Question about Vacuums
Hi there I have an Elektrolux CM3 Vacuum Cleaner, it works OK and looks like new.
But it turns off all the time. Then it needs a gentle push,just by hand, a soft nod and it can be turn on again, by the Remote button. Mysteriously huh? Hope you can help Thank You Per
  • 5,412 Answers
I can find no camera with this make and model reference
Posted on May 02, 2017
  • Per Blaaberg
    Per Blaaberg May 03, 2017
    sorry, should be Vacuum
  • Tony Parsons
    Tony Parsons May 03, 2017
    That's OK, thought you might get more assistance by posting in a different forum.
We had an older dyson vacuum that worked great until it had to be replaced and now our new one it works great on short carpet but is very difficult to push on thicker carpet.
Hi Ronnie, it's Jack at Dyson.
I'm sorry to hear you're having difficulty using your new Dyson vacuum on this particular type of deeper-pile carpet. It's possible your new machine has higher suction at the cleaner head, and this could mean it needs slightly higher push-force on certain carpets with deeper, denser pile, or thick underlay. You may find it helps to use the vacuum with the brush bar switched - carpet manufacturers will sometimes advise vacuuming deep-pile carpets in this way.
However, I would encourage you to get in touch with us directly so we can take some further details about the issue. When you have your Dyson vacuum easily to hand, please call the Dyson Customer Helpline on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU). Our experts will be happy to discuss your concerns.
We'll look forward to speaking with you.
Jun 03, 2015 | Dyson Vacuums
I can't push my Dyson Dc33 on my new works backwards ok but not pushing forward?
Hi Fran, it's Jack at Dyson.
DC33 is engineered to work effectively on both hard and carpeted flooring. The cleaner head is engineered to adjust automatically for different floor types and carpet piles. You can also turn off the brush bar for hard floors and delicate rugs, using the brush control on the cleaner head.
I'm sorry to hear you're having difficulty pushing your machine forward on this particular type of new carpeting. If your DC33 worked effectively before the new carpeting was fitted, it doesn't sound like there's an issue with the vacuum itself. However, we'd appreciate the opportunity to take some further details about the issue, and may be able to suggest a resolution. You may also want to consider contacting the carpeting manufacturer directly, as they should be able to recommend the best way of caring for this specific carpeting.
When you have your DC33 easily to hand, please give the Dyson Customer Helpline a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Feb 13, 2015 | Dyson DC33 Multi-Floor Upright Bagless...
New belt now harder to push than before
the new belt already snapped is what it sounds like try taking it into guarantee vacuum and sewing center
Mar 26, 2014 | Dirt Devil Featherlite Bagless Vacuum...
I need instructions on how to change the belt on my Hoover Model U4264-930 vaccum.
Tool Needed, flat head screwdriver (larger one works a little better). Serious Safety Precaution: Make sure unit is unplugged. Preliminary: Check: that nothing is caught like threads etc, preventing roller brush from turning. I've had this model vacuum 10 years and have pulled threads out countless times. However it still has the original belt on it. To change belt: 1.) There is a plastic plate underneath roller, towards front.. Pry the 3 tabs at front, the plate hinges downward slightly (to clear the front tabs). Next, there are 2 little clips at bottom of plate. Insert screw driver at each of these clips to fully release the plate the rest of the way. (Or it may even come off without having to pry back on these. The plastic clips need pushed towards front, to clear the ridge that catches towards the back). Pry one, then the other, clip forward, while gently pulling the plate the rest of the way out. (Gentle prying will assure it will snap back together OK, so you still get a good seal.) You now should see the whole roller brush. 2.) Remove the shell/motor cover: To do this, a.) pull off the rug height adjuster lever, and take not where you put it so you won't loose it. b.) push foot release down and keep vacuum bag in the vacuuming/hinged/operating position (not the upright/locked position), and position cleaner on it's side, or upside down. c. Pry around the bottom edge, starting at right corner, then go around, prying in about 4 different places. Shell/motor cover will now easily pull off (upward and out towards front), exposing motor shaft and light bulb. 3.) remove belt from motor shaft. 4. slide roller and old belt out the bottom. 5.) remove old and place new belt on roller 6.) slide roller back into place. 7.) wrap other end of belt on motor shaft. 8.) shell cover, rug height adjuster knob, and bottom plate snap back into place. check that roller turns without much effort. 9.) It now should be ready to plug in and vacuum.
Aug 21, 2011 | Hoover Soft Light Supreme U4262-930 Bagged...
How do you open a wertheim 2000P vacuum cleaner?
SmartAlec from here. The ET2000 has a latch that is located at the very end of the machine lid (about 6 cm in front of where hose clips in. If you sit the machine up on its back end you should see the black lever that needs to be pushed in. Now I will also say that it is possible that you have actually been pushing this but the lid still wont open, this is because every now and again the whole latch moves itself out of alignment by about a milimetre. The easy fix for this is a gentle screw drive to assist the relesing of the catch, this needs to be gently pushed in at the same time as squeezing the latch (hand at top of latch screwdriver at base kind of toward the middle of machine). You should be able to get it open like this with only light pressure. Now of course if you need bags or filters please visit us at
Kind regards Alec
Aug 02, 2010 | Vacuums
My vacuum cleaner start up fine, then quickly
Hi There,
This is a telltale sign that your vacuum cleaner is clogged. When the motor makes the higher pitched louder noise, your motor is not able to pull air through it, and has to strain harder because it's not able to breath.
Because you have already narrowed it down, that the noise only happens when you put the wand back into the vacuum, this means that you clog is definitely in the bottom section of the vacuum cleaner. Most clogs on upright vacuum cleaner occur right at the suction port behind the roller brushes on the bottom of the machine. Turn the vacuum upside down so that the brushes are facing upwards. Unscrew the bottom plate of the machine so that you may access the roller brush and belt. Look behind the brush roller for the opening of the vacuum where the suction port it. Look inside here and see if you can visibly see anything lodged inside. Sometimes just pushing a long screw driver into this hole can dislodge the obstruction.
If you aren't able to see anything in this port, and the screw driver doesn't dislodge it, look inside the small section of how that the wand connects into, and try pushing your screw driver down this hose to see if you can dislodge it from this part.
Sometimes a metal hanger can also effectively unclog hoses on vacuum cleaners, but just be careful that the hanger doesn't tear the lower hose section while you're pushing it through.
Also if you have another vacuum in the home, using the hose from the other vacuum and putting it inside the lower hose, or the suction port behind the brushes while you're pushing with the screw driver will also many times dislodge the obstruction easier.
Please let me know if this was able to unclog the vacuum cleaner, and I'd be more then happy to try and do some more advanced diagnosing with you for your vacuum cleaner.
If this was helpful to you, please help other Fixya users find this repair by rating helpful. This is greatly appreciated, and is what keeps Fixya repair experts continue giving free advice on the site.
Thanks so much,
Chris J.
Apr 11, 2010 | Kenmore Progressive 35922 Bagged Upright...
Beater bar on Dyson upright won't turn when handle is lowered
I have finally fixed my sister's dyson dc 15 beater bar problem. It was just 2 tiny broken wires connect to circuit board lead to the beater bar. The wires broke where they go through the black rubber gommet. You need a torx screwdriver tx 15 to remove 2 plastic covers to access the wires. When looking at the front of the vacuum, the gray covers located on the right side of the vacuum. 1 big cover with a black rubber gasket and other small gray cover is on the rotating ball area.
This my new year resolution is to warn people not to buy Dyson vacuum cleaner ( Junk) design to break down! Shame on you Dyson!!!! Save your money find good old vacuum cleaner with metal parts.
Happy New Year!
Dec 20, 2008 | Dyson DC15 All Floors - The Ball Bagless...
Electrolux ambassdor will not run after pluggen in
Greeting from GoVacuum,
On all Electrolux canister vacuum cleaners, there is a kill switch, that will not allow the machine to turn on without a bag in it. Sometimes when replacing the bag, the bag is placed in a position where the switch is not being activated.
When you open the bag housing, it should look like this;
You'll notice in the bottom right corner of the bag housing, the kill switch to the vacuum cleaner.
Try plugging the vacuum cleaner in, and while you are pressing this kill switch down, turn on the vacuum cleaner. Does the vacuum cleaner turn on/off when you push/release the kill switch? If it does, simply just get a new bag, and make sure that the new bag is covering the kill switch, and close the door of the vacuum cleaner.
If it still doesn't start, let me know and I'll try to help you diagnosis the machine differently. I'd say that 6 out of 10 times, this kill switch is the problem.
I hope this helps you. Please email me with any questions, or if this fix doesn't make your vacuum work. I really enjoy sharing my passion, and expertise in repairing vacuum cleaners.
Chris Jones
Oct 03, 2008 | Electrolux Vacuums
Vacuums Logo
48 people viewed this question
Top Vacuums Experts
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
