Question about Brother Office Equipment & Supplies
My Brother AX-24 Electronic Typewriter for some reason when I turn it on it goes all the way to the left, then starts beeping and it doesn't stop unless I turn off the typewriter
There is a grinding noise when it goes left then the beeping starts, I have checked the cartridges and they are fine
  • Roger Binsfeld May 05, 2017
    TRY LUBRICATING THE SILVER BAR THAT IT SLIDES BACK AND FORTH ON. USE A LIGHT MACHINE OIL LIKE WD40
  • 91 Answers
SOURCE: Can not use my typewriter
This is the Users Guide for this.
ftp://ftp.brother.ca/ENGLISH/TYPEWRITER/AX24-UG.pdf
Please rate fixya, if you this solve the query.
Posted on Jan 06, 2009
  • 68 Answers
SOURCE: looking for operating istructions for brother ax-26
Here is the link where you can download operation manual for Brother AX-26 for free:
http://www.devicemanuals.com/guide/Typewriter/Brother/Brother-AX-26-Typewriter-Owner%27s-Manual-T0RJNU1qYz.html
Posted on Oct 04, 2009
SOURCE: i bought a --brother AX-400 electronic typewriter
Move the carrier to the desired position for the new left or right margin using "backspace" or "space"
To move beyond the position of a current margin, first position the carrier on the margin and press "alt +m rel"
When the carrier is on the desired position, press "alt + l mar" (if you are setting the left margin), or "alt + r mar" (if you are setting the right margin.)
The minimim distance between the left and right margins is two inches
Posted on Dec 31, 2009
SOURCE: I have a Brother AX-24 electronic typewriter.
well once, and i have a brother em-30, i didnt use it and when i turned it on once, it went berserk and the wrong letters should up for the wrong keys. so i turned it on again(incidentally after i pasted the new letters unto the keys) and it was fine. so be basic, flip it on and off and then panic
Posted on Mar 13, 2010
hazelgrace
  • 340 Answers
SOURCE: I need the owners manual for my Brother Electronic
Hi
On the Brother site, there is one available for the AX-20.
Maybe it is simlar to your machine?
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_AX20_EN_1594.PDF
Hope this helps!
Posted on Sep 25, 2010
HP C310A grinding noise
Grinding noise is unusual. Check for the following ...
> Place the printer on an even surface.
> You may remove the ink cartridges and install them back.
If issue still persists, please call HP Tech Support as the printer requires a service.
If you are from USA and the printer is Out of warranty, then you may be provided an option to Trade in.
If issue still persists, please call HP Tech Support for further assistance.
If you are in US , the toll free # is 1-800-474-6836 .
If you are not in US , then log on to www.hp.com , at bottom-left corner there is a world map icon, click on it and then select the region you belong to, which would then provide support options for you for that region.
Apr 01, 2013 | HEWLETT-PACKARD C310a All-In-One InkJet...
The hammer for my brother ax-250 electronic typewriter doesn't move at all but everything else works fine, how do i fix the hammer?
The Hammer armature on the solenoid is cracked. This is a tough fix. for experienced repaimen only.
Dec 23, 2012 | Office Equipment & Supplies
Hp laserjet 5200 grinding noise from left side
front, rear ? I'd say fuser assembly gears or drum on toner cartridge; check the gear teeth on the toner cartridge's drum.
Dec 20, 2012 | HP LaserJet 5200 Printer
Where can i get a manual for my typewriter Brother AX-100
Go to BROTHER.COM click on support, poke around there & you will find a manual.
DickyO
Mar 27, 2012 | Office Equipment & Supplies
I need an instruction manual for the Brother AX-425 typewriter
Brother AX-425 Manual
Please visit the above link. Click "Slow Download", Download the User manual for Brother Electronic Typewriter.
Hope it helps! Good Luck!
CreativeTECH
Apr 01, 2011 | Brother Office Equipment & Supplies
My Laserjet 5SI printer has been jamming a lot lately and now it's making a grinding noise. Should I replace the cartridge or what?
Fusers generally make grinding noises more than cartridges do. If your paper jams are in the fuser area, check the fuser first.
When you open the left side door of the printer, the fuser is installed on a shelf near the top of the cavity. To remove the fuser, grasp the left and right blue fuser release handles and rotate them to the straight up and down (vertical position. Then lift up on the fuser and remove it from the printer.
Take a close look a the at the gear located on the top left corner of the fuser - does it have broken/ bent teet or is it loose on its mounting shaft? If so, that's probably causing both the paper lams and the grinding.
Also look in the printer directly under where this gear would be if the fuser were inserted in the pinter. Do tou see a build-up of fine particles the same color as the fuser gear. If you do that's further proof the the gear is bad.
You can but a replacement fuser at several places - check out www.printerworks.com & you can get one on an exchange basis.
Oct 27, 2010 | HP LaserJet 5si Printer
46 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
