Question about Sewing Machines
I can't get the tension disk to take the threads tension is set at 0 and pressed foot is up and the looper is in the highest position help!!!!
  • Sewing Machines Master
  • 12,469 Answers
Remove the top thread from the machine.
ALWAYS RAISE the presser foot and rethread from the beginning.
Verify the thread path is correct.
Set the top tension at the midway point.
Posted on May 02, 2017
Serger is not stitching at all. It has something to do with how the thread is installed. Needing a diagram
The diagram is on the inside of the serger door;
Raise the antenna to it's highest position.
Turn the handwheel until the loopers are at their highest position.
Set tensions to zero and raise the presser foot.
Begin threading from right to left, beginning with the upper looper.
Set the tensions back to mid-range.
Lower the presser foot and stitch a chain and if it is formed as it should be you are ready to serge.
There are manuals available for downloading at the Babylock website for the models DX and SX.
May 07, 2010 | Baby Lock Eclipse Serger
How do you thread a elna L-5 sewing machine
I found two sites with a manual for this model. Both are around $15.00 - sew4less and sewusa.
If you open the front of the serger, there should be a threading guide printed on the serger or on the inside of the door.
Raise the thread antenna to it's highest position.
Set the tensions to zero and raise the presser foot.
Turn the handwheel until the loopers are at their highest position - the handwheel may have a mark on it that aligns with one on the side of the serger to help with this.
Starting at the right, thread the upper looper first.
After threading, reset the tensions back to approximately mid-range.
Lower the presser foot and stitch a chain of thread to make sure the serger is stitching as it should.
May 01, 2010 | Sewing Machines
Lower looper problems
Some sergers require they be threaded in a particular order. If not, they do not "knit" the threads.
Open the tensions (set at zero). If the tension settings are automatic, raise the presser foot to open the tension settings.
Turn the handwheel so the loopers are at their highest position. There may be a mark on the side of the serger to match up with a mark on the hand wheel for this.
Open the front of the serger and the threading guide should be printed on the inside of the serger door, or on the serger.
Start at the right and note which looper is threaded first and then the needles.
You can find more information and manuals at the Singer Co website.
Mar 24, 2010 | Singer 14SH654
How to thread euro pro serger. threads aren'y interlocking
If the thread guide in printed on the side of the door or on the machine, you will need to follow the threading sequence.
Turn off the power.
Open the tensions (set at zero). If the serger has automatic tensions, raise the presser foot as this also opens the tensions.
Begin threading from the right to the left - lower looper is usually the first to be threaded.
After threading, set the tensions back to the normal setting and stitch a chain of thread and it should be knitted/interlocking.
Mar 23, 2010 | Euro-Pro Sewing Machines
I NEED HELP WITH THREADING 4 NEEDLE OVERLOCKER this has to be done in a sequence to form a chain HOW DO I DO THIS
Four needles or four thread (two needles and two loopers)?
Raise the presser foot.
Set the tensions at zero.
Turn the handwheel so the loopers are at their highest position. There may be a mark on the handwheel to match with a mark on the side of the serger for this step.
Thread in the sequence shown on the inside of the serger door.
Mar 14, 2010 | Singer Sewing Machines
Problems With the Tension serger kenmore
Open the tensions (set at zero) and have the presser foot up when threading.
Make sure the antenna if fully extended.
Turn the handwheel so the upper looper is at it's highest position.
Thread, beginning at the right thread cone unless the manual indicates differently.
After threading, set the tensions back to the recommended setting.
If this does not help, please provide more details.
Mar 10, 2010 | Singer Tiny Serger TS380
I dont know how to thread this serger. i dont
Have you opened the front of the serger to see if there is a threading guide.
Basically:
Lift the thread antenna to it's highest position.
Lift the presser foot and set the tensions to zero.
Turn the handwheel so the loopers are at their highest point.
Begin with the upper looper (first thread cone on the right/ end of looper is pointing toward the presser foot). .
Second spool is for the lower looper (end of looper is pointing away from the presser foot).
Third spool, right needle; fourth spool, left needle.
Be careful that the threads do not cross during the threading of the loopers.Follow all the guides, taking the thread under the presser foot and to the left side of the serger.
Set the tensions back to 3 - 6 and lower the presser foot. Sew a few inches and if the threads knit into a chain, you can then do a test sew with fabric.
Simplicity's Simply The Best Sewing Book has good information with regard to using a serger that you may find beneficial.
Feb 24, 2010 | Sewing Machines
I don't have a manual for my Baby lock Pro line model # BL4-738 NS. It was given to me and I have threaded it accordingly to the diagram on the machine but it won't pick up the stitch.
You will have to order the manual from a Baby Lock dealer.
This model may have to be threaded in a certain order.
Try raising the presser foot and setting the tensions to zero.
Turn the handwheel so the upper looper (the curved one) is at it's highest position - there may be a mark on the side of the serger where you align the handwheel for this.
Thread the upper looper and then the lower looper and then the needles.
Pull the threads under the presser foot and toward the side of the serger.
Set the tensions back to 4 - 6, lower the presser foot.
Hold onto the thread tails and gently press the power pedal to begin a thread chain before serging fabric.
Feb 16, 2010 | Baby Lock Eclipse Serger
Threading a husqvarna huskylock 1001L serger
Solution taken from "Handbook for Huskylock Sewing Machine Models 1001L/1000L/1000"
1. Raise the presser foot by using presser foot lever. When the presser foot is raised, the two thread tension discs in the thread tension control panel are released so that thread passes freely between them. Otherwise thread tension may not be correct.
Important! When threading the needle, always be sure to lift the presser foot lever, and also take care to thread in the proper order.
Threading order:
1. Upper looper thread (green)
2. Lower looper thread (blue)
3. Double chain stitch looper thread (purple) in case of 5 thread stitch or double chain stitch
4. Right needle thread (red)
5. Left needle thread or double chain needle thread (yellow)
Caution!
Because the left thread tension dial (yellow) is used for either the left needle or the double chain stitch needle, these needles will never be used at the same time.
Upper looper (green) sequence:
1. Thread holder (silver triangle openings attached to thread holder stand)
2. Thread guide (flat silver clips just behind thread tension disc)
3. Thread tension disc (circular knobs with numbers for tension setting)
4. Pull thread around upper looper guide and upper looper
5. Pull thread into hole of upper looper
Lower looper (blue)
Repeat 1, 2, 3.
4. Pull thread around guide (see color coded chart inside front serger cover).
Easy threading mechanism (for lower looper)
1. Pull out the lower looper threading lever
2. Thread the lower looper and position the thread on hook of the lower looper
threading lever.
3. Push the lower looper threading lever back to its basic position while
holding the end of the thread.
Caution:
When returning the lower looper threading lever, always make sure that the two
blue triangle marks (directional arrows) meet each other.
Left needle thread (yellow)
Important: Thread the needles after threading of lower looper and upper looper.
First raise the presser foot lever, and then thread the needle threads in order shown in color coded thread guide.
Jun 24, 2008 | Sewing Machines
Sewing Machines Logo
35 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
