Question about Dishwashers
How to turn on sanitized feature. Model SHX46A
Clean sanitized washing lights flashing
Hello Brian, thank you for your post!
I understand Clean, Sanitized and Washing feature lights are flashing. Let's try resetting your dishwasher. This can be done by either unplugging or flipping the household circuit breaker to the off position. It is important to wait approximately ten minutes and then turn your dishwasher on. Confirm that the door is securely closed and select a cycle. If resetting the power does not correct the issue, it could potentially mean a number of things: a potential wiring failure, door latch assembly, or control board. At this point, I would personally contact a professional to accurately diagnose your dishwasher to determine the root cause to reduce the risk of unnecessary parts.
Best of luck, Chris!
Dec 23, 2013 | Frigidaire 24 in. PLD2850 Built-in...
Unknown control panel symbols bosch dishwasher super silent
Wash Cycle Options
Delay Start (model dependent):
This option allows you to delay the start time of your dishwasher up
to 19 hours.
Sanitize:
The Sanitize feature is available only in the Heavy, Auto, Normal and Half Load cycles. Press the
"Sanitize Option" button to activate the Sanitation features during these cycles. The technical sanitation
measures may also improve the drying results. The sanitize LED or The "Water Pipe" symbol will light when sanitation
requirements are met.
Note: The dishwasher automatically defaults to Auto Wash when turned off and back on. If you used the sanitize option
in your last cycle, the dishwasher will default to Auto Wash with the Sanitize option selected when you turn it on.
To achieve proper drying, always use a liquid rinse aid, even if your detergent contains a rinse aid or
drying additive.
Note: The dishwasher indicates low rinse aid by turning on the Refill Rinse Aid indicator LED (for units without
a display) or The "Spray Looking" symbol (for units with a display).
If this light is on, you need to refill the rinse aid dispenser
I got the idea that the "squiggly arrow" has something to do with the sanitize feature also. If you post your model number "on the inside right hand side of your dishwasher door" I'll go get your manual and post the link here. Hope this helps so far! :)
Jun 18, 2012 | Bosch 500 Series SHX55R55UC Fully...
Brand new Matytag MDB7749AWB Dishwasher does not work correctly. As soon as the power was turned on, all three cycle indicator lights ('Wash', 'Dry', and 'Clean') came on and always...
Try putting the unit into a test mode. This my clear your issues otherwise call for service.
One of two ways to do this.
In standby (no lights) Press the combination of buttons:
hi temp wash > sanitize > hi temp wash > sanitize > hi temp wash
All lights will come on and the washer will run a test cycle anywhere from 5 to 10 minutes.
If that button comb doesn't work use:
heated dry > sanitize > heated dry > sanitize > heated dry
May 27, 2011 | Maytag Dishwasher
I have a Bosch SHX46A05UC/33 5-cycle dishwasher whose labels on the cycle buttons have also worn away. While the Macmarkus post was helpful b/c I have some of the same buttons, can you tell me the labels...
Some SHX46A washers have 4 cycles and others have 5 cycles.
I'm fairly sure your model has the hidden buttons on the top of the door and you stated you have five-cycle buttons, in which case they will be as follows.
1. Top Rack only cycle or Sanitize
2. Power Scrub Plus
3. Regular Wash
4. Delicate Wash
5. Rinse and Hold.
These buttons are also used for cancelling a wash cycle. Hold down "Power Scrub Plus" and "Delicate" at the same time to cancel a cycle and drain the water out.
If your washer does have 4 buttons, it means you don't have a Top Rack / Sanitize cycle, in which case the button configuration (from left to right) will be:
1. Power Scrub Plus
2. Regular Wash
3. Delicate Wash
4. Rinse and Hold.
I hope this solves your problem. If you need any additional information, please post back.
Regards,
BElectric
Nov 21, 2010 | Bosch 24 in. SHX46A05UC Built-In...
Bosch dishwaher Model # SHX46A does not display indicator lights and does not function in any mode. There is power to the on/off switch that works and power to the control panel. Other wise the unit is...
Having same problem, power to outlet, but unit is "dead", no lights, won't turn on. Unit is 6 yrs old and don't want to spend $100 for a repair man to tell me there is no hope....anyone else experience this?
Aug 12, 2010 | Bosch Dishwashers
Fill valve does not shut off completely
Yes, replace the valve. Small particulate matter will eventually damage the valve.
Sep 17, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
I am having problems with the white scale being left on the inside of the dishwasher and I am not sure how to add the rinse agent to the despenser to stop the streaking and spotting. My model number is...
1) Do maintenence as suggested in operators manual
2) Buy 3 (yes 3) Dishwasher Magic (ACE carrys it)
3) Run all 3 - NO dishes
4) Load dishwasher with 3 cups white vinegar
5)Run cycle with Glasses only
6) NEVER USE LIQUID AGAIN - powder only!
Jul 16, 2009 | Bosch Dishwashers
I have a three year old Hobart. I am not sure
Look on the top edge of the door to find the data plate. It sounds like an SR24, if the leds are on the left of two temp gauges. If your sanitizer pump has a tired silicone tube that is flattened from use, it will not draw chemical. if you have an air bubble in the sense board at the back, it will think you have run out. If you have changed the type of chemical or diluted it, the board will need recalibrating to suit. Put some sanitizer in a small vessel with the pickup tube and monitor the amount delivered. Usually one is looking for 50 ppm solution of bleach and rinse water.( test with litmus paper) If you have an SR24H with a booster, you don't need bleach sanitizer and holding the sanitizer button will turn the sense off.
Jun 16, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Kenmore Dishwasher Not Sanitizing
You don't need an additive.
The sanitized LED itself is probably out.
It will not light up if the sensor doesn't sense that the water has reached 155 F. If the dishes are getting clean, I assume the heater is working properly. You could have a failed sensor, but you would usually notice longer than normal wash times and the dishwasher getting hotter than usual.
Alternately press heat dry and hi temp scrub 4 times. This puts washer into diagnostic mode. The first thing that happens is all the LED's light up. If it lights up then it is ok and the problem is somewhere else.
If these instructions don't apply to your machine, please post the complete model number from the decal just inside the front of the tub and I will look it up for you.
Nov 16, 2007 | Kenmore 24 in. 15252 / 15254 / 15259...
Dishwashers Logo
61 people viewed this question
Top Dishwashers Experts
