Question about The Office Equipment & Supplies
I can't get the front cover off my Viking S225. I've taken out all the screws I can see. It's the second turn dial on the right that's holding it in place. How can I release it to get the cover off?
SOURCE: I removed the three bottom screws from the front bottom cover. The cover will not lift off. I cannot find any other screws holding the cover on. Is there a special way to lift off the botom front cove
If you are referring to the toe panel, after you remove the 3 bottom screws you want to lift it slightly then pull it forward.
Posted on Apr 28, 2009
  • 98 Answers
SOURCE: front hub & bearing 2002 dodge 1500 4X2
i do this for a living ,the hub is corroded in tight,get a big hammer and start beating on it
Posted on Aug 03, 2009
  • 6784 Answers
SOURCE: what does thermal fuse look
HI. The thermal fuse will be mounted to the electronic control board that is located on the rear section of the control panel. I have posted a picture below of the actual fuse assembly.
Posted on Aug 29, 2010
  • 3018 Answers
SOURCE: I have a Hoover F7452900
  • Hi, I can help.
  1. After you remove the brushes there are 4 screws where the brushes were that need to be removed.
  2. Right behind the housing for the brush, on the base, are two more screws that need to be removed.
  3. Now there are two more screws more towards the outside of the base that need to be removed.
  4. Stand the vacuum upright and lower the handle.
  5. Now remove the main suction nozzle.
  6. Now remove the screw that holds that housing where that suction nozzle just was.
  7. Now remove the screws that are above the wheels.
  8. Now the cover will just pull up.
  9. Now you can see and address the turbine.
  • If you have any comments please feel free to leave them here and I will respond to you.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Posted on Sep 06, 2011
SOURCE: have a power brush and
I have a Miele STB-205-3 Turbobrush. After opening the brush cover using a quarter, I use a T-7 torx screw driver (shaped like star of David) to remove the main cover that is held by 4 screws.
There are 2 more screws holding the fan housing. After unscrewing them, you can take the whole thing apart and clean it. Make sure you clean all rotating parts as they collect a lot of hair, dust, etc,
Posted on Nov 19, 2011
I am trying to replace the bobbin winder on my 660 Janome jem gold but can't open the front cover. Can you help me?
There is a screw that is pretty hard to get to. I suggest using a Philips screwdriver that is magnetized. When you remove the large wheel on the right side of the cover, look inside and where you removed the wheel from. There is one last screw there which has to be removed.
Best wishes!
Jan 30, 2013 | Janome Jem Gold 660 Sewing Machine Compact...
Removing the covers on a viking 980
I assume you're talking about the main back and front cover. Unless you really are skilled, I'd leave this project to a professional.
I've worked on the Designer I, II type machine and I believe yours has similar construction. You need screwdriver bits with a 6 pointed "star" head. Screws in the cover itself are "H10" size. Screws in the base are "H15" size. The back cover has to be taken off first before you can get at screws for the front cover. Typically there are 5 screws on the back cover that have to be removed and 2 in the bottom of the base. Note that the front and back covers "snap" together and have to be unsnapped after the screws are removed. If you have to take off the front cover (requires removing more screws in the cover and base), be careful with the various wiring harnesses that attach to the main circuit board.
Jan 13, 2013 | Husqvarna Viking 1
How do I remove the cover of a delonghi ec270
Prise the back cover off with a flat head screw driver. Sides first, then ease top and bottom off. Remove two push in caps by gently squeezing out with a plier, align the groove to the same direction as plier. Locate two screws holding cover, unscrew, and off it comes.
Aug 25, 2012 | DeLonghi EC270 Espresso Espresso Machine
Have a power brush and cannot get the brush out to clean. I've taken off the main cover, but the brush is held in by a bracket. I can't take off the main cover as I don't have the right kind of...
Sep 13, 2011 | Miele S251i Plus Bagged Canister Vacuum
I have a Hotpoint WDF740 washer dryer. When I turn the dial it doesn't register any cycle it doesn't make any noise when the dial is turned, therefore I can't use the machine at all. Can this...
This just happened to my hotpoint washing machine, I realise it has been a long time since this has been asked but since my answer is different from the others I thought I'd add it anyway in the hope it will be useful to someone one day. The fix was super easy, all that was wrong was the plastic knob itself, which had broken internally. I only found this out after taking the top and front covers off, which is an easy enough procedure, I did it this way: unplugged the washing machine, removed two screws from back of machine that hold top cover in place, then using a putty knife pushed between the top and front covers front to back right at the corners, thus releasing the top cover, once this was out I could unclip the front cover and get to the screws that hold the control board to the front cover. I unplugged the electrical connection to the board, removed all the screws and unclipped it from its plastic cover. At this point I could see the plastic knob had broken, I recovered the broken bit and glued it back on. After the glue dried, I just put everything back in place reverting the previous actions. Hope this helps. If you don't have glue or can't find the broken piece, you should be able to just buy another plastic knob off the internet.
Jul 06, 2011 | Hotpoint Aquarius WD640 Front Load...
In my P1I touch screen not working? how to rectify?
just try this.. enter service menu by pressing jog dial up, *, jog dial down, jog dial down, *, jog dial down, *.
jog dial is rounded things at the right side of the p1, slide it up or down, follow the instruction.
then enter the menu hardware test, lcd test, write something in ur touch pad, if the letter u wrote visible it mean ur lcd fine.. so , just close the menu and its magic.... its worked.
Apr 27, 2010 | Sony Ericsson P1i
Replacing PB010036 Bake / Broil Thermostat Viking
you do not need to take apart any switches, all you need - unplug it from power, open front panel (2 screw on each side) remove all knobs, there is 3 more screws behind them). unscrew thermostat 2 screws behind knob. open top part of stove, remove grates and cover. you will see wires to thermostat unplug them and plug one by one to new thermostat. remove old thermostat from inside the oven (it has bracket inside). put the new one. close everything back. - viking repair LA
Dec 12, 2009 | Viking VGIC485-6G Gas Kitchen Range
HP 2210 has a problem with the inside of the glass so photo/doc are fuzzy and unclear when scanned. Is there a way to clean the inside of the glass?
there are 3 screws, one's at the left side of the unit on the top corner (this is the one that's visible), the other 2 are under the silver cover, which houses the dial panel and the LCD, in order to remove the panel you have to use a flat head screw driver or something like that, and pop out the dial cover starting from the top right corner then the left side and eventually the bottom part, and then, using something that can fit through the square hole near the bottom of the dials under the cover which you've just removed, press the lock inside and simultaneously pull(slide) the panel towards the front of the unit, there then you will see the two other torx screws
Good Luck
Dec 10, 2008 | HP PSC 2210 All-In-One InkJet Printer
Viking Dishwasher Timer Dial not advancing
The timer has given it up.  The motor has probably stopped working or the gears are jammed.  You'll need to obtain and change the timer.  Generally, there are face mounted screws that may or may not be behind some covers.  Remove them to get to the panel that holds the timer.
Nov 20, 2008 | Viking 24 in. Professional Series VUD141...
Marantz 2270 receiver
The lights are on the other side of the display. They have a plastic "wave guide" that deflects the light where needed. I hope this helps...accordianman
Jun 14, 2008 | Audio Players & Recorders
Top The Office Equipment & Supplies Experts
Ian White
Level 1 Expert
Level 1 Expert
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
