Question about Lands Phones
The base is connected to a land line, there is power to all hand sets. The phones are new and should not have defective batteries. It says line in use.
SOURCE: No Link To Base Unit
I am having the same problem!
Posted on Apr 08, 2008
SOURCE: phone base set 'in use' led flashes when plugged into the jack
As is usually the case, a very simple solution in the end. Always check every thing even if the info supplied is from a qualified person. The phone came with the wall jack to base cord but it wasn't the origonal one so the phone thought the line was busy because it wasn't receiving any voltage supply as the plug into the base set had transposed 1 with 2 & 3 with 4. Damn I hate it when its that easy. I was talking to another mate about it and he said he had a similar fault to mine & he thought the cord was the issue & he was correct.
Thanks for your time
Brent.
Posted on Nov 29, 2008
  • 205 Answers
SOURCE: phone cannot find base
complite opening phone re connection remove safty try it
Posted on Jul 09, 2009
  • 3 Answers
SOURCE: BT Freestyle 2200
hi just want to help others as desciption aint complete above
Registering a BT Freestyle 2200 handset
1. If there is a handset in the base remove it whilst you are registering the new handset.
2. Press and hold the PAGE button on the base for about 10 seconds until you hear a beep and the In Use light starts flashing.
3. On the handset to be registered, press and hold redial & CALLSd buttons together until display shows 65-.
4. Enter the base number. If this is a new handset then the base number is 1, the display shows 65-1 then PIN. which is normally 0000
5. Enter and registration starts. When the handset beeps and returns to standby registration is complete.
Posted on Jan 13, 2010
  • 5 Answers
SOURCE: Phones won't Register!!
It is possible that you have maxed all of the headsets that can connect to the base. Yes, the base can support 10 headsets, but there is a small chance that in some way you registered more to the base or you purchased a base that had phone registered to it that are not in your possession. Either way, if the base is maxed out, you will not be able to register any additional headsets to it. The only option is to do a factory reset of the base unit if this happens to be the case. This is done as follows according to Uniden Tech Support:
1. Disconnect the power from the base
2. hold down the following three (3) keys: [dnd] + [middle soft key] + [*]
3. While holding down the keys, plug in the base (hold the keys down until you hear a long beep). This is supposedly all it takes to reset the phone.
The way to determine the number of hand sets tied to the phone is to press the intercom key on the base and scroll through the list of phones. if you see more than the number you anticipate still being tied to the base, you will have to utilize the above procedure.
Posted on Mar 09, 2010
Kx-tge474 Why do my new phones have static on all 4 hand sets?
if you are using a land line and have a modem connected to the same landline , it is possible broad band or ADSL interference frequency
there are filters that connect in line to the phone base station to overcome the problem
Oct 30, 2017 | Lands Phones
My uniden phone is not working. All hand sets say Check Tel Line. Will not make or receive calls. Will a dead battery in one handset make all handsets malfunction? Are batteries available?
batteries are available from e-bay
one dead battery will not affect any others
all hand sets make calls and receive calls through the base unit that is connected to the landline
base unit is connected to the landline and operates any hand set that is picked up
make sure all handsets have the end call button pressed as one not pressed after use may keep a line open
call your provider to check the land line to your premises
borrow a neighbours phone and plug it into the socket and see it you get a line on their phone
Oct 30, 2016 | Uniden Lands Phones
My bt4500 is lit up but won't work
that is not HP device,
why not tell what all that is in front of you.
my guess is this device is a home phone connected to land lines.
right? and is acting up and is not HP at all.
have you tested the land line yet with a real old fashion phone?
to see if the land line is even working?, that be first.
we call that a buttt-in-kit, in the olden days. of POTS phones
now mostly dead in USA.
2nd bad, hand set batteries.
3rd , base power pack dead.
we are not hp,
the real HP is here. 100% real, not fake like most the post on our forum are (spam it is or worse)
here they are, HP
zero hits here on phones.......
https://h30434.www3.hp.com/
the BT means Big button,
not HP
4500-b0pilnzm3b4ny2niuscuwyd1-5-0.jpg the words HP do not show up here
Jul 16, 2016 | HP bt450 Bluetooth Wireless Adapter
I want to get 2 phones,1to connect to landline, and 1 by my bed.
this can be overcome by either running a piggy back connection at the input point of the land line and running the extension wire to the other phone
or
by buying a cordless phone set ( 2 phones ) and placing the base set at the point where the existing phone is and the other cordless phone in the room
the base phone set connects to the land line and the second phone is by wireless transmission to that base set
all you will need is a power supply for the second phone as it has a charger as a stand for the phone
Sep 23, 2015 | Cell Phones
Display shows "No line"
The base set has to be connected to the land line. It's telling you:
  • No land line connected
  • The land line is not working
  • The base set is connected to a bad land line outlet.
Apr 11, 2015 | Vtech DECT 6.0 Cordless Phone with Digital...
My phone stop the ring
This phone unit it is a cordless phone hand set unit phone,it is a home land line base phone wright?Yes? Did u tries ring high ring low on the phone hand set functions up and down of the phone itself have a ring functions so u make sure is it not the phone unit functions itself.Did u try other phone unit on that phone land line to make sure it is not the land line phone line problems.U can tries take the corless hand set nocking it on a hard surface lightly a couples times.This could clean some dust and dirt loosen or stuck function buttons.The cordless phone hand set battery it is charging?Yes? Phone might have a weak or dying or a dead litium battery.Tries the phone unit itself unplug/replug it back like about and hour later for phone unit to reboot itself.
Oct 04, 2011 | Lands Phones
I have just inherated the at&t e5634b phone system. I have replaced the batteries in the hand sets. As per the manual I have de-registered each hand set. The problem is that when I register the...
This problem can be caused by the following, A bad battery, (which you say you are all new). A full base memory and a Faulty main base unit
This main base unit can only expand to four handsets and no more. If the base unit has been reset then the assigned numbers for each handset would begin with " handset 1" if they show any other number when reset then it would not have been reset..To re-set main base you will have to
De-Register All Handsets
Unplug the power supply from the base unit then Remove all handsets from the charge cradles and base then Press and hold the PAGE button on the base.
Plug in the power supply again while pressing the PAGE button, Continue pressing PAGE until the IN USE and CHARGING indicators are lit. (this could take up to 10 seconds)
Release the PAGE button All Handsets will display "enter base id".
If this does not solve your problem then you will have to replace the main base
Apr 20, 2017 | AT&T E5634B Phone System w/ Caller ID
I bought a new AT&T 2300 to go with my existing 2365 base and 3 2300 handsets. When I place the new 2300 in the base, after charging it, nothing happens no matter how long I leave the new 2300 in the...
possible that the new hand sets are not compatible with the base as it requires same hand sets as the base for the base to be able to register the handsets
follow the user manual to see if there is a how to register section that will help identify the problem
Jan 30, 2018 | AT&T Lands Phones
Our 5.8gh uniden phones all have static one land phone 3 extension.
disconnect the ac adapter from the base - before you plug the phone back in with power - press and hold down the menu button (center silver button under the led display) and the number "1" and then plug it back in - keep holding those two buttons until the date and time reappears - it worked for me and it didnt erase the phone numbers stored in the base unit.
Jun 01, 2008 | Uniden EXA15580 Cordless Telephone
Wired base unit
Try a simple thing, replace the phone cord that goes from the wall to the phone with a new one. That'll make sure you still have a good phone connection. Cords cheap.
You have a power transformer that plugs into the wall.  See if you can find a replacement at a surplus store or Radio Shack (a different store)  Take the old one with you so you can match the voltage/ampere and connector.  If its new it will work fine.  If its surplus, it's hit or miss.
If that does not work  or you don't want to bother buy as new phone.  With the constant upgrades you might find one with better features you'll like more.  Who knows.
Good luck
Oct 25, 2007 | Dual Maxus 5.8GHz Handset Cordless Phone
Lands Phones Logo
32 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
