Question about Sony Cameras
When i turn on the camera, the zoom lens sounds like its trying to expand, but in only sits there and clicks, then says to turn camera off then back on
    Problem Solver:
  • 8 Answers
This is a common problem for Sony especially on the old DSC models. The gears around the lens are stuck and not engaging. It has to be disassembled and properly seated and lubricated.
Also, make sure your batteries are fresh and fully charged.
Posted on Jul 25, 2009
My Fuji S1500 lens will not go in and out? It reads zoom error
Put a freshly charged battery in the camera. Lay it on its back on a firm smooth surface with a cloth between the camera and the surface. Hold the zoom button in and while holding it in, turn the power on the camera. If the lens moves tun the camera so the lens points down and continue to zoom in and out. That may free some grit or dirt wedging the lens in place. If that doesn't clear the trouble, look closely at the lens and the way it sits in the camera housing. Check to see if the gap around the lens is even. If it is not, gently apply pressure with your hand in the direction of the widest gap. Listen closely for a light snap. If you hear one, the adds are the guid pins snapped back in place and you may now try the zoom. If all this fails there is one more thing to try, but it may result in further damage. if you will probably trash the camera otherwise, try this. Remove the battery. Holding the camera firmly by the edges with one hand with the lens down, slap the camera into your cupped opposite hand several times. Replace the battery and try the zoom. If the zoom works this time, with the lens pointing down, zoom the lens in and out several times to try to let the grit or dirt jamming the lens drop out.
Mar 29, 2010 | Fujitsu Cameras
Canon power shot a610, had camera in waterproof platic case. when i turned it on, the zoom focus lens wasnt lined up with tube it sits in and caught the edge stopping it from expanding out. now it wont...
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Oct 17, 2008 | Canon Cameras
Problem
I had the same problem and fixed it.
The problem is related to the lens not working properly and jammed up.
When powering on the camera, the focus goes in and out and the lens spin and then the message is displayed to turn camera off.When I turn the camera off, I noticed the lens did not fully hiberate into the camera like it did before the error message.
So to fix the problem I did the following:
Turn the camera on, when the lens extended out, I slightly rotated the outer most lens clockwise and counterclockwise to free the lens from the jammed position.
The error no longer appeared and the camera stayed-on.When I shut the power-off the lens completely hibernated again like normal.
Hope this helps.
Pete
Dec 25, 2007 | Panasonic Lumix DMC-LZ2 Digital Camera
The camera zoom got jammed
This can be caused by several different situations. Most commonly the camera has experienced some kind of impact which knocks an element out of alignment, preventing the lens from rotating normally. Symptoms of this include: *you may hear no mechanical sound at all when the camera is turned on *you may see visibly mis-aligned components of the lens *you may hear a loud "snap snap" sound as the camera tries to move the lens when the camera is powered on The second most common cause is a particle of sand getting stuck in the focus motor drive gears. This prevents the focus element from moving normally and causes the camera to shut off to prevent damage to the lens assembly. Symptoms of this include: *A loud "buzzing" sound when the camera is turned on, followed by the beeping and shutdown. Finally the third most common cause of this problem is a broken tooth on the zoom motor drive gears. Symptoms of this include: *the sound of the running motor with a regular "click click click" sound for several seconds. This will not be a "snap snap" sound, that is a different problem. *the lens will move in and out easily by hand as if free from any resistance. All of these problems require disassembly to repair. The charge is around $125 at my shop. Broken drive gears are generally This can be caused by several different situations. Most commonly the camera has experienced some kind of impact which knocks an element out of alignment, preventing the lens from rotating normally. Symptoms of this include: *you may hear no mechanical sound at all when the camera is turned on *you may see visibly mis-aligned components of the lens *you may hear a loud "snap snap" sound as the camera tries to move the lens when the camera is powered on The second most common cause is a particle of sand getting stuck in the focus motor drive gears. This prevents the focus element from moving normally and causes the camera to shut off to prevent damage to the lens assembly. Symptoms of this include: *A loud "buzzing" sound when the camera is turned on, followed by the beeping and shutdown. Finally the third most common cause of this problem is a broken tooth on the zoom motor drive gears. Symptoms of this include: *the sound of the running motor with a regular "click click click" sound for several seconds. This will not be a "snap snap" sound, that is a different problem. *the lens will move in and out easily by hand as if free from any resistance. All of these problems require disassembly to repair. The charge is around $125 labor at my shop.
Jun 14, 2007 | Canon PowerShot SD300 / IXUS 40 Digital...
Cameras Logo
65 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
