Antique westinghouse refridgerator
Tried to look up my model and cant find anything. Serial # WP203488 Style # 044005 Model # DG8 Unit # ND8
  • 883 Answers
SOURCE: My Dryer wont do anything
check your house wiring circuit breaker
Posted on Jun 01, 2007
SOURCE: White-Westinghouse model la450mxw1 top load capacity in Kg.
I called Frigidaire technical support, they informed me that the capacity is 2.7 c/feet.
Posted on Nov 27, 2008
  • 1136 Answers
SOURCE: glass shelf broken
Hi, there are replacements available. If you get me model#, I can get you part # and I can even order it and ship it to you.
Please let me know if you need more help.
Posted on May 11, 2009
  • 192 Answers
SOURCE: White Westinghouse Model No WTV 11901 television
It sounds like your TV is not equipped with audio/video (A/V) jacks. Many older TVs don't have these. You need to get an RF modulator that will convert the A/V output of the DVD player into a Coaxial cable that you can plug into the back of your TV. I'm including a link to one at This one costs $27.49. You might be able to find a cheaper one at a discount store. You can also use an old VCR if you have one to do this conversion but the connections get a little bit tricky. Plug the A/V outputs of the DVD player into the A/V inputs of the VCR. You'll have to set up the VCR so it knows to use the A/V inputs. Some VCRs have and AUX setting for this. Then connect a coaxial cable from the VCR output to the TV input. You'll have to setup the VCR to send it output to a specific TV channel, usually channel 3 or 4. Then you'll have to set your TV to that channel. I hope this helps you out.
Posted on Nov 16, 2009
  • 1833 Answers
SOURCE: moved into house with westinghouse
This problem can arise due to the following
1. The is not powered on
2. Gas valve is not turned on (for gas oven)
3. Clock is not set.
I am assuming that the first 2 problems are resolve by you already. For clock setting you have follow the following steps.
1. Press the "mode" button until the "clock" indicator begins flashing.
2. Press the - or + buttons to change the time. 5 seconds after the last change, the "clock" indicator will disappear, confirming the time has been set.
I am sure the problem is in clock setting. Please refer to your user manual for other clock settings. Note that without setting the clock properly the oven will not start.
Posted on Aug 12, 2011
I have a singer antique sewing machine where is the model number
If it is an antique Singer, the model number is inclusive in the serial number.
Singer Sewing Machine Company Serial Numbers
Nov 12, 2016 | Singer Sewing Machines
Check the westinghouse web site. Many manufacturers publish user manuals for some products on their company websites..
Nov 13, 2015 | Westinghouse Refrigerators
What year was this model made?
Your unit (B3BV-036K-BB) is a Westinghouse / Nordyne Unit.
Vertical Flow only, 36,000 BTU, 208/230 volts.
You cannot tell the manufacture date from a model number, only from the serial number. Try contacting manufacture with the serial number...
Sep 13, 2014 | Frigidaire Heating & Cooling
Just bought a 1931 Desoto, the serial number on the registration is 3A17410. I can't find anything with that number. Is it possible the number is a body style or engine serial number?
This is way out of my league, but here is some info that might help.
Before 1954 there was no uniform VIN number used in the USA.
In the years leading up to 1931 Chrysler Corp and a few other car companies used a FEDCO plate on the dash or firewall for the serial number ID of the car. The car was registered by this number by some states, and some used the engine number. Starting in 1931 the serial number was changed and moved to the door post. So a 1930 car should not have a plate on the door post.
The engine number was always stamped on the block. Also keep in mind 1931 Chrysler products were carried over into the 1932 model year, including Desoto.
The serial number depended on the make and model unlike cars of today. A series 31 model started with a number 6 or 8, while a series 32 model started with letters like SA or CFS, a series K started with the letter K, and so on. Actual serial numbers were seven digits.
On most models the serial number is also stamped on the frame near the front spring support.
You can do an internet search for DeSoto FEDCO numbers and serial numbers to get a general idea of how the serial numbers were arranged. You can also contact Chrysler Historical Society to see if they have the build card for your car. The build card would have both the original engine number and serial number. There are other resources including the Antique Auto Club of America.
Jan 26, 2014 | Cars & Trucks
Everytime i turn it on the w symbol appears then the screen goes black
Okay this is a power issue, depending on the model of your unit what you may need to replace is ether the power board or just the inverter board. On some of the Westinhouse models the power board and the inverter board are on the same board which is called the LIPS board but this agan is only in some models. What I would recommend doing is to contact the Westinghouse parts department at for some further information, you will need to include contact information along with model # and serial # of your unit.
Jan 13, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
My Dometic trailer refridgerator is warm but freezer is freezing.
Unfortunately, you have a bad cooling unit in your refrigerator. Then ammonia smell means that you have a leak in the unit. TURN THE FRIDGE OFF!!! Do not use the fridge on AC or Gas until you have the cooling unit replaced or buy a new fridge. Depending on the model number and serial number of the fridge, it may be under recall by dometic and you might be able to have it repaired for free. If you will provide me with the model number, serial number and the serial number of the cooling unit (found on the outside of the unit in the fridge compartment, lower tank of cooling unit), I can then tell you the pricing of the repairs or whether it is under recall.
Again, TURN THE FRIDGE OFF and do not use it...RISK OF FIRE!!!!
Hope this helps,
Jul 03, 2009 | Dometic RM2652 Refrigerator
I have a sewing machine from Westinghouse Electric & MTG. It has a pending patent, on one of the plates says 1903-1013 but this particular is pending. The style # is 281650, can you tell me a little...
more examples of desirable and collectible early patented sewing machines, and to get more information on antique sewing machines, please visit our sister website, where we conduct most of our Internet sewing machine sales from.
Mar 17, 2008 | Vacuums
Jun 01, 2007 | Equator ED 510 Venting Clothes Dryer...
Heating & Cooling Logo
29 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
