Question about Homelite Garden
Homelite 26cc string trimmer only a year old , winter inside with Sta-bil in , to start season fresh fuel pre-mixed 50-1fuel , cleaned plug. Won't even try to start. Don't see any spark. .?
    Habit-Forming:
  • 53 Answers
Try adjusting the low idle screw on the side of the carburetor you should see two or three screws one with and "L" low one with an "H" high idle and one for the cable idle stop. Sometimes these get clogged and some are adjusted for high altitude right out of the box. Start with a half turn out see if it starts. If you truly do not get a spark you might have to replace the ignition module. If the screws have a strange looking head on them ( Two cycle carbs often have half moon or other odd shapes try using a bic pen on the screw. Saves you from having to buy a whole set of screwdrivers you will only use once in awhile. Good luck.
Posted on May 02, 2017
My black and decker edger cannot start
Ok, the first thing I check is the exhaust hole in the unit. Spiders and wasps like to build their nest inside the muffler hole. I have had this happen many times. Then you should replace the spark plug every year, as they will corrode when sitting and will not spark when under compression. The next step is to check to see if it is getting fuel. Is the plug wet, pull it out and check it, then check to see that the plug is getting spark, by inserting Phillips head screwdriver into plug wire and hold 1/2 inch from cylinder head and pull the rope. There should be a blue spark. Also if the gas has been in it for a while drain out old gas. ( This should be done at the end of season each year to prevent gelling in carburetor). Then replace with fresh oil and gas mixed with Sta-bil, this is a brand name gel dispersant and stabilizer. This is available at most parts stores. Now pump the bubble to fill carb. with fuel Make sure there are no leaks in the fuel line going to and from the bubble pump. If there is replace the line and or bubble pump. Now try to start the unit. Good luck, if you have no spark get back to me and I can walk you through the steps to diagnose no spark condition.
Aug 29, 2014 | Black & Decker Black and Decker & Grass...
SABRE S2045
May 31, 2014 | Garden
How do i get my toro gts-5 550 lawn mower to keep running?
The problem is likely varnish buildup in the carb. Add PAINT THINNER ( yes, I meant to say that !) to the gas. Use 1.5 ounces each of Xylol ( Xylel) and Acetone per 10 gallons of gas ( 5 gal. can will use 3/4 ounce each ).Drain gas tank and carb float bowl. Add fresh gas mixed with thinners. Remove air cleaner element and use quick starting fluid with upper cylinder lubricant to start mower, and keep it running with SHORT bursts of starting fluid until it will run on its own. You may also need to replace or clean air filter if it is old or dirty. continue procedure for 5 minutes or so. Remember to run Sta-bil fuel stabilizer through the system before you shut down for the season, as this will prevent the varnish build up.
I've been using thinner in all of my engines ( gas, pre mix, and diesel ) for a few years with no bad side effects. I've ridden over 15,000 miles on my motorcycle - getting better mileage and power, and not having to buy premium gas either.
Hope this helps!!
May 31, 2014 | Toro Lawn Mower With Toro Power Tools
Homelite trimmer, gas, string - y is the string wrapping itself around the head of the trimmer?
The line on my new 26cc Homelite would also feed out by itself. That started me thinking the line was wound backwards. I wrapped the line in the opposite direction as was shown on the bump feed reel and now the dang thing works although the bump feed needs to be "bumped" pretty hard to work. Is it possible that the reel was manufactured with the (string direction) arrows pointing the wrong direction? The new 26cc unit is also underpowered compared to my older 25cc trimmer.
Jul 20, 2010 | Homelite Factory Reconditioned 26cc...
I am borrowing my father-in-law's chainsaw. He is only here in the summer. I used his pre-mixed gas from last summer. It started well and ran super for about 20 minutes and then it faded, like short of...
sounds like the carburetor's getting plugged up. First, sta-bil doesn't burn that great, so you may want to dump it and start over. If the fuel has already sat for that long, sta-bil won't help it anyways. You want to start with fresh gas, with the proper mixture. If that doesn't solve it, you can look at the wide open mixture screw and see if you can tune it better.
Jan 22, 2010 | Mantis 2-Cycle Tiller
My string trimmer will not start
Possible solutions:
-Kill switch is shorted out-check the wire and connections.
-Buy a new plug.
-Primer bulb needs to be replaced.
-Fuel filter needs to be replaced, and it's located inside the gas tank so it's a bit tricky to replace.
-Try starting it without the air filter attached.
Is it possible an incorrect mix of gas/oil was used (or straight gas) which in turn ruined the motor?
Jul 29, 2009 | Garden
Riding lawn mower won't start
The carburetor is clogged from old fuel. remove and clean and consider getting a carb kit to give it new seals and gaskets and needle/seat. Sta-bil in the fuel, particularly over winter will prevent this problem. When the work is done, be sure to drain the old fuel and use fresh.
Jun 25, 2009 | Garden
Trimmer fires up but then stops , I pump the bulb and it starts again but then stops
Ok... 1. Make sure your Air Cleaner is clean 2. Empty out any old gas in the system from last season. from the tank, carb, and fuel lines. 3. Make sure that the gas filter in the tank is clean and free from blockage. 4. Clean out the carb jets with spray carb cleaner. 5.Pull spark plug and clean wih carb spray as well. 6.. Reassemble n fill with fresh gas/ or gas/oil mix if 2 cycle. let me know how it goes... k
Jun 10, 2009 | Homelite Garden
Homelite string trimmer mighty lite
does it have spark? did you replace the plug?
Apr 29, 2009 | Homelite Mighty Lite Lawn Trimmer
Homelite zip start 2cycle trimmer.
I had this same problem, would run a couple of seconds, stop, and you couldn't start it again.
Had good gas/oil mix 50:1 and 25cc Homelite. Had replaced the fuel filter, gas, spark plug, and took carb apart and cleaned with carb cleaner and primer bulb worked fine. None of that fixed it. What did? Take the muffler off and see if it will start and run with the muffler off. If it does, chances are the muffler is clogged. Also check the exhaust ports and clean them out if plugged with black oil carbon residue.
My muffler was clogged up, took it off, cleaned out the exhaust ports, there was some oil that was in the muffler(oil that didn't burn during combustion). It now starts and runs like a champ on first or second pull.
Mar 27, 2009 | Homelite Mighty Lite Lawn Trimmer
Garden Logo
26 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
