Question about Lands Phones
My phones base and cordless have been plugged in since yesterday and I've checked all batteries and connections. Do I need to register with vetch before I can use the phones?
  • 111 Answers
No - do you have the base connected to a landline? - Does the phone display show check tel line? I am assuming this is your typical home cordless phone. Is there power to all the handsets? If the screen is blank - you may have a bad battery. More information would help.
Posted on May 02, 2017
How can I open the base of vetch cordless phone and check internal power connections
The screws that hold such an item together are usually hidden under the rubber feet. Prize them out with a narrow blade screwdriver. Unlikely that anything will have moved inside, but you might find a fuse. Problems with cordless phones is usually the handset batteries failing as they are nearly always charging.
May 31, 2016 | Vtech DECT 6.0 Cordless Phone with Digital...
How do I register my vetch cordless phone?
General - Product Troubleshooting - VTech® Cordless Phones
VTech Communications Inc.Step 1: Place the handset in the base or charger. If PRESS FIND HS 4 SEC ON BASE does not appear on the screen after a few seconds, lift up handset and recradle it in the base or charger. Step 2: On the telephone base, press and hold FIND HANDSET for approximately four seconds.
Product Registration - VTech® Cordless Phones
VTech Communications Inc.Vtech DECT 6.0 cordless phones are among the most advanced and innovative homephones on the ... Product Registration. How do I register my product?
vtech cordless handset, how to register - YouTube
? 3:21
Feb 22, 2015 - Uploaded by Brian Williams
i registered my handset but im not able to call and answer call from my ... you lose your phone you have to de register allphones and start over.
Jan 21, 2016 | VTech Communications CS6114 - cordless...
I have a vetch base of cs6619 and have ordered and received a new hand set Cs 6609 and can not get it registered although it has been charging foe 2 days. Please advise.
Sometimes you have to start from scratch. Remove the battery from all the portable units (including the one at the base station). Then start by setting up the base station.
You might try less drastic steps that are similar if you don't want to lose your directories.
Mar 05, 2015 | Vtech DECT 6.0 Digital Cordless Phone
I have a vetch mod# CS6114 I checked the base unit and it gets power to charge phone but I can't get a dial tone. I even hooked up to another line and still won't work.
This sounds like a registration problem, the
handset must be de-registered from wherever
it thinks it is and then registered to your base.
( I ). First, to de-register a cs6114 handset ---
0. Start by taking off the battery compartment cover.
1. press [menu]
2. scroll up/down to "Settings"
3. enter * 7 8 9 0 #
4. scroll from "Test Base" to "Test Handset", press [select]
4. scroll down to "next page", press [select]
5. scroll down to "Register Clear?", press [select]
6. display asks "Confirm?" or "Register Clear??",
press [select]
7. display reads "Ok" and chirps, press [ off ]
(this is why the cover was off)
9. Wait ~30 seconds, re-connect the battery &
replace the cover
10. display reads "Not Registered"
( III.) To register the cs6114 handset to the base:
1. press [Find Handset] on the base and hold for
~4 sec until the "In Use" lamp lights.
2. press # on the handset and set the handset into
the handset cradle on the base
3. within 30 seconds or so, the handset will either
chirp and display "Handset Registered", then
"Handset #x" or it will say "Registration Failed".
NOTE: the battery must be well charged prior to the
registration process, a weak battery may cause a
"Registration Failed". Charge the battery for a
few hours and try the registration ( III ) again.
NOTE 2: Some cs6114 bases do not have the "In Use"
lamp indicator. To register the handset simply park it
displaying "Not Registered" in the base cradle and wait
for the registration to occur. Pressing # as above may
be required, maybe not.
Good luck !!
Feb 12, 2015 | Vtech DECT 6.0 Cordless Phone with Digital...
Why does my vetch phone say out of range or no powerat base?
Usually that works for a lot of devices, taking the battery out and waiting about 15-20 seconds. Out of range could mean one of two things, It might be telling you that the battery in the handset is low and not able to receive the signal or you have reached the limit for distance, or have crossed into a metal barrier. No power at the base could mean a lose connection at the main unit or wall plug in. It may be a good thing to relocate your base unit, if you can.
Jan 17, 2015 | Vtech cs6429 dect 6.0 digital cordless...
Vetch cordless phone says not registered and will not work....need help?
The handset needs to be registered with the base unit. Enter the model of your VTech phone into the search box at to download a copy of the manual and see how to register the handset to the base.
Aug 02, 2013 | AT&T DECT 6.0 Cordless Phone System with...
My vtech dect 6.0 phone says not registered how do i fix it
I came on here to look for the same solution but it didn't take my comment and so I am sharing what I did from my research, If it says Not registered, press and hold the page button on the base and in about 4 seconds the In Use button will be lit. Release the page button and press the # button. You may have to try this a few times. The first time I tried it, it said Failed. I took the battery out, unplugged the phone from the wall and started all over again. Good luck.
Jan 26, 2011 | Vtech DECT 6.0 Digital Cordless Phone
One of my cordless phones says not registered. How do I fix that? Also, another phone says check battery. Where can I get another battery? Warranty?
Put the non-registered handset in the master base unit. Unplug the base unit for about 10 seconds and plug it back in. Wait for a message to change on the handset and press and hold the handset locator button for 4 seconds. This will re-register the handset. Do not remove the handset from the base while performing the above steps. Good Luck!
Nov 09, 2010 | AT&T DECT 6.0 Cordless Phone System with...
Lands Phones Logo
37 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
