Question about Sewing Machines
How to replace needle
Would like a manual on 98E Just bot a used machine (from a dealer) but have no instructions
  • Sewing Machines Master
  • 10,742 Answers
Search for:
Make Model manual
Posted on May 02, 2017
My machine has no instructions it was bought from a second hand dealer and it was ok when purchased. Needle came loose now it does not work. My first machine so not sure what to do.
Could it be the needle is not installed correctly or all the way up? Most machine needles install with the flat side facing the back of the machine. If the bobbin is installed on the left side of the machine, then the needle's flat side usually faces the right (toward the harp of the machine).
You can try searching for a manual:
Make Model manual
Feb 21, 2017 | Sewing Machines
How do I replace my twin needles on my brother overlock 1334 D ?
That is not a twin needle. It is actually two individual needles that are separate. (There are actually some stitches that you would use only one needle, ie hem.)
The manual will have instructions on how to replace the needles. There appears to a hex screw immediately above the needles that is used to remove or secure the needles. With the hex tool included with your machine, loosen that set screw (be careful because both needles will become loose and can drop down into the machine). Hold the needle(s) with the flat side facing the back of the machine, slip them all the way up in the needle holes, hold them in place while tightening the hex screw. Be Careful to not lose the hex screw that hold the needle or drop the screw or needle down into the machine.
User Guide Manuals 1334D Australia Brother
Nov 12, 2016 | Brother Sewing Machines
I would like an instruction manual
[PDF]5, 6, 8, 10 Stitch Sewing Machine - Singer
www.singerco.com/uploads/download/448_5_6_8_10_slide.pdf
exclusives, like a removable extension table ... This Singer Sewing Machine was tested according to. European ... Read all instructions before using this machine. ....The needle and thread you choose will depend upon the fabric being sewn.
Instruction Manuals ' Singer Sewing
www.singerco.com/support/instruction-manuals
Our replacement instruction manuals are provided in a downloadable PDF file ... To download a manual, you will need to know your machine's model number.
[PDF]INSTRUCTION MANUAL 9960 - Overstock.com
www.overstock.com/.../Instruction_Manual_14253523.p...
Overstock.comThis sewing machine is not intended for use by young children or infirm persons without ... The wrong plate can cause the needle to break. 12. Do not use bent ...
Free Sewing Machine User Manuals ' ManualsOnline.com
homeappliance.manualsonline.com > Household Appliance
Find the user manual you need for your home appliance products and more at ManualsOnline. ... First Virtual Communications Sewing Machine Manuals.
Manual Finder « Sew it Works!
Jan 07, 2016 | Sewing Machines
HOW TO OIL jANOME 10000
the information should be in the manual, here is a link for a manual if you don't have one, if the oiling instructions is not in the manual, the contact the dealer you bought the machine from and ask them if the machine is self oiling or not?
Instruction Manual Janome MC10000 Instruction Manual Janome MC10000
Jul 27, 2014 | Janome Memory Craft 10000
Tension to loose and missing stitches
SKIPPED STITCHES ON A SERGER
1. Is the needle bent or worn--replace
2. Is the needle inserted correctly into the needle holder--check needle
3. Is the Serger threaded correctly--rethread
4. Is the presser foot pressure right for the fabric--adjust
use a scrap piece of fabric to sew on as you adjust the tension
when the tension is to loose adjust one number higher till stitch
looks good
here's 2 links for a manual one is a hardcopy & the other is a
pdf downloadable--one is a different price from the other
http://www.sewingpartsonline.com/instruction-manual-janome-mylock-634d.aspx
http://www.sewingpartsonline.com/instruction-manual-janome-mylock-634d-download.aspx
Sep 08, 2012 | Janome MyLock 634D Mechanical Sewing...
Zigzag stitch problems on brothers pc-420 sewing machine
Sewing machine skips stitches
1.needle inserted incorrectly
flat side of the needle faces the shaft
round needle
groove of needle faces away from the shaft
Correct needle insertion is mandatory for proper use
Raise the needle bar to the highest point, then loosen the clamp screw to remove the needle.
Place the new needle in the clamp with the flat side of the needle facing the back of the machine.
If round needle--the groove in the needle faces away from the shaft
Push needle all the way up to the stop or as far as it will go.
3.possible bent needle--lay needle on flat surface & roll needle over, if the needle does not roll good -replace
4.blunt needle point--needle makes a popping sound when needle penetrates the fabric--replace needle
5.needle not all the way up in needle holder--loosen needle clamp screw & push the needle up until it stops then tighten screw
6.incorrect threading--one step missed in sequence of threading can cause machine to skip stitches
7.wrong needle in machine--check instruction manual--some machines can use a generic needle with no problem
8.size of needle & thread & the fabric are not compatable
Mar 30, 2012 | Brother PC-420
I have a JUKI TL-98E, purchased used in great condition. Having a problem with the needles breaking, worked fine when I first got it. Rethreaded the machine and put in a new bobbin and the problems...
I had problems as well, especially when trying to outline quilt. I found using a Schmertz Metafill needle, or an embroidery, anything with a larger eye, helped.
Jan 30, 2011 | Juki TL-98Q
Can you tell me how to re-time my Juki TL-98E??
email me for attachment of instructions drivewithken@blueyonder.co.uk
Mar 08, 2010 | Sewing Machines
Thread breaks
First, change the needle, second, set the tension 3-5 if it only goes to 8. Next, unthread the machine with new thread and be very careful to make sure the thread is in the tension wheel.
Mar 16, 2009 | Sewing Machines
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
