Question about Lands Phones
Phone is still flashing line in use. It's been plugged in since yesterday. How do I register?
My phones base and cordless have been plugged in since yesterday and I've checked all batteries and connections. Do I need to register with vetch before I can use the phones?
No - do you have the base connected to a landline? - Does the phone display show check tel line? I am assuming this is your typical home cordless phone. Is there power to all the handsets? If the screen is blank - you may have a bad battery. More information would help.
May 02, 2017 | Lands Phones
I have no ringtone and the phone is flashing base. All okay yesterday. I have tried it on the other base and it is the same, so I assume it is the handset.
check radio base where one of the bases plugs into phone line. Check power and check phone line plugged in properly.
All other bases are just charging phones. !
Nov 12, 2015 | Siemens C300A2 C300A-2 C300A 2 Gigaset 2...
I have a uniden Tru9466 base station and a uniden TWX 977 that the later that was previously registered with the first displayed a out of range notice so I went thru the process in the owner's manual...
Welcome to FixYa.
  1. Turn OFF your handset (TWX977) and any other handset registered to the base (9466).
  2. Unplug the base from its power source.
  3. Unplug the phone line from the base.
  4. Wait for 15 mins.
  5. Plug back the power source and the phone line.
  6. Turn ON the handset (TWX977)
  7. Reset the handset (TW977) by doing the following:
  • Press the MENU soft key. Select the DEREGISTRATION submenu.
  • ARE YOU SURE? appears. Move the cursor to select YES. Press the OK soft key.
  • To clear other handset information, please follow these steps:
  • From the handset, press and hold [ ] and [#] for more than 5 seconds. Select the DEREGISTER HS submenu.
  • Move the cursor to select the handset ID to be de-registered from the list, and then press the OK soft key.
  • DEREGISTER HS appears. Move the cursor to select YES. Press the OK soft key.
  • ARE YOU SURE? appears. Move the cursor to select YES, and then press the OK soft key. You will hear a confirmation tone.
8. Register the handset by doing the following:
  • With the base in standby, press the MENU soft key.
  • Move the cursor to select REGISTER HANDSET. Press the OK soft key.
  • On the handset, press and hold [#] until you hear a beep.
  • While the handset is registering, HANDSET REGISTERING will appear in the LCD. When REGISTRATION
  • COMPLETE is displayed; the handset has been registered to the base. If REGISTRATION FAILED appears,
  • please try these steps again.
Thank you for using FixYa.
Have a great day.
Aug 22, 2011 | Uniden TRU9466 Cordless Phone
Don't I have to connect the phone to a telephone line? I don't see where i can place a phone wire in the phone. Also, I have the handset in the base but it doesn't say that it is registering. It keeps...
Often the line cord connection is on the back of the base unit or underneath, usually near where the AC cord plugs into the base unit that powers it. The handset needs to charge before it will be ready to use, sometimes for 12 hours. If after charging, it still is not registered automatically then try manually registering it to the base unit per the directions in the manual.
Dec 09, 2010 | Uniden Cordless Phone
Handset out of range
I'll give it a shot. Have you tried re-regestering the handset? Press and hold down the "end" key (on most models it looks like a red handset) while holding that key down, press and hold the # key, after a few seconds the unit should beep and show:
Deregister HS
Useing the four-way key select "Base unavailable" and press the menu key The LCD display should then show :
"Which Base?"
Base #1
Select base one and then the display will show
"Base Unavailible
Select "Yes."
Your handset is now unregistered. To re-Register the phone to the base do the following. If the base unit has a charging cradle, just set the handset in it and it should register on its own, if you have a cordeed base, or the unit will not register when you set it in the cradle on the base go to menu and select register handset, then press and hold the # key on the handset for 2 - 3 seconds, it should beep and then start the registration process. If you have 6 handsets registered to your base, you will need to de-register teh non-working unit from the bases memrey before you will be able to re-register the handset.
Jun 14, 2010 | Uniden DECT 6.0 Cordless Phone ID
Bought phone EX18560 Series yesterday. floolowed instructions to charge. Today I came home from work, plugged in telephone jack. phone will not turn on. Attempted to re-register (4X's). Led flashes....
I have two older (2002) model cordless Uniden phones that require the handsets to return to their original factory bases. If they have rested on another Uniden base, even of the same model, there is no dialup tone. Replace to the original base and you should be back in service.
Aug 11, 2008 | Uniden Lands Phones
I need to reactivate my uniden cordless phone with remote extra handset. It was on a second phone line in my home, and that phoneline has been cancelled. Now, both units are charged, but and plugged into...
This should get the job done for you!
To re-register DXA14588-2 handsets:
  1. Pick up the handset from the base. Press and hold [find handset] on the base.
  2. While holding [find handset], place the handset in the base. The charge/in use LED on the base begins to flash, indicating the base is registering the handset. Wait for at least five seconds.
  3. Pick up the handset from the base and press [talk/flash]. If the display shows TALK, the handset is registered. If not, place the handset in the base to try again.
  4. Press [end].
  5. Place the next handset in the base and wait for at least five seconds. No need to hold [find handset] this time.
  6. Repeat steps 3 - with any other handsets you have.
Please let me know if you have any further questions.
Good Luck!
Aug 11, 2008 | Lands Phones
How do I add an extension handset to my current config?
IF it was a used handset it was likely registered to another base. I just switched bases (1line to a 2 line base). I had to "deregister" the handsets from the old base. I am not sure if you can deregister if the old base is not present? With the old base plugged into power I hit the "function key" at the bottom left of the handset and scrolled down to initial settings. Under registration is "deregistration". I selected that and it put the handset back to its default out of the box. Then simply hit the mute button on the New base and OK on the handset. Worked for all 5 of my old handsets.
Hope this helps
Jan 27, 2008 | Panasonic KX TGA270S Cordless Expansion...
Uniden DSS7955 Cordless phone problems
I had the same problem!
What you need to do is hold the "end" and "#" key for 5 sec, which will deregister the headset then all you would have to do is place it back in the base for it to registered again.
Nov 25, 2007 | Uniden Lands Phones
No Link to Base
to re-register the phone, hold down the "handset locator" button on the base untill he "charge" light flashes. then, on the phone, hold down the flash/call waiting button until the LCD screen says "handset registering." if after it registers it says "error!!!" then retry. that is what it says in the instructional booklet, but i have not done this successfully. mine keeps saying error.
Oct 22, 2007 | Panasonic KX-TG2313 Cordless Phone
Lands Phones Logo
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
