Question about LG Dishwashers
The Air Braker for LG #14at1 dishwasher.how can i located. ?
    Top Expert:
  • LG Master
  • 41,875 Answers
Trace the drain line from the pump.
Posted on May 02, 2017
Tip
I get error IE on my LG dishwasher.
IE is inlet error, displayed when "Not reached to the normal water level in spite of 10 min. water supply"
Possible cause:
  • The Water Supply Tap is closed.
  • The Water Supply is shut off.
  • The Inlet Hose is kinked.
  • The Water Pressure is very low.(below 10 psi)
  • Inlet Valve is OK?
  • The filter of Inlet Valve is clogged by impure water.
  • The Hall sensor is OK?
  • The Impeller of Air Guide is bound.
Remedy:
  • Cut power by tripping circuit breaker or unplugging power cable for ten minutes.
  • Take action on Water Supply device.
  • Measure the electric resistance of Inlet Valve. (950-1300 )
  • Clean the filter of Inlet Valve.
  • Check the frequency of Inlet Water by the Test Mode.
  • Replace the Air Braker.
on Jan 31, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Hello, LG LD 14AT1 dishwasher, starts cycle runs 3 minutes, starts stops on off no water in bottom. Then displays OE chimes! Checked tap under sink water there, checked filter inside bottom, turned off for...
Hi
OE in your dishwasher is a drain error and dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. If the issue returns after cleaning then the drain pump assembly should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 27, 2011 | LG 24 in. LD-12BS6 Stainless Steel...
Does not fill with water e1 code
1E means - Water inlet problem >Condition : Not reached to the normal water level in spite of 10 minute water supply
Water supply problem. The inlet hose is kinked. The water pressure is to low (10psi) Inlet valve. The inlet water valve filter is clogged. The hall sensor. The impeller of Air guide is bound. Remedy : Check resistance of inlet valve ( 950-1300ohms) Clean valve. Check pressure. Replace the Air braker.
Mar 29, 2010 | LG 24 in. LDS 5811 Built-in Dishwasher
I have an error code of 1E on my LG dishwasher what does this mean and how do I fix it?
1E error is Not reached to the normal water level in spite of 10 min. water supply
POSSIBLE CAUSE REMEDY FOR ERROR OCCURRENCE The Water Supply Tap is closed. The Water Supply is shut off. The Inlet Hose is kinked. The Water Pressure is very low. (below 10 psi) Inlet Valve is OK? The filter of Inlet Valve is clogged by impure water. The Hall sensor is OK? The Impeller of Air Guide is bound.
Remedy Take action on Water Supply device. Measure the electric resistance of Inlet Valve. (950-1300 ) Clean the filter of Inlet Valve. Check the frequency of Inlet Water by the Test Mode. Replace the Air Braker.
Sep 26, 2009 | LG Dishwashers
Keeps alarmimg 1E on my Lg Dishwasher
Inlet water error 1E
Sep 24, 2009 | LG Dishwashers
LG 14AT1 Dishwasher not working
Well done! Can you confirm that you own an LG dishwasher?
Thanks!
Mar 14, 2009 | LG 24 in. LD-12BS6 Stainless Steel...
IE problem
Possible cause:
Remedy:
Dec 23, 2008 | LG LDF8812 Stainless Steel Built-in...
LG Dishwasher (LDS5811) - low water level
1E= Inlet Error
Condition>>>
(below 10 psi)
Inlet Valve is OK?
by impure water.
Solutions:
device.
by the Test Mode.
Aug 20, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
LG 3 in 1 Dishwasher model LD2131SH
E1=Water inlet Error
Causes:
(below 10 psi)
Inlet Valve is OK?
by impure water.
Solutions:
device.
by the Test Mode.
Aug 14, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
Dishwashers Logo
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
