Question about Coffee Makers & Espresso Machines
I own a ECAM45.760 i noticed in the empty grounds container is a fair bit of water ?? I ,even coffee grounds behind towards the back of the machine unhappy as the machine is only 2 years old.
SOURCE: Saeco Italia sensor problem
In order to reset this, you must remove the drip tray while the unit is powered up or it won't know that it has been emptied.
Posted on Feb 15, 2008
dutchman05
  • 487 Answers
SOURCE: saeco italia
ok turn the machine on and wait till warmed up. Open door while machine is on and remove the dreg drawer. This you always need to do when the machine is on otherwise it will not reset.
flashing means dreg drawer steady means coffee beans
Posted on Apr 16, 2008
SOURCE: Saeco Vienna: water does not go through to the main unit
I had the same problem and got on the Saeco US website and talked to an online support person. She downloaded me a couple of pages of "fixes", I tried them and they worked! You have to take the two screws out of the brew group, remove the spring and a little clear plastic ball. Then clean out the hole thoroughly. I stuck a toothpick up into it from underneath to clean out the coffee that was stuck in the hole. I then put it back together and now it works perfectly.
Posted on Aug 02, 2008
  • 4 Answers
SOURCE: Saeco Coffee maker container is leaking
OK, I finally called Saeco. There are about four rubber rings that you need to get. The one for the water resevoir is a big thick black ring and once you get it and look at the new and the old, you can see why it is leaking. Anyway, fixes it no problem.
The overflow in the drip tray? There are two rings in the back of the machine that will fix that problem. Problem? I got them, but haven't put it on there because it very hard to get in there.
Last one, the ring around the coffee puck maker (what do you call that part) It's the piston that catches the coffe and raises up to tamp it down, then holds it as the water goes through. ANyway, big ring around that. If you aren't getting a nice crema on top, that ring will cure that.
I saw get all four, replace them all at once and then descale the coffee maker and be done with it. You'll be working like new in a few hours or maintenance. For most of us, it's been like 3 years anyway, time to do it.
Lastly, when you call Saeco, (Pronounced I found our SA Yey Co) ask for the directions for cleaning out the grinder. Even has notes on how to get it back together with all the adjustments in the right spots.
The rep on the phone says she likes this model better than most fo the new ones.
Posted on Dec 10, 2008
  • 1089 Answers
SOURCE: need to take out brew group jammed
Hi
Look on the left side where the box should be. In the left side towards the botton there is a long opening. Take plastic knife and slide it in while the machine is on and blinking and see if the brew unit will cycle. The drip tray has to be in for this to work. There is a metal bar that has to be pushed toward the rear of the machine to cycle the brew unit.
Posted on May 22, 2009
Empty ground container issue
Once you have the drip tray out and the grounds container out - look inside the unit and clean any grounds that are still in there. Look for a switch that might be sticking (because it's cover with coffee residue) clean everything and check for freedom of movement.
Nov 27, 2014 | DeLonghi ESAM6620 Prima Donna Bean-to-Cup...
Where is the ground coffee shoot?
Open the door and you will see four bins top right is the bean container - bottom right is the water container - bottom left is the waste container - top left is and empty storage bin - remove the top left bin and you will see a flap door - lift the door up and insert your ground coffee.
Jul 18, 2014 | Miele CVA 4066 Stainless Steel
Hi, my tchibo coffee machine display is showing bean container empty when the container is full of coffee beans.I have removed the container and made sure it is there is nothing obstructing the tube.i have...
Hello
Push "Off" on the coffee maker's control panel. Unplug the coffee maker, and allow the machine to cool down completely. Remove the coffee bean container by lifting up on it and sliding it out. Wipe it out daily with a damp cloth, and slide it back into the coffee maker. Press down on the handle to click the container into place.
Dump out the water in the water container,Wipe out the water container with a damp cloth. Refill the water container with clear drinking water.
Remove the dump box and drip tray, and empty them.Wipe each one down with a damp cloth. Open the service door and push "Press." Remove the brew group by its handle, and rinse if off in a sink with hot water. Use the key provided to unscrew the plastic pin holding the metal filters together. Rinse each one separately. Put the filter back together and dry the separate parts with a towel.
Mix a package of descaler with the water in the water container every four to six months to rid the coffee machine of mineral deposits. Plug in the coffee machine, and select "On." Select the "Hot Water" button, and position the steam valve over the drip tray. Dispense two thirds of the descaler and water into a container in 15 minute intervals by turning the steam valve counterclockwise to dispense and clockwise to shut off the flow.
Let the coffee machine heat up fully, and then dispense the remaining descaler and water by turning the steam valve counterclockwise to empty the water container. Press "Off" to turn the machine off.
If this does not work then you might require a technician.
THANK YOU FOR VISITING FIXYA
Feb 10, 2011 | Coffee Makers & Espresso Machines
Water leaks into side small reservoir, under the grinder.(normally there is only a bit of dry ground coffee. I need to empty it twice a day, because it fills up to the edge. Big water Reservoir at bottom...
Hi
Sounds like your drain is getting plugged with coffee residue. Remove your brw unit. There is an injector that has 2 orange o-rings in it in the back. That pocket below it is filling with water. There is a drain that is to the bottom left that goes into the drip tray in front. Use a prob of some kind that is about 12" long that you can stick down and forward in the drain pocket. Work it towards the fron and you should open the drain again. it fills with oils, so use some hot sudzy water and clean it out.
Oct 30, 2010 | Saeco Royal Digital Plus Coffee...
Red Light 28 is flashing even when dregs are emptied
Check the edge of the container that goes in to the machine there is a small part that sticks out, it is possible that that piece is not touching the microswitch in the machine. Remove the drain tray and the dregs tray, check the corners of the machine for loose coffee grounds.
May 31, 2009 | Gaggia Syncrony Compact Coffee...
Delonghi EAM 3400 keeps saying "Empty Grounds Container"
I think the microswitch that sensors the front door is not activated. Try to find it and "give it a massage" The machine resets the counter for the grounds container every time the door switch is activated.
Rgds
Michael
Dec 19, 2008 | DeLonghi Esclusivo Magnifica ESAM3300...
I can't get the coffee grounds plastic dispenser back into the
remove the used grounds container and place a folded piece of paper where the grounds container touches the micro switch ( that is in a slot in the left side where the container enters approx 8cm inside) and then restart the machine and the grounds container will now be able to enter, remember to remove the folded paper before inserting the container
Nov 18, 2008 | Saeco Vienna Deluxe
Descaling?
With the selector buttons find Descaling and press OK
This process takes about 35 minutes
1. Empty the water tank, drip tray and grounds container.
2. Insert tray and grounds container, refill tank with with 0.5 Lt. of water and add descaling agent (not the pill or powder used for clean cycle) to tank. Make sure its completely dissolved.
3. Place a container or cup under the steam wand large enough to hold 0.5 lt.
Display says Descaling and press OK
4. Press the water button
Display says Descaling in Progress
after the descaling agent is exhausted
Display says Empty Drip Tray and Spent Grounds
5 Also remove rinse and refill the water tank to Max line
6. Press the water button again
after the machine stops
7. Empty the drip tray and spent. ground container and replace
Display says Rinse Press OK
Display says Appliance Ready
In essence go to Descaling Press OK and follow the directions as they are displayed.
Sep 07, 2008 | Krups Orchestro Dialog FNF2 Espresso...
Saeco magic comfort coffee machine grinder
Make sure you not get any water in the grinder, if you got water in the grinder then you have to clean it.
You can try to set grinding to coarse and try to make 3 cup of coffee.
Jul 22, 2008 | Saeco Magic De Luxe Espresso Machine
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
