Question about Samsung Televison & Video
In order to repair my Samsung UN32H5203AF US02 TV, what part would need to be replaced? Details below...
I have the Samsung UN32H5203AF US02 TV. It suddenly went black. I checked the backlight and there isn't any. I checked the screen using the flashlight and you can see the menu, etc. Sound is good! Called an online part supplier, they sold me the power board. Changed it, but did not resolve the issue. Another tech told me that it is the LED driver or LCD inverter. I have the service manual, but it does not reference either parts.
    Sergeant:
  • Samsung Expert
  • 330 Answers
In most of the case, the problem is the LED back lights strips, it was the most case we encountered.
To check it, un-plug the cable between the power supply & the main board, apply the AC power to it, if the back lights came on, replace the main board, if not, mostly the problem is the back lights LED strips.
Posted on May 27, 2017
TV #1
  • 129 Answers
SOURCE: my 32" lcd vizio vx32L turns on there's sound
Have you tried the T-con board?
Thank you,
Posted on Dec 18, 2010
SOURCE: Replacing a Vizio Backlight Inverter
I have a television that did this. The picture went out but it continued to have sound. It was the projector bulb. I ordered from a dealer on ebay, very resonably priced. It came with instructions on how to install it and was a very easy fix.
Posted on Feb 25, 2012
mike0862
  • 5670 Answers
SOURCE: Seiki led tv has sound but no picture. The picture can be seen with flashlight. We tried resetting default on menu with tech support, still no picture. Has no backlight. Which part should we replace?
You are correct, this is a backlight issue! The screen inverter is usually built into a circuit board, if you want to attempt this yourself you will need to access the circuit boards to see which one you need to replace! If you open up the TV and post a picture we will be able to point you in the right direction!
Posted on Jan 11, 2015
Testimonial: "Thank you for your quick and very helpful response. My husband will tackle that task soon and we'll send photo. Hopefully will be an easy fix. Thanks!"
gopakumarg43
  • 75581 Answers
SOURCE: lg led tv backlight
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Posted on Feb 05, 2015
phil_hick883
  • 917 Answers
SOURCE: How can I get my backlights to work on Samsung LCD tv
If your not a TV Engineer , get one to look at it , as you may keep changing the incorrect part.
Posted on Mar 14, 2015
I have audio but no video samsung UN32H5203AF
That is video codec problem.Change your Application for a popular generic video player.
Feb 06, 2018 | Samsung Audio Players & Recorders
How to replace led lighting in samsung UN32H5203AF tv
The process is delicate and requires a fairly dust free environment. You can see examples on youtube.
Feb 06, 2018 | Samsung Televison & Video
No sound, no picture, stand by light on but will not turn on (green) only blinking red light. I have replaced both main board and the power board. Still nothing. Any suggestions?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Aug 06, 2016 | Samsung Inch Smart Un32h5203af Hdtv
Why cant I get Netflix on Samsung UN32H5203AF. Sets up OK buts says theat it cannot be watched at this time
Contact Samsung's Remote Management. They can remotely configure and even update the firmware on your TV. Here's a link...
Samsung TV Remote Support
Jan 26, 2015 | Samsung Cell Phones
How can I get the part number for the power board for a Samsung plasma tv PN52D530A3F. The board was taken by a repair guy and he disappeared.
You can get it from its repair manual; or by contacting the authorized service centre for Samsung. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 31, 2014 | Samsung PN51D530 51 in. Plasma TV
How to assemble tv stand
To know more about this, you have to download the repair manual to this set. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts. Surf the site with patience.
Apr 10, 2014 | Samsung LN32C540 32 in. LCD TV
Screen distortion shadow
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Below are more details for both items. Also, complete repair kits with instructions and repair support are avail from site such as www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. The power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
What you will need to do is convergence. You can get a repair kit from TvRepairKits.com . It includes replacement parts,step by step instructions, support, etc.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from TvRepairKits.com . It includes replacement coolant,step by step instructions, support, etc.
Feb 08, 2012 | Samsung HL-R5656W 56" DLP HDTV
Open Questions:
Televison & Video Logo
155 people viewed this question
Jerry Greenberg
Jerry Greenberg
