Question about Kenmore Dryers
No heat and timer doesn't seem to turn - Kenmore Dryers
    Problem Solver:
  • 17 Answers
More than likely you have lost 1/2 of the 220 volts to your dryer. On the pigtail (thats the power connector) that plugs into the socket,Unplug it and check to see if the prongs are discolored, Clean them with steel wool, or a scouring pad. ( Don't use water) If that doesn't work check your fuse box, or breaker box. to make sure you have power to the socket. The power connector has 2 slits in it. One up and down, and 2 at angles. If you have a voltmeter, or a neighbor, check the voltage between the vertical slot and each of the slanted slots on the plug. You should have 120 volts ac on each. and 220v between the slanted slots. Unless you have a bad breaker, or one leg open by a bad fuse Your dryer uses one half the 220 or 110 for the motor, and the other half to run the timer, ect, and 220 for the drying element. with 1/2 of it gone only certain thing will work. If that doesn't work, you may have to turn off the power to the dryer outlet, clean or replace it. (Make sure the breaker is off, or fues are removed and check with a voltmeter that the circuit is dead before working on the outlet) , but I would almost bet that by wiggling and cleaning the plug will solve your problems for a while. Hope this helps.
Posted on Jul 25, 2009
My whirlpool dryer comes on and runs good but it wont get hot can you tell me whats the problem
Hello there and welcome to fixya there are several things that could make this dryer not heat up
Here are the most common things
Thermal Fuse
If the dryer doesn\'t heat, but the drum
turns, check the thermal fuse(s). The thermal fuse protects the dryer
from overheating and helps to prevent fires. If the thermal fuse is
blown, it will have to be replaced.
Enter your model number to see parts for your dryer.
Help me find my model number
Gas Valve Solenoid
The gas valve has two or more electric
solenoids which open the valve to let the gas flow into the burner
assembly. If the dryer doesn\'t heat one or more of the solenoids may be
defective. If the igniter glows for 90 seconds but the burner flame
doesn\'t light, replace these coils as a set.
Dryer Igniter
If the dryer doesn\'t heat, the igniter might
be burned out. Check the igniter for continuity with an ohm meter. Dryer
igniters burn out over time, similar to a light bulb.
Heating Element
The heating element on an electric dryer can
burn out over time. If the dryer doesn\'t heat, the element should be
checked for continuity. The heating element cannot be repaired and must
be replaced if defective.
Heating Element Assembly
the heating element assembly on an electric
dryer can burn out over time. If the dryer doesn\'t heat, the element
assembly should be checked for continuity. The heating element assembly
cannot be repaired and must be replaced if defective.
Flame Sensor
Gas dryers have a flame sensor to detect the
heat given off by the flame. If the dryer doesn\'t heat, the flame sensor
might be defective. Check the flame sensor for continuity. This is not
as common as a burned out igniter or thermal fuse.
High Limit Thermostat
Although not common, if the dryer doesn\'t
heat the high limit thermostat can be defective. It can be checked for
continuity. If the thermostat is "open" the dryer doesn\'t heat.
Cycling Thermostat
The cycling thermostat regulates the
temperature of the air in the dryer. If the dryer doesn\'t heat it may be
caused by a defective cycling thermostat. This is not common.
Main Control Board
The main control board is normally not at
fault when the dryer doesn\'t heat. Check all of the other components in
this troubleshooting guide before replacing the main control board. The
main control board cannot be tested easily and must be replaced if it is
defective.
Timer
The timer is normally not at fault if the
dryer doesn\'t heat. In many situations where timers are replaced they
end up being returned. Check all of the more common components in this
troubleshooting guide before replacing the timer
Oct 14, 2013 | Dryers
Worcester MT10 Timer doesn't start. The clock seems to work fine but when it is time to start the heating system doesn't. Please someone csn help me? Thanks
Go to http://www.worcester-bosch.co.uk/homeowner/boilers/boiler-controls/which-controls-go-with-my-boiler/mt10-mechanical-timer. They have a video and instructions plus a downloadable manual to walk you through the process. If it still doesn't work maybe you should return it a get a new one.
Nov 07, 2012 | Watches
Whirlpool built in dishwasher DU840SWKQO
Hi
Thanks for using FixYa. If the cycle doesn't complete, then the first thing that should be checked is the Timer and then the heating element. Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it. Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next depends, as follows: On some units, the pause is timed and the unit continues after the allotted time. On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Dec 22, 2011 | Whirlpool Dishwashers
I just installed a Wood 59018 timer, and when i try to turn it on manually, I hear the relay click on and then immediately off (the attached light turns on and off too). That's when the switch is set...
Timer is wired wrong and timer white and timer red wires are probably connected together.
Timer white wire has to be connected to white neutral wires that are twisted together and shoved to back of box. This will power the clock mechanism inside timer.
If box does not have white neutrals, then connect timer white wire to bare ground wire along with timer green wire.
Timer black wire connects to Hot wire.
Timer red wire connects to Load wire.
http://waterheatertimer.org/Woods-timers-and-manuals.html#59028
Jul 09, 2011 | Woods InWall 7 Day Digital Programmable...
Microwave is less than a year old. It looks like everything is working, timer, light, air, turntable, etc., but it doesn't cook.
HI..there is a heating filament of an oven MAGNETRON..it s responsible of producing heat to the oven..possibly this is defective ..this filament must be replaced by a new one..theres no problem with the motor cos it runs the table power and light button seems working..HOPE THIS HELPS
Jul 06, 2011 | Oster Microwave Ovens
Our Dualit toaster doesn't work. The red light doesn't work. I have changed the fuse in the socket with a working one. The timer turns normally. Yet none of the heating units heats...
You need to replace the timer-contactor. This part is acting both as timer and electrical contactor. It consist from electrical contact moved with springs on and off. Due to electrical load and extreme heat these contact have been tear out thus they can not contact properly and in your case they don't contact at all.
So from the web page of dualit or ebay you can order A new timer contactor and replace it.
Jun 12, 2011 | Dualit Vario 3 Slices Toaster
My Coralife aquarium lamp does not turn on once it is turned off.... until the next day. Other times it seems fine.
The timer doesn't know what time it is until you set current time.
The yellow outlets are controlled for 12 hours, and you can determine when those hours occur when setting current time.
http://waterheatertimer.org/GE-timers-and-manuals.html#zilla
If you want timer to control one lamp with both day and night schedules, you have to adjust current time setting so lamp schedule falls within a 12 hour period. If that schedule doesn't fit, then buy a second timer.
Absolutely feel obligated to upvote the help.
Or take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Dec 20, 2009 | Coralife Zilla Aqualight Power Center
Dryer tub turns but there is no heat
I have a frigidaire crown series dryer.the tub turns,timer works but there is no heat coming out.
Jun 23, 2009 | Whirlpool Dryers
Clothes dryer don't run
sounds like a bad cycle timer switch
Apr 22, 2009 | General Electric Clothes Dryer Knob -...
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
