Question about Honeywell Heating & Cooling
Thermostat on honeywell is set at 21.when it comes on it gets too hot.Should it not get hotter when it reaches 21.It rises to 24 and above.
  • Honeywell Master
  • 1,925 Answers
Plug the hole where the wire comes through the wall. Then be sure the air is not blowing right on it. Make sure you are set for auto fan. It's also possible it's humidity related or minimum run time related but that can even be confusing to me at times so I won't explain. Good Luck!!
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Posted on May 02, 2017
Testimonial: "Thank you,J Preston"
    Top Expert:
  • Honeywell Master
  • 26,730 Answers
Check it is wired correctly or it may be faulty.
I have a Honeywell CT87K thermostat. I wish to REVERSE it's functionality
Your existing thermostat is not capable of doing what you want it to. Instead, install a "heating and AC" type thermostat, and hook your fan to the AC (cooling) side.
Apr 13, 2018 | Honeywell Heating & Cooling
My upstairs temperature is 80 degrees and the downstairs is 69 Honeywell focus pro th6000 is set at 69. Why is the upstairs so drastically hot?unit is located upstairs& thermostat is downstairs
if there is no control of air movement between floors and you have it on cooling then any cold air will go down to the lower floor
or alternately if you have it set on heating all the hot air will rise to the upper floor
where is the system located (upstairs or down stairs ) and where is the thermostat located
to get control close any upstairs to down stairs doors or erect a heavy curtain across the stair well
Dec 17, 2016 | Honeywell Heating & Cooling
Dip switch settings rthl2310
Check for cold air inside the wall behind the thermostat, a cold wall, and area that is getting hot or cold air blowing on the thermostat. Last, the heater may not be compatible with some digital thermostats. Honeywell Customer Care toll-free at 1-800-468-1502.
Aug 29, 2014 | Honeywell Programmable Thermostat Heater
Why can't I lower my honeywell 8500 below 67 on cool?
With a two story house you have to be aware that cold air flows downwards so any cold air coming from an ac unit will flow downstairs( normally down the stairway) so unless you can close off the down stairs then the up stairs unit will be cooling downstairs as well. Ac units have a thermostat located in the air intake and it cools until the cold air has risen to that point. In effect the space above the ac unit will be hotter than the floor. Knowing how they work ,you can see that the upstairs unit will never reach the set temperature because the cold air is continually heating from the house and will never get to the top thermostat.
So your solutions are
1-- fit controls that restrict the cold air from leaving the upper floor (Doors)
2--don't run the upper ac unit unless you are living up there (waste of money
)3 place an ac in each upper room and keep the room door closed
Aug 12, 2014 | Heating & Cooling
Why does furnace fan run continuously?
No on the thermosat go and check fan is not on the summer switch setting , if the fan is running it could be the AFC automatic fan control not shutting the fan off
Dec 29, 2012 | Honeywell Heating & Cooling
How to set the day with the Honeywell vision pro TH800 series thermostat screen
Press the "system" button
Then press and hold the center blank button till the advanced functions menu comes up...
Then set the year, month, and date and the day will be correct
Check out pages 21 and 22 of this manual...
http://www.honeywell-thermostat.com/manuals/th8321u1006manual.pdf
heatman101
May 11, 2011 | Honeywell Heating & Cooling
We have the honeywell thermostat: th2100d1009 1A/24 VAC Why would the heat shut off with this thermostat while no one was home??? We always leave the heat on.
May be it reached the thermostat setting. And one humble advise, please do not keep a/c on for long time when no one is there. It's not safety.
Dec 11, 2010 | Honeywell Heating & Cooling
I can't get my Air Conditioner to come on ?
Clean the filters of the air conditioner. Also, if the unit has been running for a few years without proper maintenance you must expect lots of dust in the evaporator unit. This is usually easy to clean with compressed air.
May 21, 2009 | Honeywell CT87B ROUND HEATING&COOLING...
Thermostat not shutting off heat.
has the thermostat been programed to tell it what type of system you are using. If you look in the papper work you should find where it ells you to hold down the button lower left and top right button i think those are the two i don't have the papper work with me right now but i can get if you need more information on how to set it
Jan 21, 2009 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
37 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
