Question about Refrigerators
My fridge works but the bottom freezer doesnt
  • Refrigerators Master
  • 884 Answers
Is it a dual compressor system? Is there a separate thermostat / controller for the freezer?
Posted on May 04, 2017
eagle338
  • 4889 Answers
SOURCE: Zanussi fridge freezer - fridge not working
The defrost cycle is not happening like it should, that's what causes the block of ice (and poor air flow). If you have all that defrosted look at the defrost bi-metal, it usually is a small round disk with a couple wires coming out of it and it's clipped on the coils. When it's cold enough, it passes electricity to the heat elements, when it gets hot enough it "opens" and kills power to the heat elements. If that is bad (swollen cracked or bloated) and not passing electricity to the elements that's the problem. Another item would be the defrost timer itself, if it doesn't work (no clock motor turning) then it will never go into defrost. And the last and usually least expected failure would be the heat element themselves not working
Posted on Oct 09, 2007
SOURCE: my amana bottom freezer won't cool both the fridge and freezer are warm
Ice build-up inside refrigerator and cycling switch not functioning. Requires technician to take apart inside of refrigerator, clear ice and replace switch. Took my repair man about half hour to fix.
Posted on Jan 15, 2009
konzzz
  • 255 Answers
SOURCE: Bottom not cooling
the blower is broken or frozen.you need to defrost and clean it.or the air passages are clog.
Posted on May 08, 2009
Sea Breeze
  • 4655 Answers
SOURCE: kenmore model 596.72253201. Bottom freezer works, fridge does not
The most likely reason is part number 12566102 Adaptive Defrost control board. The next likely are the defrost heater and the defrost thermostat,Sea Breeze I will send you photos. below
Posted on Sep 11, 2009
  • 180 Answers
SOURCE: kenmore fridge. freezer top works, but bottom doesn't.
Either your fan has stopped working, or it is not defrosting. Take the back panel of the freezer off and see if the evaporator coil is iced over, if it is replace the deforst heater, and the deforst thermostat. If the compressor is running the fan if the freezer should be running. Also make sure both your fridge and freezer controls are centered. Putting the freezer on the coldest setting acutally shuts off airflow to the fridge.
Posted on Dec 05, 2009
We have a model MBF1956KEB the freezer works but not the fridge
sounds like you have a bad damper,if you go here and look at part number 13 you can see it
http://www.searspartsdirect.com/partsdirect/part-model/MAYTAG-Parts/Refrigerator-Parts/Model-MBF1956KEB/3048/0161000/M0607105/00010?blt=06&prst=&shdMod=
it's broke in the closed position so no cold air can get blown over from the freezer and into the fridge section,open the freezer door and make sure you hear the fan blowing,also check around the freezer door and ceiling of the freezer and make sure there isn't any ice,common problem with bottom mount freezers is the door can get left open,warm air gets sucked into the freezer and ice forms in the air ducts,if all looks good i would say you have a bad damper,one more thing,remove the bottom kick panel there should be a tech sheet either folded up in the panel or taped on the cabinet wall down there,it will tell you how to do a diagnostics check to check all the parts like the damper,this way you know what part is bad.hope this helps you out and good luck.
Jul 28, 2012 | Maytag Refrigerators
Freezer works, fridge doesnt!
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 26, 2011 | Maytag MFI2568AES Stainless Steel Bottom...
The freezer seems to be working but the fridge doesnt seem to be getting cold
heatman101
Jan 04, 2011 | Amana ARB2217C Bottom Freezer Refrigerator
Freezer works, fridge wont get cold and fridge doesnt cycle off
Probably have a bad freezer fan or the unit is not defrosting. You can easily hear the fan running.
May 28, 2010 | Maytag MFD2560HES Bottom Freezer French...
No light in refer but works in freezer
Check the door switch to see if is working and try another light bulb or try the light bulb somewhere else to see if the light bulb is good. Check to if vent holes coming from the feezer are blocked by something in the fridge. This will make it feel like your fridge is not working.
John
Sep 28, 2009 | Smeg FAB32 Bottom Freezer Refrigerator
My fridge in my fridge freezer keeps freezing everything in it.
If the fridge side is frozen you have a door seal issue.
If the freezer side is frozen you have a defrost component issue.
Your post was not clear as to which side is frozen.
Jun 16, 2009 | Hoover HFA270K Bottom Freezer Refrigerator
Frigidaire Side-By-Side Top Not Cooling
the unit is loosing the freon supply to the evaporator.you either have a leakage,a blockage or the compressor is not pumping to full capacity.
Nov 05, 2007 | Frigidaire FRS3R5EMB Side by Side...
Kenmore Elite 75212 fridge doesnt cool off
Well there is a diffrence between no air flow and not cooling is the freezer working?? We can go from there
Sep 16, 2007 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Touch Temp Controls
If the touch control doesn't respond then it's most likely bad. They don't normally act up, they either work or they don't.
Jan 05, 2007 | LG Bottom Freezer Refrigerator w/ Swing...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
