Question about The Office Equipment & Supplies
How to change developer on studio 35
How do i get to the developer unit
In toshiba e-studio35 the developer always leaks and run away
if you are sucking the developer out it could be a few things. 1. aftermarket toner. 2. bad dv unit. 3. bias problem (could be a setting, HVT failure, or continuity/grounding issues)
Nov 30, 2013 | Toshiba e-Studio 35 Copier
My thoshiba e-studio 352 giving an error "latch the developer unit". Please help to resolve this issue. Thanks Roy Robinson
I think the cable is not connected properly on the developer unit...Open front cover, take out the waste toner box, and u will see the connector.
Oct 02, 2013 | Toshiba e-Studio 350 Copier
Where does the developer go toshiba 3500
The developer goes into the developer unit. It is a supply that your tech installs. The copier you have needs both developer and toner. The developer is iron fillings that are used to hold the toner on the mag roller of the developer unit. It gets worn out over time. Good Luck
May 07, 2013 | Toshiba D3500 D-3500 Developer Starter...
Where we can buy toshiba studio 230 developer?
677864645f7a396c54674d71464b78424b4677-100x100-0-0.jpg Toshiba E-STUDIO 163 202l Developer Black
New Genuine Original D2320 TOSHIBA E-STUDIO 163 202L DEVELOPER BLACK Each $88.21ExtraMileToner
New Genuine Original D-2320 TOSHIBA E-STUDIO 163 202L DEVELOPER BLACK Each $65.33
Oct 21, 2011 | Toshiba e-Studio163 Copier
Error code F-35-1 in bizhub 7145 copier
quote is probably in the right price range. you need to look at how many copies are on your machine. look at any future repairs/supplies that will be needed. like drum, developer unit. If these are also needing to be changed soon, you will have to plan on those costs also. Any comparable machine that you get get will be expensive to repair the big items. You have to put all of the money that you spent on the machine and find out how many copies you have made. you can then figure out the cost per copy. At the same time, if this machine does everything that you need from a copier, do you want to buy a new one at much higher cost.
Oct 13, 2009 | Toshiba E-Studio 3511 Color Copier
Blank pages on E 35 Studio
type in the address bar
toshiba e35 copier print blank paper
Feb 06, 2009 | Toshiba e-Studio 35 Copier
Developer leakage while copying
after replace  developer you dont turn round the developer wheel left side. only right side.try this take out the developer and after re fill in to the developer unit. and u change the main charger unit also.
Feb 06, 2009 | Toshiba e-Studio 161 Copier Copier
Toshiba E-Studio 35 PM Kit Instructions
open front door and remove waste toner container, unplug connector and loose blue screw slide out developer unit removed top cover empty developer(100%). then open by-pass, duplex and jam access cover , remove two screws and slide out drum unit .remove charge corona. release latch on rearand remove bracket/bar( on top of drum),turn level counter clockwiseto release slide drum shaft out.remove two screw lift drum blade before install new drum & blade needdust some lubrication powder.after put everything back,hold down05 while turn onthen enter200,press start,let run about 3 minutes ,the value should bebetween 2.35-2.45 press set or interupt key same procedure doing 08then401 set to 0
Dec 15, 2008 | Toshiba e-Studio 35 Copier
Changing Developer on E-Studio 150
The developer you need to purchase is 1620 , and the drum unit also the 1620, you can see this number in the toner catridge itself. or in the toner catridge box. Regd. the 161 you need to purchase the products name 1620 number and the concerned part like developer, drum, toner, some gears etc.
Aug 19, 2008 | Toshiba e-Studio 161 Copier Copier
Changing the Developer on a Toshiba E-Studio28
If you are not a technician I would not even attempt this!
Jun 13, 2007 | Toshiba e-Studio 35 Copier
Top The Office Equipment & Supplies Experts
Ian White
Level 1 Expert
Level 1 Expert
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
