Question about GPS
Have a Nuvi 2595 that keeps reading Battery is low even when I plug into AC, tried two different cables and two different cars. Thanks
SOURCE: CANON POWERSHOT A530 LOW BATTERY READING
We had the same problem and it was so very frustrating. We sent the Camera back for assesment and repair only to be told there was nothing wrong with it. The solution was so simple we felt like real dummies.
All you have to do is use Energizer Lithium Batteries, since we started using them we have not had a problem with Batteries going flat or that annoying Battery indicator flashing.
Regards
John
Posted on Oct 15, 2008
SOURCE: Garmin Nuvi 760
Sounds like you both have a battery problem. I experienced a similar problem when trying to charge via the USB-cable connected to my computer.
Ended up buying an original charger (expensive) and the charging went smooth.
The car charger should in any case work fine, so probably your battery is not very healthy.
Try holding your finger on the battery symbol for about 10 sec. The unit will then switch to a technical page. There you can observe the battery and charging voltage. When I plug in my computer USB-cable, I read around 4,4V and that is not sufficient for charging my battery.
When connected to the original charger, this voltage rises to about 5V which gives a nice charge. When unplugging charger, the unit displays the battery capacity. If the charging voltage is OK, but battery capacity drops quickly after you unplug charger cable, the battery is probably bad. (Of course you have to charge is for some time) I think around 4V battery voltage give 100% capacity. 3,9V gives about 90% capacity.
This will not solve your problem, but can give you an idea about what is wrong.
Good luck.
Posted on Nov 17, 2008
ginko
  • 19396 Answers
SOURCE: without plugged in my garmin nuvi 200 will not work
That means that you have to replace the battery.
The video on the link below shows how to replace the battery in a Garmin Nuvi:
How To Change The Battery On A Garmin Nuvi 760
Posted on Apr 13, 2009
  • 14 Answers
SOURCE: garmin nuvi 750 battery does not hold a charge
A new battery can be purchased and installed inexpensively. I found a video.
You-Tube video "yxP4PdRB_98" placeholder (do not delete)
http://www.newpower99.com/ProductDetails.asp?ProductCode=GARMIN+NUVI+750
Posted on Dec 26, 2009
  • 504 Answers
SOURCE: Why should my GPS indicate a low battery even
It sounds like the unit is not being charged when it is plugged into the car. Does it come on when you plug it in, or do you have to press the power button? If you have to press the button, the charger is not sending power to the unit. Make sure it is connecting properly to the unit and that it is seated in the AC outlet correctly. If it is, check the fuse in the end to see if it has blown. If so, replace it. If that is not the problem, you may have a problem with the AC outlet in the car.
Posted on Feb 18, 2010
What type torx size is the 2595
Go on eBay and buy a kit to change the battery, it will come with the right torx bit size.
Jun 23, 2016 | Garmin nuvi 2595LMT 5" GPS w/Lifetime Maps...
Garmin nuvi says low battery and it is plugged into the car
The Garmin will tell you 'Low Battery' if its alternative power source is not available for some reason, so the battery is not being charged. Depending how the Garmin has been programmed, the display on some models will become slightly brighter when a power supply, other than its own batteries, is detected. Check for this.
It is likely that the lead you use to plug into the car is not supplying voltage to your Garmin set. If it plugs into a cigarette holder, check that the cigarette lighter works, or plug in another device to see if there is any electricity to the receptacle. Obviously ensure that the ignition switch is on. If the plug-in bit of the power cable has a light on it, check the light is illuminated. if you have a sensitive tongue, you should be able to put the end of the lead that plugs into the Garmin onto your tongue and you will feel a very slight tingle on your tongue if power is getting to the end of the lead. If not, then there is probably a break in the lead inside the plastic insulation or a problem with the supply plug.
If the plug in lead proves serviceable then you should change the batteries in Garmin as one or more may have failed and will not charge. Check for this by leaving the unit on after unplugging the external supply lead. Depending on the Garmin you have, the unit should remain functioning for at least 30 minutes. The internal batteries will degrade rapidly if the unit has not been use for some time and the batteries were not fully charged before you put it to bed.
Mar 10, 2014 | Garmin Nuvi 2460 2495 2555 2595 3790 Lm W...
Garmin nuvi 2595 will not take a charge
I found my brand new nuvi 2595lmt repeatedly power cycling and loosing its charge when I tried to charge it (for the second time as well). I was using a different USB cable. When I switched to the supplied cable with the "Garmin" insignia on it, the problem resolved. Hope that helps, good luck.
Feb 17, 2012 | Garmin GPS
Today i turned on my garmin after a few months, it was working will for about 2 min, then it lost satellites, so I turned it off, then tried to turn it back on, but it never turned back on. the battery...
If the GPS's internal battery is allowed to discharge too far, it will not be possible to recharge with the card charger, until it is brought up to a certain level. Connect the nuvi to a computer with USB cable overnight. This will trickle charge the internal battery to a level that will allow the car charger / cradle to keep the GPS charged from that point on. Anytime the car charger fails to recharge the internal battery, the USB charge method will have to be performed first.
Oct 21, 2009 | Garmin nuvi 200W GPS Receiver
My Garmin will not start up.
it sounds like your battery within the GPS Unit is died. You need to charge it somehow. Keep it connected to the car charger for around 30 mins and unit should turn on. Do not keep it on while it is being charged
Oct 18, 2009 | Garmin (010-00583-00) for nuvi 750/760/770
Garmin 200w goes into usb mass storage mode when pluged to charge
Steps:
1) Disconnect the nuvi from the charging cable.
2) Press and hold the battery meter icon for 8 seconds. This puts the nuvi into "system test" mode.
3) Plug in the power cable.
4) Click "Exit." The nuvi will reboot, but remain in GPS mode!
Jun 08, 2009 | Garmin nuvi 200W GPS
Garmin Nuvi 760
Good luck.
Oct 28, 2008 | Garmin Nuvi 760 Handheld GPS Receiver
Nuvi 200 GPS
We did not have a charger to plug in the GPS to charge, so my husband plugged it into a battery charger. I guess the battery charger was low, so it drained the unit rather than charging it. It was so low it would not come on again. I have an electric charger that adapts the car charger into AC current, so I tried that and the unit came on. Problem solved and the GPS is working again. Thanks for responding.
Jun 20, 2008 | Garmin nuvi 200W GPS
GPS Logo
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
