Question about LG Dishwashers
Dishwasher LG #14at1 start and run two minuts then stop and show 1e errors .please your advise.
onthejob5130
  • 640 Answers
SOURCE: LG DISHWASHER LD-12AW2
ae unknown code,,,but ie that means uinit is taking to long to fill,,your inlet screens are clogged or the water pressure is to low...kinked hose...onthejob
Posted on Feb 04, 2009
Krazytech
  • 725 Answers
SOURCE: I have an error code of 1E on my LG dishwasher
1E error is Not reached to the normal water level in spite of 10 min. water supply
POSSIBLE CAUSE REMEDY FOR ERROR OCCURRENCE The Water Supply Tap is closed. The Water Supply is shut off. The Inlet Hose is kinked. The Water Pressure is very low. (below 10 psi) Inlet Valve is OK? The filter of Inlet Valve is clogged by impure water. The Hall sensor is OK? The Impeller of Air Guide is bound.
Remedy Take action on Water Supply device. Measure the electric resistance of Inlet Valve. (950-1300 ) Clean the filter of Inlet Valve. Check the frequency of Inlet Water by the Test Mode. Replace the Air Braker.
Posted on Sep 27, 2009
Krazytech
  • 725 Answers
SOURCE: keeps alarmimg 1E on my Lg Dishwasher
Inlet water error 1E
SOURCE: I have the same problem !!!
I have the same thing happening to my dishwasher what do I do
Posted on Oct 19, 2009
rickead1
  • 1998 Answers
SOURCE: We have an LG lds5811ww dishwasher with IE error
check for voltage at the water valve when it should be filling Try disconnecting the Water Valve outlet from the DishWasher and run the output into a bucket if all is well with the valve then remove the door panel and inspect the wires near the bottom of the door. the wires get buried in the tar like insulation causing the wires to break as the door is opened and closed.That tar like substance is one of the worst things they could of ever put into that machine causes the wires to break apart adn become brittle
Posted on Apr 30, 2010
Hello, LG LD 14AT1 dishwasher, starts cycle runs 3 minutes, starts stops on off no water in bottom. Then displays OE chimes! Checked tap under sink water there, checked filter inside bottom, turned off for...
Hi
OE in your dishwasher is a drain error and dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. If the issue returns after cleaning then the drain pump assembly should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 27, 2011 | LG 24 in. LD-12BS6 Stainless Steel...
I have an LG F1256QD machine that keeps stopping half way through the cycle with the message 1E displaying. I've lost the manual! Any idea how to solve the problem please?
1E = WATER INLET ERROR
• Correct water level (2 level) is not reached within 8 minutes after water is supplied or it does not reach the preset water level within 25 minutes.
Check to see that your water valves are open all the way. Check the strainer in the water hose for any buildup or blockage.
Here is the "Service Manual" for your machine.
Happy Holidays! Rick
Dec 11, 2010 | LG Washing Machines
Keeps alarmimg 1E on my Lg Dishwasher
Sep 24, 2009 | LG Dishwashers
Aug 18, 2009 | LG 24 in. LD-12BW5 Free-standing...
LG 14AT1 Dishwasher not working
Well done! Can you confirm that you own an LG dishwasher?
Thanks!
Mar 14, 2009 | LG 24 in. LD-12BS6 Stainless Steel...
LG dishwasher not working showing 1F in timer display
I am not aware of an LG code 1F. But there is an error code "1E"
After you double check that the water valve is open that feeds the dishwasher, focus on the inlet valve (solenoid)
As you remove the inlet valve, if you see the screen is filled with gunk, clean it and retest.
Good Luck!
Feb 28, 2009 | LG 24 in. LD-12BS6 Stainless Steel...
LG Dishwasher LDS5811ST 1E error code
I had a LG certified repairman come out and fix. The electrical wires within the door were melted into the "tar" (sound deafening spray) and one wire actualy sheered. Apparently the drying cycle heats the tar and the wires become embeded and melt into the tar. This is what was causing the error code. After the wire was tested and spliced everything worked great. Long term...The door/electrical harness was replaced by LG.
Oct 08, 2008 | LG 24 in. LDS 5811ST Stainless Steel...
LG LDF7811ST 1E code
Are you sure it's 1E and not LE error code??  The symptoms you mentioned indicates that it is an LE error code and the motor has an issue.  You will need to call a qualified LG technician to diagnose and resolve the problem.
Jun 28, 2008 | LG 24 in. LDF 7811 Stainless Steel...
Dishwashers Logo
29 people viewed this question
Top LG Dishwashers Experts
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
