Question about Lands Phones
I need resistors color of Loboss phone,model Hcd 3588tsc L-13
My sony hcd-gnz888d resistor got burnt and I want to replace it but don't know d resisto No. Pls, who can help me ?
BUY A BUNCH OF RESISTORS WITH A CHART AT RADIO SHACK (very cheap) AND START INSERTING THE HIGHEST RATED RESISTOR IN; GO DOWN ONE BY ONE UNTIL YOU FIND THE RIGHT SETTING.
Jun 17, 2015 | Sony Audio Players & Recorders
CAN THE DISPLAY UNIT OF MUSIC SYSTEM MODEL HCD VX 55 BE REPAIRED
check the five and twelve volts d.c is reaching the panel and if not trace the fault mostly from a protection zener diode
Jan 29, 2015 | Audio Players & Recorders
My sony dvd player only plays in black and white. Any ideas? my model is HCD-BC150.
See if you are having a color system issue. PAL TV with NTSC DVD player or the other way round.
Mar 10, 2011 | Sony DAV-BC150 System
I have a Sony receiver/tape deck/cd system, and need a copy of the owners/users manual in order to use the presets and other features to best advantage. The model of the unit is HCD250 or Hcd-G2000. I was...
http://www.givemefile.net/smanuals/hi-fi_hi-end--others/sony/hcd-g2000_26718.html
Above is a service and repair manual for the Hcd-G2000.
Below is your user guide.
www.devicemanuals.com/guide/.../Sony/Sony-Bookshelf-Hi-Fi-System-HCD-F250AV-User-Guide-TXpZek9EST.html
Support links for Sony below.
esupport.sony.com/
HCD250 service repair manual below.
http://www.givemefile.net/smanuals/stereos/sony/file/8297.html
Aug 24, 2010 | Audio Players & Recorders
Model 53UWX103B - parts 21 chips for converters to
This is a model that uses either the STK-392-110 OR STK-392-150----BOTH are the same part but the 150 chip lasts longer.
Most of the time the "kits" are a waste of money--unless something unusual has happened you will just need a pair of the chips and maybe one resistor.
There are several resistors around them that can fail if a chip shorts. The kits average 40-80 dollars but you can buy a pair of the 150 chips on EBAY for about 13 dollars plus shipping.
Let me know if you have specific questions or need advice--I am here to help.
SD TECH
Dec 10, 2009 | Televison & Video
WILL NOT TURN ON
Sir;
friend of mind had the same model # and he give me the color band for the resistor
Nov 18, 2008 | Yamaha HTR-5560 Receiver
Manual for a Sony s-master 5.1ch full digital amplifier
Where can i find some extra speaker wire and connectors for my speakers
Aug 30, 2008 | Televison & Video
No Power... Main Fuse Blows right away. Resistor R809 has its outer layer burned off so I cant tell what value it is.
I would check the rectifiers (diodes) all 4; one or two may be shorted. Check color code for R809 or may have number on it if it is white square resistor
Dec 29, 2007 | Daewoo DVN-14F6N 13" TV
Lands Phones Logo
29 people viewed this question
Top Lands Phones Experts
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
