Question about LG Dishwashers
Is there any drawings to show assembly of LG #14at1 dishwasher mainly components [for bottom section only] ?
    Top Expert:
  • LG Master
  • 39,273 Answers
Request an assembly diagram from LG.
Posted on May 02, 2017
I have an LG flat screen tv that only show the top half of the picture. The bottom half is blacked out. What is the problem.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Apr 14, 2017 | LG Televison & Video
LG Dishwasher LD-1420T1 Tripping the main Power Board
Looks like the pump motor is drawing lot of current and tripping the circuit breaker. Need to check if there is any water inside it. Or simply the capacitor is leaky and causes motor to draw current.
See this part.
http://shop.onlineappliancespares.com.au/part/4681ea2002f-134640/43518
Apr 07, 2014 | LG Dishwashers
My lgis making a horrible noise and is now shoeing an e1 code dishwasher
The LG does suffer from "poor quality" motor that causes this type of noise. The main motor and pump assembly is common to give this type of problem. The pump seal leaks a small amount of water that gets onto the front bearing and causes a "grinding = humming" noise. This can be easly replaced once you have the bottom off and dishwasher on its door. The motoe has 1 screw in the back holding the motor to the bottom and two rubber seals for the water pump in/out into the washer. Just pull and move motor and pump assmbly and it comes free. Replace with a new motor and pump assembly...
Nov 18, 2011 | LG LDF6810ST Stainless Steel Built-in...
Hello, LG LD 14AT1 dishwasher, starts cycle runs 3 minutes, starts stops on off no water in bottom. Then displays OE chimes! Checked tap under sink water there, checked filter inside bottom, turned off for...
Hi
OE in your dishwasher is a drain error and dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. If the issue returns after cleaning then the drain pump assembly should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 27, 2011 | LG 24 in. LD-12BS6 Stainless Steel...
Bottom rack of dishes don't come out clean, top rack is good. is this a possible spray bar problem
You may have a stuck diverter valve inside the sump assembly. Only way to tell is to disassemble the top section of the sump assembly to see if there is any debris blocking it. You will need a technician to help you with this. Good luck
Jun 17, 2011 | LG 24 in. LDF 7811 Stainless Steel...
Lg ld2131sh dishwasher makes a constant, metal on metal grinding sound
If you’re hearing a fast knocking or a fast grinding sound, then it is your motor going bad. This will result in an LE code and the unit will no longer work as this gets worse.
You can get a replacement sump assembly that has the motor and all new sensors to resolve this issue.
Good Luck.
Jul 22, 2010 | LG LDF6810ST Stainless Steel Built-in...
LG 14AT1 Dishwasher not working
Well done! Can you confirm that you own an LG dishwasher?
Thanks!
Mar 14, 2009 | LG 24 in. LD-12BS6 Stainless Steel...
Hi. I have a 3 year old LG dishwasher. It will not drain. Display shows OE. I completely cleaned the drain assembly inside the DW. I checked the discharge line, it is completely clean. I disconnected the...
Measure the electric resistance of the Drain Motor. (Value should be 20-40 Ohms) If it is out of spec, replace it.
Please reply with what worked best. Thanks!
Dec 26, 2008 | LG 24 in. LDF 7811 Built-in Dishwasher
Drum outlet hose assembly
Hi trevor it is just a eco ball it is not needed it will cause you more problems when it is in the machine dont worry just leave it out
Aug 01, 2008 | Whirlpool AWM8103/1 Front Load Washer
Dishwashers Logo
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
