Question about The Office Equipment & Supplies
I'm trying to read a gas meter with a and B buttons. When I press a there's a noise but the screen doesn't respond, how do I get a reading?
SOURCE: Makes a loud clicking noise and reads scanner error.
I had this exact problem. This printer was given to me, so I didn't have the instructions. I'm pretty sure I damaged it when I tried to open it to change the ink. I didn't realize there was a lever. After I got it open, I had trouble closing it, but eventually I got it to sit down flat. It was after this that the scanning function ceased to work as described by others.
I searched online to find a solution, but was hesitant to buy a repair manual. I read about someone else who took the unit apart. His experience was really a help as he knew just what part to take off. You need to remove the gray panel on the right side of the unit (as you are facing the front). This is the side with the USB port.
There are only three screws to remove. I used a flat head screw driver to gently pry the pieces apart. There are two places it snaps together on the bottom of the unit. I was able to get it apart without damaging anything. Once it's open, you will be able to see there are a few ribbons that connect the top of the unit to the circuit board in the base. For me, two of these had come loose. I simply slid them back in the slots where they seemed to belong and put the thing back together.
It was easier than I imagined and it worked! Good luck.
Posted on Mar 16, 2008
  • 300 Answers
SOURCE: Meter read on HP Laser Jet P2015
To print a Configuration page from the printer, press
and hold the Go button for 5 seconds
Posted on May 16, 2008
  • 284 Answers
SOURCE: Need to get a meter reading from my Panasonic DP190 fax machine
i just tested on a machine. if the copy light is on and if you press paper tray and copy size buttons at the same time it will show you a count if not i can show you a way to print it
Posted on Sep 22, 2008
  • 3 Answers
SOURCE: rca drc8052nb only says ''hello'' on screen, can anyone help?
RCA DRC 8052NB does nothing but displays "HELLO"
Among the voltages available from the power supply is a 3-volt source. The first capacitor after the diode is a 1000 microfarad, 6.3-volt unit. There were no signs of leakage of overheating, but I changed it anyway. Voila! the unit came to life. Hope this helps.
Posted on Jul 12, 2009
SOURCE: film advance stuck and metering problem on Minolta X700
Hi, i have the same problem, do you fix it?, can you give me the solution please?
Thanks, my mail is
Posted on Mar 18, 2010
I pluged in the treadmill and the display screen turn on but when i press one of the preset buttons it doesn't respond what do i do
use silicones or wax read your o.manual. Adjust the REED switch, clean it, and tigh the connector very well . Of course test for open or faulty. see the diagrama
God bless youfae5e48a-3b4a-46e1-97e7-daf4cd17fef3.gif6c87d923-76bb-4cb3-a607-1be11d1fb26a.gif
May 22, 2013 | Triumph Academy Sports 400T Treadmill
How do i get meter reading on t35?
On the panel, there is a User Function button with 123 marking...Press on it...then u will see the meter reading on the right side of the screen...
Jul 16, 2012 | Toshiba e-Studio 205 Copier
Where is the meter read button on the canon 1025?
hi sir, nothing counter / read meter button on this copier, and you can see at the mini LCD only.
to see reading meter you press the star button (*) than you press (>) or (<) button to find a counter than press (ok) button.
good luck
Jun 24, 2011 | Canon imageRUNNER 1630 Copier
I have the bizhub C352 - I want to print the utility/counter (meter readings). How do i do that. Previous machines had me go to Utility - admin management - copy track - Copy track data - & hit the...
to print meter readings perform these steps. 1-press "utility/counter" 2-press "details" 3-now at the left side of the screen you will see a "print" button, press it and get your copy.
Oct 20, 2010 | Konica Minolta bizhub C250 All-In-One...
Electric Range Model Number: FEF365CGBD> The oven door is open and the lock is engaged. The lock light is flashing. I tried disconnecting power (from the main breaker) for about 10 minutes but that...
. If you can push the latch in manually, press the clear button while the button is pressed in. If that doesn't clear it:
Try disconnecting the power at the breaker to reset any electronics that might be at fault. (Make sure there are no little graphics of a lock that appear on your screen. If there are and you can't find the source, the shut down should help.
There is sometimes a separate switch aside from the light switch the is on the front of the stove front or very close to the latch itself. Considering that the oven clean will work, if there is one, it appears that is working in the in position. Look around the latch and the front of the oven for any other switches. Clean it if you find a separate control so that it can pop back out when the door is open.
hold in the door button and push broil until the latch makes a 360 degree
then the door lock should stop flashing and the oven will work again .
Hold the lock button for 3-5 seconds..
if the door was open but the lock are latched. Holding the Clear/Off button had no effect. We unplugged the unit. Then while one person held the oven door light switch button in, another person plugged the unit in. While still holding the light switch button in, the Clear/Off button pressed for 10-15 seconds, at which point "locked" appears in the display. Then, while still holding the light switch button in, pressing and holding the Clear/Off button unlock the unit.
if still the same problem the door assembly is cracked and that needs can get required parts
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Jan 17, 2010 | Kitchen Ranges
LCD display on minolta autometer 3 constantly blinking
I can't help but have the same problem! battery OK. Can change ASA/ Time but when I press button to take a light reading the display flashes for about a minute. did you ever find a solution?
Mar 01, 2009 | Cameras
How can I get a meter reading from an AR-M237?
press and hold the the button that says "copy" on it next to the screen, the meter should show on the screen
Dec 05, 2008 | Sharp AR-M237 Copier
Meter reading
2 ways to check the meter.
press the user tools button on the op panel. on the screen press counter. you can either view the counter on the screen, or press print counter, and it will give you a hard copy.
the 2nd way is to look behind the front cover, probably behind a piece of tape, on the right side, about half way down.
Nov 20, 2008 | Lanier 1205 Copier
Touch Screen
Hi Blu,
A friend had a similar problem, with the touchscreen not responding at all. I read somewhere on the internet that if you press the four corners of the screen very hard with your thumbs it may come back. I tried it...and it worked!
Jun 25, 2008 | HTC Touch P3450 Smartphone
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
23 people viewed this question
Top The Office Equipment & Supplies Experts
Ian White
Level 1 Expert
Level 1 Expert
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
