Question about Ovens
WHERE CAN I FIND....HOW TO REMOVE AND REPLACE A DASH PAD ON A 2000 FORD CONTOUR....THANKS...
DASH BOARD PAD...THINK THATS WHAT ITS CALLED...
  • 2 more comments
  • Willie Cooper
    Willie Cooper May 29, 2017
    it has to be done vey carefully remove all trims a carefully as you can then it will expose hidden screws that are there take those off go to a car recyle parts place it does not have to be the same year you will hve some to choose from or try eBay
  • larry croucher
    larry croucher May 29, 2017
    Thanks Willie,Maybe you would how to fix the dash..its all curled up by the bottom of the windshield...IT IS CALLED THE DASH BOARD.....RIGHT
  • Willie Cooper
    if you live near used car junkyard they might have one already off so you can see , by the way that is what you have to do to replace the heater core if the care is really high mileage I would replace the heater core go you your library and ask for a repair manuel you might get lucky
  • larry croucher
    ok thanks Willie
    Habit-Forming:
  • 144 Answers
I would start with u tube and then go to the junk yard they might have one off
type in how to remove instrument cluster that will show you a lot
Posted on May 03, 2017
  • larry croucher
    larry croucher May 03, 2017
    THANKS WILLIE........
My oven pad show out F2:E1
For Whirlpool (and associated brands), the F2 E1 error indicates a communication problem between the touch pad and the electronic control board. The oven's control thinks that the touch pad wiring is unplugged. This could be due to damaged wires, a loose wiring harness or a problem with the touch pad. First check that the wires aren't loose. Press Cancel to see if the signal is sent to the control board and clears the error. Wait 60 seconds for a response.
If the error persists, you need to replace the touch pad. On some models, you'll have to replace the touch pad and control board since they are sold as a single unit. For the units where the touch pad is a separate unit, you may still need to replace the control board. If the F2 E1 error persists after replacing the touch pad, then the control board is also faulty.
If you post a comment with the oven's make and model number, I may be able to give you the appropriate replacement part numbers. If your oven is still under warranty, contact the manufacturer for the repairs.
I hope this helps.
Jun 28, 2016 | Ovens
EO F2 whirlpool range
you have a bad keypad or a loose wire or ribbon,you can try unplugging it for 10 minutes and see if that helps or unplug it,remove the ribbon that connects to the keypad,plug the ribbon back in and see if that does anything,if not you need a new keypad. next time send the model number so i can help you betterF2 - E0 Shorted keypad (also called touch pad) 1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Read more: http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#Whirlpool Range / Stove / Oven Fault Codes#ixzz1dikBsooc
Nov 14, 2011 | Whirlpool Ovens
When cleaning the oven, F1 appears on the screen. What does this mean?
F1 - Board failure
Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be cancelled, replace the oven control (also called clock or ERC), touch pad, or both.
Only solve with replace control board (also called ERC or clock).
Hope this helps.
May 19, 2011 | Whirlpool Ovens
My oven has gone out and gave this message before dying.(.E1 F2) I think that means I need a new panel but not sure. Can you help? Where can I buy the part if need be?
HI. This code is in reference to a unplugged key pad cable. Use the check list below to address this issue further.
CLICK HERE TO BE DIRECTED TO AN ON-LINE PARTS DEALER.
Dec 16, 2009 | Whirlpool GMC275PD Electric Double Oven
I am getting an F1 signal after I self cleaned the over and now the over will not warm
Hi. This will Usually mean that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be canceled, replace the oven control (also called clock or ERC), touch pad, or both.
NOTE_ If your unit is equipped with an integrated control board, simply replace the entire control board.
Integrated control board= A control board that will have the touch pad built-in.(One whole piece)
Nov 11, 2009 | Ovens
Is it easy to replace the keypanel of the GE
Hello, The simple answer is yes it's not too hard...Normally you have a couple of screw located underneath the control panel. In most mordern ovens today they just consist of 2 components, the EOC (Electronic oven control) and the touch pad which basically cosists of everything you see(the whole panel). If you are replacing the touchpad..remove screws holding old panel in...pull wire harness from control board (dont worry where they go because the will only fit in one place) remove tape from EOC and relocate the control board to the new touchpad panel...reattach wire harness and tape in the new touchpad panel and hook back on oven ..screws in and your good to go. if replacing the control board (EOC) drop touch pad panel from oven and pull wires install new control then reassemble..easy!. One thing i would check though before purchasing the part, check to see it is the touchpad and not the control board...Here is how to do it...shut breaker off...pull out control panel...remove ribbon for key pad from EOC the re install panel..go switch breaker back on. leave for 24 hours..if within the 24 hours the error messages come back it's the EOC that is bad, if the error messages do not come back then you can be sure it's the touchpad. I would check this before buying the part since they are expencive and offten non returnable. Good Luck!! If you have any other questions or concerns please feel free to comment again. Thanks for using Fixya!! Mike
Jul 24, 2009 | GE Profile JKP56 Electric Double Oven
E6, f2
You have a stuck or shorted keypad. Try Cancel/Off and hold for 10 seconds. Then push every key several times to unstick. If that does not work unplug range and remove the access panel, disconnect the wire connections, then replace them. If all these steps fail replace the control. good luck
Jun 06, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
What does an F1 fault indicate
MAYTAG
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F1 Defective touch pad or membrane Replace touch pad or membrane (usually the touch pad)* F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC) F2 Oven too hot Replace relay board (if present) or bad oven temperature sensor F3 or F4 Open or shorted oven temperature sensor Replace oven temperature sensor F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Check for proper voltage F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or un-stick button F8 Analog/Digital supervisory Replace clock assembly (also called the ERC) F9 Door latch supervisory Check door lock circuit or replace clock assembly (also called the ERC) F0 Function key stuck Replace touch pad or clock assembly (also called the ERC) * Here is a simple test that you can do to determine whether the clock or the touchpad are defective when the display reads F1:
- Disconnect power to the range.
- Gain access to the back of the ERC (electronic range control, or "clock").
- Unplug the touch pad ribbon connector from the ERC. This will be a flat wire about 1 ½" to 2" wide.
- Make sure everything is clear and will not short out when power is turned back on. Replace any covers removed to gain access to the ERC.
- Turn the power back on to the range.
- Watch for the F-1 and listen for the beep.
- If you get the F-1 and beep, replace the ERC.
- If after approximately 60 Minutes you do not get the F-1 fault, replace the touch pad.
NOTE: Some models incorporate the touch pad and the clock control as one part so F1 = bad clock control.
Warning: If you do not feel comfortable doing this test or making this repair please contact a qualified appliance repair technician.
Jun 01, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
F2 E6 Codes appear, time flashes off and on
HI, this is a faulty key pad issue. check the following.
Mar 31, 2009 | Whirlpool RBD305PD Electric Double Oven
Jenn-Air WW30430W double oven flashing F7 and beeping
It seems you have a stuck button. Here is a list of fault codes:
JENN AIR
Failure
Code
Condition Check/Repair F1 Defective touch pad or membrane Replace touch pad or membrane (this problem is usually the touch pad) F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC) F2 Oven too hot Replace relay board (if present) or oven temperature sensor F3 or F4 Open or shorted oven temperature sensor Replace oven temperature sensor F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Check for proper voltage F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or attempt to un-stick button F8 Analog/Digital supervisory Replace clock assembly (also called the ERC) F9 Door latch supervisory Check door lock circuit or replace clock assembly (also called the ERC) F0 Function key stuck Replace touch pad or clock assembly (also called the ERC)
Dec 09, 2007 | Jenn-Air JJW8530C Expressions Collection...
Ovens Logo
60 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
