HP ProBook 4520s keyboard not working after restoring to fatory default.
Hi Amol, could you please provide that which key is not working properly. Or is that the issue with the Keyboard Language. If you installed a new OS on you PC the language should be changed. For that you need to open Contrl Panel-->Region and Language (if not available change the view by to small icons from category). --> Select Keyboard from the Tab--> Press Change Keyboards--> Select English US--> Apply & OK--> OK. You need to reboot your PC and test the Keyboard issue. If you still facing the same issue then please get back with the correct issue (which keys not working).
Requesting you to provide the status.
Regards,
Sreerag.S
