Apr 24, 2016 | Campbell Hausfeld 1300 Psi Pressure...
I have a campbell hausfeld 2450 pressure washer with water coming out of a brass hose nozzel right next to where you screw the high pressure to the pump as soon as you turn the water on from the house,...
this is called the chemical injector which enables you to insert the hose for you to dispense the soap and or chemical by utilizing a soap nozzle .apparently inside this barb you will find a ball a spring and a o-ring,find the replacement parts or kit from its manufacturer.finding a plug to replace it is not recommended due to the fact that the pitch of thread is hard to find.replace asap this unit relies on trap pressure to unload.
Aug 04, 2013 | Campbell Hausfeld Garden
For the Campbell Hausfeld 1800 PSI model (PW182500AV), the garden hose connects to the pump inlet on the lower back of the pressure washer. The high pressure hose connects to the high pressure outlet on the lower front of the pressure washer. Here is the operator's manual that will show both connections.
May 18, 2013 | Campbell Hausfeld 1800 PSI Electric...
Where to find replacement carbon brushes Campbell Hausfeld pressure washer pw1350
Parts for Campbell Hausfeld can be found at Campbell Hausfeld does not however, sell motor parts for many of their tools. You would have to call their 800 number and speak with a parts person to determine availability. You may be able to purchase a close match at a local True Value hardware store. They sell a variety of brushes for many major brands of tools. Purchase a slightly larger set of brushes and sand them to size. If the connector is different, cut off the old connector and solder it to the new brush.
Dec 15, 2011 | Campbell Hausfeld Garden
Need the connection for the wand hose to the pump for Blue Max Gasoline High Presssure Washer stock No: PW2200/03435
Your pressure washer is sold under various brand names, however I believe that it is made by campbell hausfeld. Parts are here:
Take a close look at the pump diagram to make sure it looks like yours. Good luck
Nov 10, 2010 | Psi Blue Max 2200 High Pressure Gas Power...
Can't find a part #
May 15, 2010 | Campbell Hausfeld Airless Spray Guns &...
Campbell Hausfeld PW1380 Pump won't run when water hose is connec
Hope this helps. I have the same problem. It's not the switch but the mechanism that slides inside the switch, which activates the switch to go on and off. I fnally found it so hopefully they have the part in stock. It's not a clogged wand trust me I have torn it completley apart and found out it is the mechanism in the switch is plastic and breaks.
May 19, 2009 | Campbell Hausfeld 1,350 Psi Electric...
Garden Logo
Top Campbell Hausfeld Garden Experts
John Trevino
Mike Squire
Are you a Campbell Hausfeld Garden Expert? Answer questions, earn points and help others
