Question about Dyson Vacuums
Hi I replaced the belts on the dyson dc14.They were all streached out. Now the brush bar turns all the time. Does this mean the cluch is bad?
Alighnment is good, as the cluch level appears to pivot okay when the handle is tilted back.
geordie rob
  • 7 Answers
SOURCE: roller brush is not turning on a dyson DC14
http://www.dyson.co.uk/support/help.asp?product=DC07-SY&article=527
here's a link that might help
good luck
Posted on Dec 29, 2008
  • 134 Answers
SOURCE: beater bar belt needs replacedon a dyson DC14 animal
Remove the glide plate at the bottom of rhe machine. Remove brush and broken belt. Fit new belt and re install brush. Fit glide plate, job done.
Its in the instruction book
Posted on Mar 08, 2009
ukvacfan
  • 328 Answers
SOURCE: replace belt and dyson vacuam cleaner, model dc14
If the DC14 has a brush protected aspect i.e. a switch on the front that puts the drive belt off, the drive belt would have to be replaced by a professional repairer as this can't be done at home.
If the model doesn't have the brush control at the front, flip the Dyson over so that the beater bar is in the air and locate three/four screws that can be taken out with a coin or blunt knife. A turn is all that is required on those notches and the sole plate should come off once these notches have been undone. Then check the belt - if it has broken lift out the beater bar in the middle with your hand and replace the sections necessary. Be careful to check that the end caps are pushed in properly otherwise the beater bar will not sit correctly.
Posted on Apr 02, 2009
  • 7 Answers
SOURCE: My Dyson Animal 14 beater brush will not turn.
It MAY be a clutch issue. I had a similar problem with my DC07 Animal recently a posted a solution elsewhere on this site, but here's the summary. To reset the clutch on my model, recline the vacuum, turn it on it's side and slowly change the carpet/bare floor knob from one setting to the other about 6 times. This apparently reset the clutch and now it works fine. You may also wish to call DYSON. They're very helpful and walk you through troubleshooting before recommending servicing. Their number is 1-866-693-9766. They'll need your model and serial number (located on bottom of uinit).
Posted on Apr 18, 2009
  • 3 Answers
SOURCE: Dyson DC14 Brush Bar won't turn
You don't need to take it for repairs, I just corrected the same problem on the phone with a tech. Have the head on your lap, make sure the end nearest the little belt has the rounded side of the bar facing you. The squared off end faces towards the machine. Place your left hand pointy finger under the bar (the 2 inch bar next to the little belt) and lift up, while finessing the loose end of the bar into place, with the rounded part still facing you. Then it sort of snaps into place. Now, replace the face plate. In the upright mode, starting at the carpet dial, switch the dial back and forth between carpet and bare floor, ten times. (the tech actually referred to this as re-setting the vac. LOL) Plug the vac in, incline the hand, and start. It should work. It didn't for me the first time and made a horrible sound. That meant I had to go and repeat the process again, but lo and behold, IT WORKED! When in doubt, call the tech and don't let them get away from you; have them stay on the line until the problem is resolved.
Posted on Oct 10, 2009
All belts are good but brush will not turn
Hi Nabil, it's Jack at Dyson.
If you have a DC14 and the brush bar isn't rotating, it's worth checking to make sure the brush control on the cleaner head is set to 'Carpets', and not 'Hard floors'.
http://www.dyson.co.uk/support/dc14/dc14-all-floors/my-machine-is-not-working/i-can-see-something-wrong-visual/i-can-see-something-wrong-visual/my-brushbar-is-not-rotating2/does-the-brushbar-turn-with-the-power-on
Tip: The brush bar will never rotate when the machine is standing upright, so make sure you recline it down into the normal vacuuming position before testing it.
If you're confident the brush control is set correctly, but the brush bar still won't rotate when the vacuum is reclined, please get in touch directly so we can help further. You can reach our experts by calling 0800 298 0298 (UK), 1-866-693-9766 (US), or 1-877-397-6622 (CA).
Best wishes,
Jack
Dyson Online Customer Support
www.dyson.com
Aug 19, 2013 | Dyson DC14 All floors Bagless Upright...
Dyson dc14 brushes not turning
Hi there, it's Jack at Dyson.
I'm sorry to hear your DC14's brush bar isn't rotating. This could just mean that the brush control is set to 'Hard floors' rather than 'Carpets'. To check for this, please take a look at our Support guide:
If you'd like further advice after running through these checks, you can reach our freephone customer Helpline on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Jack
http://www.dyson.com
Mar 04, 2013 | Dyson DC14 Bagless Upright Cyclonic Vacuum
Dyson dc14 brush bar is not turning at all. Everything else seems to be fine. I just replaced the brush bar but still no movement. What else could it be?
I'm sorry to hear you're having difficulty with your DC14 Animal. If the brushbar doesn't rotate, please check you have the brush control set to 'Carpets', not 'Hard floors'. The brushbar will not rotate when the machine is standing upright, so please recline it into the vacuuming position before testing it.
If this doesn't resolve the issue, please give our Helpline a call on 0800 298 0298 (UK), or 1-866-693-9766 (US), so we can provide further assistance.
Best wishes,
Jack
Mar 24, 2012 | Dyson DC14 Animal Bagless Upright Cyclonic...
The belt on my Dyson DC14 will not turn. How much will you charge to change the belt.
Sorry to hear you're experiencing a problem with your Dyson. If your DC14 doesn't have a Brush Control option, you should be able to replace the belt yourself - you can find out how to do this here:
http://www.dyson.co.uk/support/help.asp?article=635&product=DC14-SY-STD
If your DC14 has a Brush Control, try checking for and removing anything blocking the brush bar. You can find out how to do this here:
http://www.dyson.co.uk/support/help.asp?article=668&product=DC14-ANIMAL
If you require further assistance, please get in touch with us free, on 08002980298, or 1866MYDYSON (US), so we can run through some checks over the phone.
Kind regards,
Jack
Dyson Customer Service
Feb 26, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
On the DC14 the brush bar is not spinning. The belt is still attached and there is suction. Any ideas ?
Even though the belt is intact it can still be stretched and worn and that would cause the brush to not turn. Here is the belt you need:
Dyson DC14 Belt
Feb 09, 2010 | Dyson DC14 All floors Bagless Upright...
It wont vaccum
If the brush isn't turning you need to replace the belts. You can get replacement belts here:
Dyson DC14 Belts
Nov 21, 2009 | Dyson DC14 All floors Bagless Upright...
When I tilt back handel and turn dial to carpet It makes a loud grinding noise
On a Dyson this engages the brush bar. Two possible faults: Debris (hair etc) caught in brush bar - cut out with knife. Or - damaged drive belt - pieces of belt striking casing. Last, but unlikely cause, debris in bearings of brush bar - replace brush bar.
Jul 29, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dyson vacuum cleaner-brush bar is frozen
Hi If your Dyson has a brush protection design - i.e. roller bar on the top of the hood on the left hand side then the DYson can't be repaired by you- serviceman or professional care can replace it.
However if the Dyson doesn't have the roller bar on top of the hood, flip the machine over so that the beater brush is facing upwards, locate three/four screw heads that can be undone with a coin and remove the sole plate assembly. This should give you a clean view of the brush bar, drive belt and dirt channel. Ensure everything is clean espcially if the brush bar has lots of hair or threads tightly corded around. Then locate the drive belt and check to see if it has snapped. Grasp the beater bar gently upwards and the belt and brush can then be removed. Fit a new belt on carefully and check the tension as it will be tight.
Apr 05, 2009 | Dyson DC14 All floors Bagless Upright...
Vacuums Logo
32 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
