Question about Sharp Microwave Ovens
Need feet dimensions for sharp R664SLM microwave with grill mounting on wall brackets
MicrowaveSvc
  • 9085 Answers
SOURCE: Removing Microwave
First I would wonder if you really need to remove it from the wall? Many repairs can be done with it still in the wall. If so, installation instructions should be with the paperwork that came with the oven, and that will show you how to remove it. Buit if you don't have that, you would likely remove the grille from across the top. The grille is usually held in place with screws and/or clips. After that is out, there may be a couple of other screws now revealed at the top edge, or there may be a one or more "catches" just under the top edge of the the chassis. I would strongly advise you to have a helper working with you. These can be heavy, and awkward. You might call the GE Answer Center and ask if they can supply you with installation instructions. They're at 800-626-2005 (24 hrs.) Otherwise, you may be able to find instructions that are close enough at a place like Lowe's. They may have some demo models and you can usually ask to look at the manuals.
Posted on Jan 07, 2007
jyackle5
  • 8197 Answers
SOURCE: I need a wall mount bracket for a ge spacemaker
To get the wall mount you need to call GE here at this #.
1-866-775-4557
GTood Luck and Please Rate
Posted on Sep 10, 2009
  • 5 Answers
SOURCE: How do I remove Frigidaire FMV156DCC under cabinet microwave?
Underneath the microwave, on the right & left hand corner sides at the back, there are levers that you pull down & it releases the mounting bracket.
Posted on Sep 12, 2009
I just got my Whirlpool MH7100 off the wall. It was a bit of a hassle. I could not find a proper manual online at Whirlpool, but I guess since my unit was manufactured in 1993, who can blame them? Was the Internet even around in 1993?
There were 2 obvious bolts to remove above the microwave, these were found by opening the cabinet above. The next step was the hard one. Even after these were removed, the microwave would not lean forward so that it could be removed from the rear brackets. To get it to lean forward, I had to partially remove and partially break (i think) the vent for the exhaust fan. This revealed what looked like a very large screw with a regular head, one on each side. Once I unscrewed both of these, I was able to lean it forward and get it off the rear brackets.
Posted on Sep 23, 2009
rylee_smith
  • 8619 Answers
SOURCE: We have a Sharp R-1851A
Hi
Thanks for using FixYa. Please find the user installation manual for your Microwave--
Sharp R-1851A Over the Stove Microwave installation manual
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Oct 27, 2009
Testimonial: "Jackpot! Thank you so much. I've been everywhere else on the web with no luck. You are wonderful!"
Over range microwave doesn't fit in the space outlined by the installation template
You missed something while reading the installation directions but that won't fix it. since you already drilled holes in the wall lower the mount down as needed then drill new holes in the mount to match the holes you drilled in the wall. The problem would have been worse if you were off left or right... up and down is easier. Remember you maybe just not dropping the microwave low enough to fit in the slot at the bottom of the wall mount before you tilt the micro up.. check it one more time...including the directions before you re-drill
Sep 26, 2015 | Bosch 30" 500 Series Over-The-Range...
I own a 1993 (but very seldom used) Sharp R-1830 Over-the-Range Microwave. Worked perfectly until a total death yestereve. The oven light went out last week and now the control panel neither lights or...
There's need to remove the oven from the wall to check and replace the fuse.
Just see the video here to show you how to remove the grille and controller assembly.
The fuse is located between the door switches.
If the fuse blows again as soon as you press "Start" to begin cooking, then you likely have a shorted high voltage capacitor.
Let me know if you need further assistance.
You can find helpful exploded views and order parts at the Sears Parts Direct Web site.
Jan 08, 2014 | Sharp Microwave Ovens
Ewave microwave
Over the range microwaves are generally the same as far as the rear dimensions but you will still need to install new mounting brackets and drill new holes in the cabinet. Each brand is slightly differnt in its mounting.
Nov 25, 2013 | Microwave Ovens
Sharp R-1461a. What are dimensions?
The dimensions of your Sharp microwave model number R-1460, R-1461 and R-1462 are 29 3/4" in width 14 3/4" in height and 12 1/2" deep. Capacity is 1.1 cubic feet.
Sep 30, 2013 | Microwave Ovens
How to remove sharp 1480 microwave from the wall
If this is a built in mounted under an overhead cabinet, Just open the above cabinets and there will be 2 long screws facing downward that hold it in place, if it is a built in that is framed in then you will need to remove the frame and the brackets behind the frame that are holding it in place and then slide it out.
Aug 26, 2010 | Sharp R-1480 Microwave Oven
We're trying to remove our sharp R-1420B microwave oven off the wall. We're having absolutely no luck. How do we get this off the wall?
I just removed our Sharp R-1420B microwave. Unplug the microwave. Start by removing the two bolts from the top cabinet (one left and one right). Remove the decorative screws (one left and one right) from the bottom support bracket. I used a plastic bucket sitting on the range as support under the microwave (you may need a couple different sizes). Once the bucket is in place, pull down on the attachment brackets where the decorative bolts were located near the bottom. I used a vise grip to attach and pull them down, and they came down fairly easy. By doing this, the top of the microwave should become detached from the wall. Once you allow the microwave to tilt down far enough (you may need to move the bucket or use a shorter one), you should be able to lift the bottom of the unit off the lower support bracket. Now you can just pull it out from the wall.
May 16, 2010 | Microwave Ovens
Jennair JMV8208BCS No instructions in box
Hello. the installation of wall mounting bracket is not too difficult. you will need a drill, some bits, and a scrrewdriver. you will also need an electrical outlet at that spot to plug in the microwave.
Jennair makes a bracket kit for each microwave. Call any jennair dealer, have your model # handy and they will get you the bracket you need, also ask specifically for the instructions.
Aug 12, 2009 | Jenn-Air JMV8208A Microwave Oven
Sharp Microwave R-1480 ~ Removing
You need to remove the grill above the door to find two more screws that go straight to the back wall plate. They will be on the left and right side. There are chrome or a gold color. That is the only other way that they mount to the wall.
Good Luck
Nov 17, 2008 | Sharp R-1480 Microwave Oven
Limited space for over the range microwave
You can call Sharp and ask them what current models if any will be drop-in replacements,either using the same mounting hardware or at least the same space.
You can contact Sharp at 1-800-BE-SHARP (1-800-237-4277) or visit them online.
Oct 19, 2008 | Sharp R-1460 Microwave Oven
I replied to your other post on this, but I'll just paste the solution here and get myself 2 FixYa ratings! *grin*
Oct 19, 2008 | Microwave Ovens
Microwave Ovens Logo
22 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
