Question about Life Fitness Exercise & Fitness
Motor Error displayed on Lifefitness x5i
Problem started as intermittent. Used to unplug and replug and would be okay. Resistance got difficult. Replaced motor.   Now get error displayed all the time. They want me to replace console. Not sure if that is right.
Joed911
  • 4338 Answers
SOURCE: canon mp 160 error code e 22
First make sure that there isn't anything keeping the carriage from moving freely.
Then follow the instructions below:
How to clear Error Code Canon printers MP150 MP160
CANNON Printers MP150/MP160 ERROR CODE
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber full
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Dec 20, 2008
SOURCE: set paper again/toner again error message
I had this problems and did everything suggested on here. Installed firmware update (which just changed the error message - didn't get rid of it), removed paper, changed size, replaced paper, tried new cartridge. Nothing worked. Finally found a tiny piece of paper that must have been blocking the sensor. It was on the left side near where the power cable is. It was less than an inch square. Got it out with some tweezers and problem solved.
Posted on Dec 31, 2008
SOURCE: Dell Printer 926 cartridge error
I had the same prob..... I fixed it I took a clean soft rag sprayed Windex on it wiped off the ic type board on the front of the cartridge and also the board on the inside that the cartridge rest up against,,, turned it off and on put a copy under the scanner and kaabam it printed a month of pulling my hair out it works
Posted on May 22, 2009
shockwave727
  • 262 Answers
SOURCE: Scanner motor move failed error code 6202
6202 error code means that the scanner motor failed
to solve this
-Open the printer access door of your printer
-Unplug power cable
-then after 30secs plug the power able back
-If the printer is already power-up the message printer access door will appear
-Close th printer access door
-try to scan or print
If this issue not solve call tech support of kodak Toll free 1 800 421 6699
Posted on Nov 08, 2009
pineworks
  • 4041 Answers
SOURCE: Model Canon MX850. Display error message 6A00.
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 10, 2010
Can anyone tell me what F06 error code means on the whirlpool 6th sense 10kg washer? and what to do about it as the screen is flashing but the door to the machine is locked. Thanks
F06 Drive motor tachometer error This error occurs when the main control unit fails to detect the motor speed from the tachometeric generator fitted to the motor either through an incorrect resistance or the tacho is not correctly fitted into place. The machine will try to detect the reading several times before aborting the program ans shutting down with this error being displayed.
When checking ensure that the drive belt and belt tension are okay as this can cause this error.
  • Check tacho resistance
  • check tacho placement
  • Check wiring for shorts
  • Check wiring harness connections between motor and main controller
  • Check drive belt for damage and tension
http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3708-whirlpool-washing-machine-fault-codes.html
May 26, 2015 | Whirlpool Washing Machines
Error 44 precor eliptical 546
Precor Error 44, Un-commanded Lift Motion Probable Cause 1. Intermittent or bad connection in the lift position sensor(potentiometer).
2. Lift position sensor (potentiometer) is bad.
3. Lower PCA is bad.
Corrective Action
  1. Bad or intermittent connection of the lift position sensor (potentiometer) is the most common cause of the error 44. Inspect all wiring and connections related to the lift position sensor (potentiometer). Repair or replace wiring connections as necessary.
  2. Monitor the lift position number displayed while operating the lift in diagnostics mode. If the reading makes large changes or is erratic, the lift position sensor (potentiometer) is likely bad. Replace the lift position sensor (potentiometer) or lift motor if the lift position sensor (potentiometer) is internal to the lift motor.
  3. If the lift moves without any command entered either manually or through a program, replace the lower PCA.
Precor Error Code 44
Nov 22, 2012 | Precor EFX 546i Elliptical Version 4
Lifefitness TR 9000 treadmill - 1997 model
Because you are hearing the lift motor making a noise, it sounds like the gears in the motor are bad. The fix is to replace the lift motor.
Apr 28, 2010 | Life Fitness 9000 Next Generation...
Blinking display of advantium m/w oven
by unplugging the m/w for a few minutes and then replugging the problem is gone.
May 29, 2009 | GE Advantium SCA1001SS Convection /...
Our stove, a whirlpool accubake system is displaying an error code E0 - F0. We recently unplugged it after running the self cleaning feature. Now only the clock works, the stove does not heat and neither...
The E0 - F0 indicates that there are no error codes. This code will sometimes be displayed when you press and hold the CANCEL/OFF key for 5 seconds and there are no pre-existing error codes. Press the CANCEL/OFF button to clear this code.
You could have a problem with the oven temperature sensor or a problem with an element that is preventing the oven from heating properly. A problem with the control board or a blow thermal fuse on the broil element could also cause this problem. Check the broil function to see if the broiler will work properly. If the broiler will not work at all then you could have a blown thermal fuse. This thermal fuse is shown on the wiring diagram and parts drawing in the image below. You should be able to access this fuse by
unplugging the range and removing the back panel. You can check this fuse with a volt/ohm meter. Pull one wire off (with the range still unplugged) and measure the resistance across the leads of this component. You should measure near zero ohms of resistance (continuity) if the fuse is good. If the fuse is blown you will measure Open Circuit (open load or infinite resistance). With the range unplugged!
If the thermal fuse is okay, you could have a wiring failure, a failed broil element or a bad electronic control board.
If the broil element works okay but does not heat to the correct temperature, then you could have a bad oven temperature sensor probe. The procedure for accessing this component (with the range unplugged) is shown in the second image below. You can check this component by measuring the resistance through the probe. At room temperature, it should measure about 1080 ohms. If it is bad, it will need to be replaced.
If the sensor probe is okay then you could have a bad bake element. You can measure the resistance of this components in a similar manner as described above with the range unplugged!
The element should measure between 5 and 20 ohms. If it is open (measure Open Circuit or infinite resistance) then it will need to be replaced.
If you do not feel confident repairing this problem yourself, then you can have it repaired at your home by a technician.
Dec 15, 2017 | Kitchen Ranges
F 06 error code
The "F06" error code is a Motor Speed error. The following link explains the recommended course of action you should take:
http://www.fixya.com/support/r714929-f06_error_whirlpool_duet_kenmore_elite
Now, another tip to try BEFORE you assume you have any failed parts is to unplug the washer for at least 30 minutes. This is recommended by the manufacturer to reset the main computer (or CCU). Sometimes this tip will reset most common system errors. If the problems persists, I would recommend checking the wiring harness between the Motor Control Unit (MCU) and the Drive Motor, followed by resistance checks of the motor windings. You may have a loose connector somewhere (as you suggested) or a component beginning to fail after it heats up (hence, the reason why the washer works for a while, then sometimes fails). Intermittent problems aren't always easy to troubleshoot. If your symptoms keep reocurring, take note of when and how (i.e., after several loads, during heavy loads, during final spin, etc.). This will give me an idea of what may be causing any repeated error codes. I hope you find this information helpful. Let me know if you require additional assistance.
Sep 08, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Maybe a bulb going bad?
Without doing some tests this is difficult to know.
I do not remember if the bulb in this model is a gas discharge type or a filament type. I will first indicate here for the filament type.
Make sure that the unit is switched off, and is unpluged from the AC mains.
With a DVM it is possible to check the socket contacts. The unit would have to be unassembled to gain access to the lead wires that go to the socket, and the socket disconnected. With the lamp installed, use the ohms scale to see if the resistance of the bulb's filament can be measured.
If the socket contacts are okay, it is possible that the fault is the power supply to the bulb, or it can that there is a cooling fault, or maybe the bulb itself has an intermittant where when it gets heated up it temporarily becomes open circuit.
The way that most electronic equipment is designed today, it is microprocessor controled. There are sensors for temperature, current draw, quality of voltage regulation, air flow for cooling, specific performance checks, and other similiar things. If there is an error, the uPC will shut the unit down. In most cases, an error code of sorts is indicated. In some equipment, there is no displayed error code.
For the gas discharge type of bulb, to test the socket contacts to the bulb, instead of measuring the heater resistance, you will need a dummy insert to replace the bulb that has a zero resistance for testing the socket. You insert the dummy tester, and measure of the leads with the DVM to indicate if the contacts are okay to the bulb.
A less sure way to test the socket contacts is to disconnect the socket from the supply, and measure the resistance of each lead to its respective contact in the socket. This will indicate if there is open or closed resistance to the socket contacts, but does not respect the tollerance for the contacts to make a connection to the bulb contacts on its base.
In the service shop, after all the above has been done, the tech would do his tests by trying modules and parts until the fault is located. That is if the fault was not the socket.
Jerry G.
Apr 27, 2008 | HP Digital Projector Vp6120 Multimedia...
HP 8150N ERROR CODE 79.060E
Power off the printer. Unplug the printer's USB cable for 5 seconds replug turn on the printer. If that fails power off the PC and printer unplug the USB cable at the PC and printer replug and power back on the PC. After PC is fully booted turn the printer back on. If this keeps reoccurring please replace the USB cable and or try different USB ports.
Mar 18, 2008 | Computers & Internet
Exercise & Fitness Logo
178 people viewed this question
Top Life Fitness Exercise & Fitness Experts
Howard
Howard
Glenn Mayer
Glenn Mayer
Craig Butler
Craig Butler
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
