Question about Hilti Drills
How to open a hilti charger - Hilti Drills
Can C7-24 hilti charger that had been out in the rain be repaired
try putting it in a bucket covered with rice for a couple days...sometimes this will absorb any and all moisture in the device
Jun 16, 2016 | Hilti Drills
Hilti 22-a
The problem here is it could be either the battery or the charger, most of the time it's the charger. The only way to check is to try charging your battery on another charger or try charging another battery on your charger. If you have two batteries this is easy, if not you have to find a service center or someone you know with the same battery and charger to find out which is bad.
Jul 18, 2012 | Hilti Drills
Where can i get a schematic drawing for a TE 5A battery charger
There are no schematics for the 5A charger. Those were not serviced by Hilti. If they were bad then they just replaced the whole unit. If your charger has no power at all there is a fuse inside that you can replace. Other than the cord that is about it. I think you can still get a charger from Hilti. 1-800-879-8000
Nov 22, 2011 | Hilti Drills
Do you know where i can find electronic diagram of hilti c7/36-acs
contact their tech support direct at 1-800-879-8000 for assistance
Nov 29, 2010 | Hilti 285359 SF 121-A 2.0 NICD Cordless...
Battery wont charge on new charger
Just return it to a Hilti dealer, they replace everything for free.
Oct 21, 2010 | Hilti Cordless Hammer Drill Sfh 151 A...
Hilti c7/36 I am looking for a electronic diagram
if the light on the charger are functioning ok. the problem is most probly the batterys. they dont last forever, replace the batteries and you should be ok.
Jul 20, 2010 | Hilti 285359 SF 121-A 2.0 NICD Cordless...
Where can i get my hilti 36v charger repaired
Most chargers have a replaceable fuse. This may have blown.
Jul 17, 2010 | Hilti Drills
How do i refresh battery
Hello
You can revive the dead nicd batteries in your tools.
There is a simple guide that can fix all nicd batteries in few minutes, available here.
Thanks
Dec 04, 2009 | Hilti 285359 SF 121-A 2.0 NICD Cordless...
I cant seem to locate a Hilti TE5A battery charger
I would call Hilti direct at 1-800-879-8000 and speak with one of their customer service reps and they should be able to help. If not let me know and I will contact my local sales rep and see what I can do for you.
May 11, 2009 | Hilti Cordless Hammer Drill Sfh 151 A...
This must be an older tool but you can try calling 1-800-879-8000 and ask Hilti direct where you can purchase this if it is still available. Good luck
May 11, 2009 | Hilti TE 7-C 120V Rotary Hammer Drill
Drills Logo
73 people viewed this question
Top Hilti Drills Experts
woodzowl307
John Trevino
Are you a Hilti Drill Expert? Answer questions, earn points and help others
