Question about Shuttle AV41P Motherboard
Compatibility oy my video card..
I recently bought a ati radeon 9250 video card AGP8x.. my supporting AGP bus is 1x,2x, 4x.... the display become blank after i run my pc after 15 minutes using this card.. and input does not support display in my LCD..Wat brand can i replace? i want a 256mb video card
  • 1,601 Answers
Check power options in control panel.
is it set to shut off monitor?
do you have the right drivers installed?
Posted on Nov 22, 2007
Enable AGP 4x
you don't need to reinstall or format c:\ ..all you need uninstall al the drivers and install the correct driver of your VGA add on card.
Jan 18, 2008 | ASUS VIA 694XDP Dual Processor Chipset...
I need this driver "ati
Apr 18, 2011 | Gigabyte RADEON 9250 AGP8X 128MB DVI...
How can i configure ATI Radeon 9250 with some pc games requiring a video card as like the nvidia geforce ... is this a matter of great conflict of playing a gaming network???
128MB or 256MB of 333MHz DDR memory
accelerates the latest cutting edge 3D applications
Available in both a 128-bit and 64-bit memory data path interface
ATI RADEON™ 9250 VPU operating at 240 MHz
Supports the AGP 8X and AGP 4x standard or PCI Bus, providing a high-speed link between the graphics board and the rest of the PC
Four pixel shader pipeline
Full support for Microsoft® DirectX® 8.1 and DX9 compliance and the latest OpenGL® functionality
VIDEO IMMERSION™ and FULLSTREAM™ technologies which provide for amazing video playback quality.
Integrated DV support for Flat Panel displays
Powered by CATALYST™ -
The industry's most stable unified graphics software
But since its only a 256 mb graphics card.
ATI Radeon™ HD 4770 Graphics is the best if you don't want to buy a costly one. its the most economical graphicss card.
ATI Radeon™ HD 4770DirectX®10.1
512MB, GDDR5
640 Stream Processors
ATI Stream Technology
51.2 GB/s Memory Bandwidth
ATI CrossFireX™ Technology (up to 2 GPUs)
PCI Express 2.0 x 16
since most of the games are compatible with Directx 10 and 11 this would be the one..
Jan 22, 2010 | Video Game Consoles & Games
Problem for my video card drivers
Go under your start menu and click on windows update, and when it pulls up internet explorer click on custom install and you'll see all the updates click on hardware and see if windows can install the driver.
Jun 17, 2009 | Ultra ATI Rage 128 Pro Graphic Card
Is my motherboard compatible with a new graphic card
Being agp3.0, it is backwards compatible so in theory, it should work. With the older system, it may be dangerous. I would find a card that clearly states that it works in x8 (3.0) 1.5v. If it doesn't work it could fry the whole system. If i find a card that works, I'll let you know.
Oct 27, 2008 | XFX GeForce 6800 GT, (256 MB) Graphic Card
Graphics card support to motherboard D845GBV
AGP 2.0 and 3.0 4x and 8x feed with the 1.5v spec. AGP 1.0 1x and 2x was fed at 3.3v. In short, you should be fine.
May 15, 2008 | Intel D845GBV (BOXD845GBVL) Motherboard
Intel P$ 1.8 mhz on a D845HV/D845WN board
Before removing your current card swap video outputs on the PC. If currently connected to the VGA output switch to the HDMI connector AT the video card. Use the HDMI to VGA adapter that came with the video card. Check & see if the display loads Pc starts. Taking the information directly from your motherboard manual pg. 25, your AGP video can only run at, AGP supporting 1.5 V 4X AGP cards. The 9600pro runs at 8x & it is not backwards compatible. (able to run at either 8x or 4x). You could run the Sappire ATI Radeon 256MB 9550 DDR AGP 4x/8x 1.5volt card.
Here is one site:
When you do get the video card be sure to set your bios AGP to the correct size as listed in your manual pg. 109 subsection 4.4.7
I hope this helped.
Feb 20, 2008 | Intel Motherboard
All AGP based cards are backwards compatible, so an 8x card should operate at 4x 2x and 1x
however what is important is the voltage of your slot, you can tell by looking at the slot itself,  the AGP slot may have a partition either 1/3 or 2/3rds down the slot, or may have no partition at all,
this slot partition is to prevent you from inserting a card of the wrong voltage.
If there is no partition in the AGP slot then the slot has a switchable voltage, and will automatically switch to the appropriate voltage, (on request from the graphics card AUTOMATIC)
so all you need to check is that the graphics card you buy has slots on the AGP interface that accomodate those on your board
according to the manual
This board has a 4x AGP slot
Oct 09, 2007 | Intel Motherboard
Does my (this) mother support agp ddr2?
MOTHERBOARDS Hi there, does my motherboard support video cards like ATI RADEON X1650 512MB AGP? ---YES, When you installing AGP card, please make sure the following notice is fully understood and practiced. If your AGP card has "AGP 4X/8X (1.5V) notch"(show below), please make sure your AGP card is AGP 4X/8X (1.5V). Caution: AGP 2X card is not supported by Intel® 845(GE/PE) / 845(G) / 850(E) / E7205 / 865(G/PE/P) / 875P. You might experience system unable to boot up normally. Please insert an AGP 4X/8X card. Does it support ddr2 or ddr3 memmory for the agp? ---YES, see the above notes can the agp memmory be over 512 mb? ---YES, see the above notes More more information go here >>> Hope This Helps =============================================== If you are having trouble with a Newly bought items then return them and demand a replacement or a refund! You may have purchased a reconditioned\repaired\factory defect product.
Sep 19, 2007 | Gigabyte GA-8IPE1000-G (MBGA81PE1000G)...
Shuttle AV41P Motherboard Logo
Top Shuttle Computers & Internet Experts
Iqbal Husain
Iqbal Husain
Alun Cox
Are you a Shuttle Computer and Internet Expert? Answer questions, earn points and help others
