Can I restore my laptop with on screen keyboard
How do I scan a hp laptop?
You need to provide a little more information to get an accurate answer. If you are able to see the log in screen, the display is probably fine. If you are using Windows 8.1, this has been a problem for some of the HP systems after certain updates. You'll need to do a recovery to get things back to normal.
  1. Turn off the computer and wait at least 5 seconds with the computer in a full off state.
  2. Turn on the computer and repeatedly press the F11 key, about once every second, until you see the Windows loading screen.
  3. If a language selection screen opens, select the language you want to use to continue.
  4. On the Choose your keyboard layout screen, select the keyboard layout that matches your keyboard type. On the Choose an option screen, click Troubleshoot .
  5. Choose an option
  6. On the Troubleshoot screen, click Advanced Options .
  7. On the Advanced options screen, click System Restore .
  8. Advanced options
  9. Click Windows 8 or Windows 8.1 as the target operating system. Click Next .
  10. Click the restore point that you want to use, and then click Next .
  11. The Confirm Restore Point window opens.
  12. Click Finish to restore your computer to a previous point.
Aug 28, 2014 | HP Computers & Internet
I have a Acer aspire one 1012 that had a broken screen, I replace the screen and then the keyboard would not work. I replaced the keyboard and restore the computer to factory default but still can not
how you did the restore? USB keyboard?
See if it is disabled by BIOS. you can check this with your manual.
Try with FN+ i think it's F6 you have probably some markings on keyboard.
Mar 18, 2013 | Acer Aspire One Netbook
Disc read error
Step 1:
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer You could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue You might use the system restore to restore your system to an earlier time click start all programs If it is a hardware issue the system restore might not work Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer. Use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System. Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue.
Feb 12, 2013 | HP Compaq NC6220 Business Notebook
Factory image restore
Press "Power" on the Inspiron 1525, and continuously press "F8" on the keyboard when the Dell logo appears on the laptop's screen.
Press the down arrow to highlight "Repair Your computer," and press "Enter" to select the highlighted onscreen option.
Click your preferred keyboard layout, and click "Next" to continue with the laptop's restoration process.
Type "administrator" in the username field, click "OK" and click "Dell Factory Tools."
Click "Dell Factory Image Restore," and click "Next." Click the checkbox next to the Hard Drive reformat confirmation, and click "Next."
Click "Finish" to reboot the OS after the restore process finishes, which can take up to 10 minutes
hope this helps
Aug 27, 2012 | Dell Inspiron 1525 Laptop Flamingo Pink
Dell lattitude d620 won't factory restore ?
Please go through the below step, you can able to do it.
1) Shut down the Dell Latitude D620 if it's currently powered on. Click "Start" in the left-hand corner of the screen to access Windows' shut down options. Alternatively, press and hold the Latitude's power button, located on the top edge of the laptop's keyboard.
2) Turn on the computer by pressing the laptop's power button.
3) Press and hold "F8" on the top of the laptop's keyboard immediately after turning the computer on. If the Windows logo appears on the screen, you're too late and must repeat Steps 1 through 3 again. If you pressed it in time, a list of text options will appear on the screen.
4) Use your keyboard's arrow keys to scroll down to "Repair Your Computer." Push the "Enter" key on your keyboard.
5) Choose a language from the next list and select "Next." If you've password-protected your laptop, you will be prompted to enter your user name and password at this time.
6) Press "Dell Factory Image Restore." A new window will appear. Click "Next" and select the option for reformatting the hard drive and restoring the factory condition of the laptop.
Dec 17, 2010 | Dell Latitude D620 Notebook
I wanto to reformt my sattelite a100 - 700 without cd drivers
Hi icsisayanir,
Follow the instruction below to help you restore your laptop to the factory settings.
1) Turn on the computer.
2) As the computer starts, press 'F8' on the keyboard until the Advanced Boot Options menu appears on the screen.
NOTE: You must press 'F8' before the Windows logo appears on the screen. If you press 'F8' after the Windows logo appears on the screen, the Advanced Boot Options menu will not appear on the screen.
3) Press the 'Down Arrow' on the keyboard to select Repair Your Computer on the Advanced Boot Options menu, and then press 'Enter'.
4) Follow the onscreen instructions to complete the factory restore.
5) When the restore operation is completed, click Finish to restart the computer. Now your computer is restored to the default factory configuration.
NOTE: You can restore the laptop only if there is a Recovery Partition and/or if you haven't deleted it.
If this information was helpful, please rate it.
Thank you for using fixya,
Arun Zac
Nov 27, 2010 | Toshiba Satellite A100-S8111TD Notebook
How can I restore my laptop dell d 830 to its factory settings without a cd
Hi darioindc,
4) Specify the language settings that you want, and then click Next.
5) Log in as a user who has administrative credentials, and then click OK.
6) Click Dell Factory Image Restore.
7) In the Dell Factory Image Restore window, click Next.
8) Click to select the Yes, reformat hard drive and restore system software to factory condition check box.
9) Click Next.
10) When the restore operation is completed, click Finish to restart the computer. Now your computer is restored to the default factory configuration.
Arun Zac
Nov 27, 2010 | Computers & Internet
Evesham laptop muse/keyboard/restart prob
Operating System Corrupted. Save all your data and use Factory Restore Disks to Restore your Entire System, including Drivers. If you have problems with saving Data on Hard Drive with External USB Drive than it may be a faulty Hard Drive which you can just replace, then reload O.S. .
Aug 20, 2009 | Computers & Internet
When i try an open system restore the window appears blank, an my laptop doesnt no what the internet is when i try an open internet explorer it asks me what program to use, all this started after i ran i...
You might want to print this out:
1) Turn off your laptop.
2) Press the "on" button on your laptop, and *immediately* start tapping on the F8 key on your keyboard. This should bring up a black screen with white text on it.
NOTE: You may get a message saying "keyboard error, press F1 to continue." If this happens, press F1 and then keep tapping on the F8 key.
NOTE: If the Windows screen comes up, turn off the computer and try again until you get to a black screen with different startup choices on it.
3) Once you have reached the startup choices screen, use the arrow keys on your keyboard to highlight "safe mode." Press the Enter key. If you are asked to choose your operating system, just press Enter again.
This will start a lot of text scrolling on your screen. Just be patient. When it stops, you will see a login screen. Log in under your name (sometimes this is "owner").
4) You will now be logged in to you computer in Safe Mode. A message will pop up asking if you want to use Safe Mode or System Restore. Click on System Restore.
5) You should now have the option to undo your last System Restore. Choose this option and follow the instructions on your screen to get back to where you were before you tried to restore your laptop.
If you need further help after that, please reply with the name and model number of your laptop. For example, "Dell Inspiron 530," or "Compaq Presario 3000." Also let me know what version of Windows you are using, for example "XP" or "Vista."
Jan 08, 2009 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
