Question about Cannon Office Equipment & Supplies
Cannon printer ts6000 series gives message load paper but paper is in a tray how to fix ir
SOURCE: Printer won't pull paper into printer
Check the "Feed Switch" button on the control panel (below the ON/OFF button) to be sure the green light at the back of the picture is lit. If not, try pushing the button and then printing again. It worked for me and it was so simple!
Posted on Sep 07, 2008
SOURCE: Printer will not print
I had the same problem and to fix it there was a blue tray I had to pull out (the tray for the photopaper). Once it was pulled out so it was about flush with grey part beside it, the printer worked again. (The photopaper tray is just above where you put the regular paper.)
Posted on Mar 26, 2009
SOURCE: HP Officejet 7410 AIO keeps saying out of paper when plenty of paper loaded
I have the same unit. There are many issues with it. First when you install the software you may need to add something to the registry.
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\Print\Printers\HP Officejet 7400 series\PrinterDriverData and create Key HPDJEnableSecondTray as DWORD with Value of 1
Once you've done this here is the biggest issue and one I've found to fix this issue PERIOD.
You need to go to your Printer Driver then to Properties of it then Device Settings Tab - you will see Form to Tray Assignment in the list and like 5 options, you have to make all but the one you want to NOT AVAILABLE. Example mine is set to Upper than Lower (Letter) all the rest are set to NOT AVAILABLE. Problem solved.
Posted on Apr 15, 2009
SOURCE: Supply rec paper tray - what does this mean when the tray is loaded?
OK, I was having a similar problem: Tray full of paper and tray adjusted properly.
Whatever I tried, the printer kept saying load paper.
I went to print menu>properties button (windows XP this is next to the printer name)>paper source tab.
It tuned out that the paper source had been changed from cassette to multi-purpose tray.
Change it back to cassette and you should be golden.
Posted on Jun 16, 2009
  • 4041 Answers
SOURCE: My cannon pixma ip 1600 keeps giving an error
Hello there
You may not see a paper jam, so this is worth trying.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 25, 2010
Canon image runner ir 2520 says load paper but the paper is already on the paper tray please help
To fix the error:
- You select setting
- Device Settings
- Plain Paper Feed Settings
- Set up on Rear Tray instead of cassette
Oct 30, 2016 | Canon Office Equipment & Supplies
Cannon IR 1600 Rec paper jam any paper find. how can i solve this problem?
Yes, often it is not a paper jam but a fail of paper to feed out of the tray which the machine thinks it has a jam. Clean feed rollers with Windex, or alcohol. Check the paper tray to see if paper size panels are set to the correct position. portrait, landscape, width length ect.. Good luck.
Jan 08, 2016 | Cannon Office Equipment & Supplies
Cannon mp282 pixma ,how to fix error code 3
The E03 code indicates (1) That the Paper Output tray is closed and you are trying to print. Open the Paper Output Tray and the printer will resume printing. (2) There is a paper jam. Remove the jam, reload the paper into the printer, then press the "Black" or "Color" button,
Dec 25, 2014 | Cannon Office Equipment & Supplies
Unable to print from canon imagerunner 3100
Select the paper source(paper tray) on the computer,select paper size.
Jan 03, 2012 | Canon Diplomat Office Equipment & Supplies
My xerox machine cannon IR 2020 shows a system error E007. How can I solve it? Please describe step by step.
E007 - Fixing film rotation error
You have to disassemble fuser unit and inspect a fixing film, if damaged - replace.
The official documentation says:
E007 0000 Fixing film sensor failure
The fixing film sensor is faulty. - Check the connector of the fixing film
- Replace the fixing film sensor.
- Replace the DC controller PCB.
Nov 11, 2010 | Canon iR 2022 Printer
Message paper jam and open left drawer cover
Delay Jam in Delivery Assembly (Paper Leading Edge Jam at Delivery Sensor/Wound Paper Jam at Fixing
Mar 19, 2009 | Canon iR 2020i Laser Printer
Once remove both the trays and insert them again and if the problem persists, power cycle and semi-full reset the all-in-one.
May 27, 2008 | HP OfficeJet 7410 All-In-One InkJet...
73 people viewed this question
Top Cannon Office Equipment & Supplies Experts
Cosma Papouis
Cosma Papouis
Greg Cann
Greg Cann
Are you a Cannon Office Equipment and Supply Expert? Answer questions, earn points and help others
