Question about The Computers & Internet
What does the subscript in a chemical formula tell you?
    Master:
  • 412 Answers
The number of the previously named atoms in the compound. Water has 2 Hydrogen atoms and one Oxygen atom -- H2O, where the 2 is a subscript.
Posted on May 03, 2017
What does it mean if there isn't a subscript number in a chemical formula?
It means just one atom of an element is present in the molecule, or that just one group of several different atoms is present.
Jan 13, 2017 | Computers & Internet
What is the chemical symbol or formula foe nitrate
Nitrate is a polyatomic ion with the molecular formula NO3? and a molecular mass of 62.0049 g/mol.
Mar 30, 2015 | Computers & Internet
What does chemical symbols mean?
Are you talking about chemical formulas, reaction symbols or the elements on the Periodic Table?
Nov 05, 2014 | Computers & Internet
Where is serial number and mfg date on bissell 73h5 machine
On machines: The serial number is located on a white label like this. It is usually located at the lower back or bottom of the machine (for Lift-Off models - remove Lift-Off pod to locate), or behind the cleaning tanks.
On cleaning formulas: cleaning formulas do not contain serial numbers. Instead, please enter the full number from the UPC code. Look for it on the back of the bottle or can, near the bottom. Here is a sample:
[img title="upc-on-chemical" alt="upc-on-chemical" src="http://www.bissell.com/uploadedimages/Asset_Library/images/Customer_Support_images/upc-on-chemical.png">
May 03, 2014 | Computers & Internet
Write down the equation for the formation of the complex trans-K[Cr(C2O4)2(H2O)2.3H2O from the reactants K2Cr2O7 and H2C2O4.2H2O.
limiting reactant:
The limiting reagent, or also called the "limiting reactant", is the chemical that determines how far the reaction will go before the chemical in question gets used up, causing the reaction to stop. The chemical of which there are fewer moles than the proportion requires is the limiting reagent.
Limiting reagent formula
There is a much simpler formula which can be used. However, you must first calculate the moles of both of the reagents in the reaction. Once the number of moles have been figured out, just simply fill in this equation (reagent 1 being the first reactant and 2 being the second):
When the answer to the formula is less than zero, reagent 1 is the excess reagent. When the answer is larger than zero, reagent 1 is the limiting reagent. The number shows how much in excess one reagent is from another. If the answer for the formula is zero, both reagents are perfectly balanced. The unit of an answer is in moles.
Oct 17, 2013 | InnerIntimates Vaginal Renewal Complex...
Steps on how to apply superscript
In earlier version of Microsoft Office (Word 2003), trying to write a subscript or superscript takes quite a time but with the new Word 2007 it's so simple. For those who are writing technical articles face situation to use these subscripts and superscripts in almost every article like mathematical formulae or chemical equations.
What are Subscript and Superscript? A subscript appears smaller and below the baseline (Ex. H2O or X2) while a superscript appears smaller and above the baseline (Ex. X3)
How to Subscript and Superscript in Office 2003 and 2007?
In Word 2003, select the characters that you would like to change. Go to Format menu and Click Font, from the Font tab you have to select subscript or superscript.
In Word 2007, select the character that you would like to change and Click the Superscript or Subscript symbol from the ribbon under the home tab.aviral_srms_14.jpgIn both Word 2003 and Word 2007, you can also use keyboard Shortcut keys to make the characters as Subscript or Superscript.
Superscript: Press CTRL+SHIFT+=
Subscript: Press CTRL+=
If you work on Windows and Office Applications most of the time then these posts on Keyboard Shortcuts for Windows and Office will help you a lot.
Mar 19, 2011 | Computers & Internet
What is borazine
Borazine is an inorganic compound with the chemical formula (BH)3(NH)3. In this cyclic compound, the three BH units and three NH units alternate. ...
en.wikipedia.org/wiki/Borazine - Definition in context
Jan 12, 2011 | Lands Phones
I have just had an iflo metal bath installed but am unsure what products should be used to clean it
When cleaning your metal bath you should clean your bathtub with a non-abrasive soap. Dishwashing detergent such as Joy®, Palmolive®, Ivory®, etc and a soft sponge or cloth is all that you need. If you spill something on the bathtub and need something stronger, the following are SAFE to use: Fantastic®, Tackle®, Top Job®, Formula 409®, ScrubFree®, Calgon Bath®, Windex®, Clorox Bleach®, Spiffits® Bath, Glass Plus®, and **** & Span Powder®.
DO NOT Clean Your Acrylic Bathtub with Paint Thinner, Goof OFF®, Scrubbing Bubbles®, Acetone, Lacquer Thinner, M.E.K. ® or other chemicals that attack the structural integrity of plastics (including, but not limited to, acetones). Use of these chemicals will destroy the acrylic surface of your bathtub and there is no way to reverse the damage caused by this type of chemical reaction. Use of these chemicals will void your warranty.
Oct 25, 2010 | Home
Looking for formulas to produce Magnesium Oxide Boards
http://www.mag-board.com/
http://www.ehow.com/way_5299792_practical-ways-make-magnesium-oxide.html
I don't know why you would want to make the stuff, you can buy it already made into boards. A couple web sites here for you to check out, one is a supplier and the other is a lot of work if you ask me. Check it out.
Jun 12, 2010 | RTO M-D Building Products Carpentry &...
Computers & Internet Logo
54 people viewed this question
Top The Computers & Internet Experts
Ed Watson
Level 1 Expert
Alex Krenvalk
Alex Krenvalk
mukhtar21 shaikh
mukhtar21 shaikh
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
