The target on thermostat is 21, but when it comes on,it gets too hot,up to 24.5.If its set for 21,should it turn off when that temperature is reached.
    Top Expert:
  • 12,744 Answers
Check area of where stat is mounted if cold wall or coldest section stat will continue till satisfied --or stat may need to be calibrated
Posted on May 02, 2017
My dyson won't turn on. In the section for the speed of fan is showing the number 33.
Hi Deborah, it's Jack at Dyson.
It's likely the '33' you see displayed on your machine is the target temperature you've selected, as the fan speed goes from 1-10.
If you've selected 33 degrees as the target, your heater will only activate if the ambient room temperature drops below 33 degrees. It would then continue to run until the temperature reaches 33 degrees once again. The intelligent thermostat is engineered to heat the room to the desired temperature, then to run as needed to maintain this temperature.
If you want the heater function to run, try increasing the target temperature degree by degree until the machine comes on. But if you want to use the fan-only function in warmer weather, turn the target temperature down to 0. The LED indicator around the on/off switch will turn blue, and the machine will run in fan-only mode to cool you down with unheated airflow.
I hope this information helps. If you'd like further help or advice from our experts, you're welcome to call the Dyson Customer Helpline directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Jul 18, 2015 | Dyson AM04 Hot Cool Fan Heater White
Dyson hot cool will not start
Hi Frank, it's Jack at Dyson.
I'm sorry to hear you're having difficulty with your Dyson Hot + Cool fan heater. I'm not sure from your question if your machine isn't running at all, or if it's displaying an error code. However, there are a couple of quick troubleshooting steps you can try.
If your AM05 is displaying an error code, we'd recommend unplugging it for the wall socket for 30 seconds before testing it again. This should reset the machine.
However, if your AM05's LED display lights up as normal, it may not be coming on because the thermostat's target temperature is set lower than the current ambient temperature. Try raising the target temperature degree by degree using the remote or the controls on the base. You should find it will come on once you've set it to heat the room to a higher than ambient temperature.
The Getting started guide I've attached may help, but if you'd like any additional advice from our experts you can reach us on 1-866-693-9766 (US), 0800 298 0298 (UK), 1-877-397-6622 (CA).
Jan 12, 2014 | Dyson AM04 Hot Cool Heater/Table Fan -...
Dyson hot cool will not turn on
Hi there Frank, it's Jack at Dyson.
I'm not sure from your question if your AM05 isn't running at all, or if it's displaying an error code. However, there are a couple of quick troubleshooting steps you can try.
If your machine is displaying an error code, we'd recommend unplugging it for the wall socket for 30 seconds before testing it again. This should reset the machine.
Kegerator gets cold but will not not stay cold. its like unit shuts off after it reaches cold
You may need to replace the thermostat. Sound like it works until the low temp setting is reached and then can't maintain that temperature. Given that it will turn the machine on when the refrigerated compartment is warm this implies that the thermostat works until it breaks the connection when the low temperature target is reached.
Jan 07, 2014 | EdgeStar KC2000 Beverage Cooler Commercial
Setting start temperature on central heating thermostat
It sounds like your heating system has to little capacity to heat the home properly. 21 degrees is a reasonable temperature to expect but if the unit is running all the time and can't reach 21 degrees the heater is too small.
As far as setting the thermostat here is a link to the instructions.
http://www.salus-controls.pl/data/product/attach/rt300rf_-_eng.pdf
Nov 22, 2013 | Heating & Cooling
Adjust thermostat
A thermostat only cuts the heating off when the temperature it is set to is reached while the heating is on. If the heating is set to off then the thermostat will do nothing.
Generally you want to think about when you want your heating to come one and off by using the timer and then the thermostat is just used to ensure that you don't waste energy by exceeding the maximum comfortable temperature.
Hope this helps a little.
Nov 22, 2013 | Ovens
My dyson hot fan will not give out air under 24 degrees?
Hi Charlie, it's Jack at Dyson.
When you adjust the target temperature of your Dyson Hot fan heater (shown on the LED display on the base), you're setting the target temperature you would like the room heated to. The actual temperature of airflow produced by the fan heater will not vary.
If the heater won't run below 24 degrees, this is likely to be because the temperature of the room you're in is equal to or warmer than 24 degrees. The heater will only turn itself on if the temperature drops below 24 degrees, and once the room temperature reaches this target once again, the fan will turn itself back to monitoring mode.
I've attached our Getting started video below which shows how to adjust the temperature, using the remote or the controls on the base.
I hope this makes sense. It sounds as if your machine is working correctly, but if you'd like any further advice from our experts you can reach us at 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Aug 01, 2013 | Dyson Hot Heater Fan AM04 - Blue
Dyson hot and cold fan only works in hot mode
Hi there, it's Jack at Dyson.
If the heater won't run below 25 degrees, this is likely to be because the temperature of the room you're in is equal to or warmer than 25 degrees. The heater will only turn itself on if the temperature drops below 25 degrees, and once the room temperature reaches this target once again, the fan will turn itself back to monitoring mode.
Nov 09, 2012 | Dyson AM04 Hot Cool Fan Heater White
Carrier Comfort 13 Puron model 24ACA3 / FV4NB006 installed 3/18/08 no longer cooling. Carrier AC1-100 Thermostat checked per manual - all default settings intact. Test override did not turn unit on though....
Verify 24 volts at the low voltage transformer inside the air handler. If it is OK, jump out the red/green and yellow thermostat wires. If everything comes on, replace the thermostat.
Jun 07, 2009 | Carrier 38CKC036 Air Conditioner
Heating & Cooling Logo
29 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
