Question about Bosch Hammering
Because my Bosch 11316EVS does not turn on I plug it into the light and it does not turn on
  • Bosch Master
  • 1,932 Answers
Bosch Parts Service Online Illustrated Part List
Control the power cable for wire breakage second remove the carbon brushes and control them on the collector surface for if there is a little black pin was coming out of it thats an auto protection build in then replace the brushes , but there are more things because there can be a problem with the electric field on a contact measure both coils and all the collectors (commutator around) on the armature that there is no-one lost the last option is the electronics
Posted on May 06, 2017
Which parts need to be greased before I put it back together
Bosch 11316evs a hammer where are complete maintenancekits for with the right grease beware of the parts that are have high priority to observe ALLWAYS REPLACE POS 41 and 39 together to get the neccesary pneumatic vaccuum for the mechanism because if there is leakage of oilseals the o-rings are to early getting HOT and harden prematurely again. also
Also note that the statorfield is mounted with two screws, because it does happen often that these 2 screws are not used!! and this in order to prevent the mangle with the four sliding contacts
A nice old model hammer GBH 11 in the Netherlands and or the same as this new product
http://dasen-hammer.en.made-in-china.com/product/BMgJKvoEXFpm/China-High-Quality-11e-1500W-Electrical-Demolition-Hammer.html
but finally this is what you are looking for your hammer .!!!
POS 898 partnumber 1.617.000.190 a consumables kit
http://www.powertools-aftersalesservice.com/public/boschprof/service?p_auth=aR4sBRMv&p_p_auth=WUDGLa1r&p_p_id=WSRP_bc93764e__6873__4b00__9a29__b331c9759da9&p_p_lifecycle=1&p_p_state=normal&p_p_mode=view&_WSRP_bc93764e__6873__4b00__9a29__b331c9759da9_wsrp-navigationalState=L0JPUy9QVEFTLVBULVNJUy1TaXRlL25sX05MLy0vRVVSL1ZpZXdQcm9kdWN0LURpc3BhdGNoO3BnaWQ9YmI5NWI3MGRjM2E3NzQxY2ExYzA0OGYyM2IzMF9fNDlzR3JsO3NpZD1QMzhKeVRtclkxWndER19mQlhFVk1qWWdLYlM2S19Dd3BYNktZcnNMOW1TVHlMb0F2ZDg9
May 16, 2015 | Bosch 11316evs Elec Vs Sdsmax Demolition...
My bosch 11316evs pause during hammering
COld be the powercable (think on the electric field by the sliding contacts) or a to short carbon brush or a broken ring on the impact bold in front inside , pauze can be mechanical or electric.
Feb 10, 2015 | Bosch Hammering
How to repair bosh 11316evs
Purchase a service kit # 1-617-000-190
This will have all the normal wear parts including brushes & new grease.
This is a fairly easy hammer to rebuild - make sure you thoroughly clean all the parts, install new rings & grease - the kit comes with a parts breakdown to help. Service Pack 1617000190 for Bosch Power Tool eReplacement Parts
Apr 15, 2014 | Bosch SDS - max Demolition Hammer 11316EVS
Bosch 11316EVS demolition Hammer soft start not working. Starts at full speed and does not impact until slowed down.
Variable speed control module has failed, however you can still use the tool. Hammering action will improve with a good cleaning of internal parts and apply new grease. Hammering action is caused by air/vacuum cushion between drive piston and driven piston which inturn hits a third piston that actually impacts the bit. If third piston is worn, chipped and lodged with debris, there will be light hammering action. After use, store the hammer with the nose pointing down so that the driven piston will slide to end of cylinder and ready for next use.
Sep 27, 2011 | Bosch 11316evs Elec Vs Sdsmax Demolition...
Bosch 11316EVS doesn't star. Power cable is good What another issue is possible?
most common problems with these units is brush replacement, or even the on/off switch, I work for a home depot tool rental and are constantly replacing the brushes.
Oct 09, 2010 | Bosch 11316evs Elec Vs Sdsmax Demolition...
It doesn't star. Power cable is good What another issue is possible?
The electric field contacts carbon brush autostop in it is activated or is stuck on dirt .
Sep 29, 2010 | Bosch 11316evs Elec Vs Sdsmax Demolition...
Bosch Demo Hammer switch plate removal?
The switch plate must be pryed off very carefully. Pry off the top part of the plate if the tool is upright. Start on one side then switch the tool on (unplugged) and pry off the other side. Not a very good system but it can be done if you are carefull
Jan 10, 2010 | Bosch SDS - max Demolition Hammer 11316EVS
Hammering Logo
1,764 people viewed this question
Top Bosch Hammering Experts
John Trevino
Mike
Are you a Bosch Hammering Expert? Answer questions, earn points and help others
