Question about Husqvarna Garden
My husqvarna 224L bogs down when accellerate i have cleaned spark arrester and carberater still bobbing down need help
  • 117 Answers
Check fuel filter to make sure nothing is obstructing the flow of gas.
Posted on May 02, 2017
How much oil does a husqvarna 224l use
The manual does not call for a specific volume of oil. Make sure to check the level using the dip stick and make sure the oil level is approximately half way up the dip stick. If oil is needed, SAE10W40 is recommended.
Sep 01, 2014 | Husqvarna 224l Gas Powered Line Trimmer, 4...
1. [Broken Throttle cable?] I would start by making sure that when you press trigger you see the throttle cable moving linkage on carb.
2. [Spark arrester clogged?] There is a small metal screen at muffler that is known for getting clogged with carbon deposits and will prevent air/exhaust from leaving engine properly, causing it to bogg down. Try removing it and test run, if that fixes it clean or replace spark arrester.
3. [Incorrect spark plug?] If spark plug was changed recently and is not the correct one for this model trimmer it can do that. Or, if spark plug is fouled(too much carbon built up/or incorrect gap).
4. [Bad carburetor?] if there has been water in fuel, or carb has stiff diaphram inside it will not run properly.
5. [Needs service?] if none of the above work you may have to take it in for repair.
Aug 18, 2014 | Husqvarna 323R 24.5cc 2 Stroke Gas Powered...
Husqvarna husky boy 50cc My 6 year old son has a husky boy 50cc it starts up an ticks over fine but wen he turns the accelerator the engine starts to cut out then when he releases the accelerator it fires...
If equipped with a spark arrester then you should remove, clean and reinstall. If you don't have a spark arrester then you need to have your carb looked at
Jul 18, 2014 | Garden
I need to clean an air filter for a john deere 55ev chainsaw
just wash filter in petrol and blow of with compressed air , I would also remove spark arrester from exhaust and clean that by burning carbon of then blowing with compressed air , if you chainsaw still runs bad it needs carby serviced and retuned .
Mar 28, 2014 | John Deere Garden
Saw bogs down
First clean out or replace the air filter. I have also seen spark arrester screens plug up in the muffler. The screen can be cleaned with carb cleaner.
Aug 02, 2013 | Garden
Weed eater bogs down
First if it has adjustable screws on carb. Turn one or if two both about 1/2 turn cw and then back to starting position. Sometimes trash gets in the jets and this will clear. If no help then if you can find reasonable carb. (under $20) buy and install if not cheap then buy rebuild kit. But when you rebuild make note of settings of set screws by counting turns as you turn cw to bottom.
Nov 24, 2017 | Garden
Chain saw stalls out
If I understand your problem the saw starts and accellerates normally but bogs down when making a cut. If true only the "H" needle valve needs adjustment. This is the best explanation and procedure I have found.
Carburetor Adjustment by
  • CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
  • Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
  • Clean the spark arrestor and muffler; if the saw cannot exhale it cannot inhale.
  • There are 2 wav (sound - idle & full - may not be highlighted) files that I find most helpful, I think you will too.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck Captain. HTH
Mar 13, 2010 | Husqvarna Chain Saw 20" Bar
Echo PB-413H bogs down
Echo tools have a screen in the muffler to arrest sparks. Take off the muffler and remove this screen
Jun 03, 2009 | Echo Inc. 44 CC, Carb Certified Backpack...
The trimmer will not run when i give it gas
When 2 cycle engines preform as you have stated...the main problem is a carbon build up on the spark arresting screen on the muffler, it needs to be cleaned or replaced with a new one
Apr 04, 2009 | Garden
Garden Logo
59 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
